Page 2 of 2 FirstFirst 12
Results 26 to 50 of 50
  1. #26
    Jun 2018
    been messing with the adjustments, tbh the rear cogs shift fine and in the front going from big cog to small cog is no problem, but going from small cog to big cog is tough.
  2. #27
    Reputation: Fredrico's Avatar
    Jun 2002
    Quote Originally Posted by Sproiteboike View Post
    first make sure the cage is lined up with the chain, not curved in or outward. Then take a screwdriver and back of the outer limit screw 1/4 turn and see if that works. If not, back off the screw another 1/4 turn.
  3. #28
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Whoa those are pretty good deals, why are they so much cheaper?
    E-commerce versus the QBP brick&Mortar monopoly. Being online, they don't have to support it with adjustments, only warranty in the event of failure.
    Same way Amazon is driving all B&M retail out of business.
  4. #29
    Jun 2018
    ah so basically QBP is a store branch? I was wondering because I didn't see any bikes on their website, but they do have a QBP 2 hours from me!
    Been watching how to adjust deraiullers online and tbh its very easy! I think I got my bike shifting better now, though I will take it to the store at least once just to be safe.
    I really like how bikes have a simple mechanism, it's like my escape from an over-stressed tech world. I hope electronic shifting and etc don't become standard in the future because I don't want to have another thing to keep charged!
  5. #30
    Jan 2005
    Quality Bicycle Products....they're the single largest bike parts supplier in the USA...most shops are under their thumb WRT supply chain and pricing.
  6. #31
    'brifter' is a lame word.
    Quote Originally Posted by Fredrico View Post
    Much better advice would be to figure out why the shifting is working correctly first, then you don't need to blindly adjust limit screws.
    I work for some bike racers
    and a bunch of skateboards
  7. #32
    Nov 2009
    I agree, having him mess with the limit screws at this point is asking for trouble.
    May just need a simple turn of the inline barrel adjuster.
  8. #33
    Quote Originally Posted by factory feel View Post
    Kinda sounds like it's more of a lack-of-tension issue than a limit screw, right?
  9. #34
    Nov 2009
    yup.
    And having him mess with the derailleur cage alignment, as suggested above could get him in a big mess.
    My advice, like yours, is start with the easy common sense stuff.
  10. #35
    Apr 2013
    absolutely. nothing wrong with getting 105. that said i'd pay the few dollars extra and get ultegra at least. just looks and feels a bit nicer. but 105 will get the job done.
  11. #36
    Jun 2018
    Unhappy BMC SL01 Road Racer - Integrated Seat Post Clamp Split, how to remedy?
    Quick Question? How to remedy a split integrated Seat Post Clamp in a BMC SL01 Road Racer frame?
    The cycle is a favourite. It rides very well. However, on a recent ride the seat post felt odd, on arriving home, horrified to see the crack. What are the possible ways to remedy?
    All advice that leads to an ability to continue to ride the bike is hugely appreciated.
    A few pictures to illustrate:
    Is it okay to get a 105 groupset on my 2018 domane al 2 (claris) ?-img_4393.jpgIs it okay to get a 105 groupset on my 2018 domane al 2 (claris) ?-img_4392.jpg
  12. #37
    Jan 2005
    Quote Originally Posted by MattCole View Post
    Mount it on the wall and buy a new frame. Can't replace the collar. Aluminum so you can't weld it without screwing up the treatment. New bike time.
  13. #38
    Jun 2018
    Hey guys, I messed with the barrel screws for the front and rear derailer and it's shifting nice and smooth now (well not 105 smooth, but smooth enough for claris xD)
    i shall be a bike mechanic yet!
    so how often are you supposed to adjust the small screws in the front and rear derailer? or are those 'set and forget'?
  14. #39
    Nov 2009
    Once you learn what they are for, it's good to check your limit screw settings by shifting into the highest or lowest speed cog while bike is in a work stand and turn the pedals while simultaneously and carefully pushing or pulling inward or outward, depending on cog and see if chain wants to climb over the cog.
  15. #40
    Dec 2015
    Performance Bike is a franchise and sell online rather than being a small local bike shop. They're also owned by Fuji Bicycle's parent company also owns Performance Bike. The bikes were on sale so I bought them below MSRP.
    I support my local bike shop in other ways but I'm not dropping an extra $1,000 just for the Trek name with same level of components. I prefered the ride of my Transonic over the Madone too.
  16. #41
    Jun 2018
    Looks like BMC Frame Failure
    After careful review this looks like wise advice - so sorry to see the BMC go, whoever signed off that design?
  17. #42
    Reputation: Lombard's Avatar
    May 2014
    Remember that saying "If it aint broken, don't fix it"? Don't adjust anything until the next time it has a problem.
    For what it's worth, cables have a whole lot more to do with smooth shifting than any of your other drivetrain components. I am think if this is a Claris bike, it probably has the cheaper galvanized cables. These oxidize and become rough with time. Roughness will lead to poor shifting. Run your fingers along one of the cables. Does it feel smooth or rough? Does it leave a gray residue on your fingers or not?
    I am thinking that a set of good quality STAINLESS STEEL cables will improve you shifting. As I said before, if it's shifting OK now, then leave it alone. But if/when you have shifting problems again, upgrade your cables before you go spending gobs of $$ on a whole drivetrain upgrade.
  18. #43
    Jun 2018
    Nice thanks, I didn't know that, but it makes sense!
  19. #44
    For what it's worth I can't remember the last time I saw a newish bike that had galvanized shift cables. EVERY new bike comes w/ stainless cables now. As long as it's a 'real' bike from a 'real' bike shop it will have stainless cables. The odds that the OP's bike is having problems because it has non stainless cables is so slim it's not worth thinking about.
  20. #45
    Nov 2009
    Thank you for saying what I was about to post. so much false info gets spread around.
  21. #46
    Nov 2009
    Terrible advise, where do you come up with this inferior cable stuff?
    And checking your derailleur limit adjustment periodically is a good practice.
  22. #47
    Jun 2018
    Hey guys, I went to the bike shop for my 30 day free tune up and they cleaned it up, lubed the chain, trued the wheels, adjusted everything and now it's shifting and riding silky smooth
    sometimes when going to the big chain ring from the small chain ring there is a hesitation, but they said thats more for shifting technique and shifting at the right time from the right gear and they said that the shifting resistance and everything seems normal!
  23. #48
    They're most likely right about the front derailleur shifting from the small ring to the big ring. You need to be pedaling at a decent cadence and let off the power just a bit when you make that shift.
  24. #49
    May 2014
    I have. Trust me, I've seen it and not on only Claris bikes. I've seen 105 bikes come stock with cheap galvanized cables. My shop concurs they have seen it too on "real bikes" from brands like Trek, Cannondale and Specialized.
    As I said, the finger feel test speaks louder than words.
  25. #50
    I can't say anything about Cannondale or Specialized but I have NEVER seen a new Trek road bike w/ galvanized cables and you know where I work.
  1. RBR TdF 2018 Predictions! Post by Start Time 2018
    By PJay in forum Pro Cycling - Tour de France
    Last Post: 3 Weeks Ago, 07:45 AM
  2. Replies: 4
    Last Post: 11-09-2017, 06:03 AM
  3. 2018 Trek Domane SL
    By Rashadabd in forum Trek
    Last Post: 08-01-2017, 07:58 AM
  4. 2018 domane alr
    By vurtualife in forum Trek
    Last Post: 07-15-2017, 09:55 AM
  5. Replies: 3
    Last Post: 05-01-2017, 05:34 AM
