Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 86
  1. #51
    Apr 2017
    So, unimaginably, a quick test of 1/5th the price resin pads instead of finned sintered ones completely muted the brakes (exact same method of bedding in - brake firmly from good speed without locking wheels about 10-15 times).
    However, one of the pistons in the other caliper doesn't move at even speeds even after cleaning and bleeding, which keeps bending the rotor. They don't sell those separately, so gonna have to replace the whole caliper.
    Otherwise, everything's nice apart from few things nothing to do with brakes. Completely fixable as well tho.
  2. #52
    'brifter' is a lame word.
    Quote Originally Posted by nimetonmaili View Post
    I'd spend some time trying to get the pistons to move evenly before buying a new caliper. Pull the pads out and get some mineral oil. Carefully pump the lever a couple of times to expose some of the piston and apply a few drops of mineral oil to the piston. Push it back into the caliper. Repeat as necessary. Use a plastic tire lever to push the piston to avoid damaging it. When you get them moving the same clean up w/ isopropyl.
    I work for some bike racers
    and a bunch of skateboards
  3. #53
    Dec 2015
    You're splitting hairs with this one. A little bit of flex in the disc will not cause it to bend/warp and it wont effect braking power or pad wear. You definitely don't need to replace the caliper anyway. Could just be a bubble behind one of the pistons causing it to move a little slow. Just tap both sides of the caliper with a wrench to dislodge any bubbles and bleed it. Should only ever need to do that once unless you take the pistons out for some reason.
    Glad the resin pads fixed the squealing. Resin pads still have tons of braking power and they're plenty durable. There are extremely few exceptions that would require sintered pads.
  4. #54
    Apr 2012
    Are you guys saying most all "hydraulic" brake systems on the market will 'squeal" like this if you don't regularly maintain them? I mean, ole'd rim pads are plug and forget for something like 10k miles.
    How often is this "cleaning" and "adjusting" of them going on?
    My skepticism of "hydraulic" brakes might turn into outright hatred if you guys say this has to be performed fairly often. The only disc brakes I heard squeal were the very early versions, that were not 'hydraulic', and the squeal only happened when they either sprinted and/or braked.
    Thus I thought the "hydraulic" and "direct-mounted" brakes removed all this worry....????
  5. #55
    Apr 2017
    Quote Originally Posted by Fajita Dave View Post
    Need 10 characters.
  6. #56
    Apr 2017
    Quote Originally Posted by BelgianHammer View Post
    Not sure you read the thread.
    For my permantently squealing brakes the fix was 6€ resin pads. The pistons moving unevenly, not sure, will have to see, but havent really heard of "most all" hydraulics acting like this. Certainly plenty more than rims (less tolerance), but people with no issues rarely create threads about it. Maybe a few "never had any problems" or "haven't touched them apart from changing pads for 3 years" here and there.
    But if you want to "hate" them, go ahead, it's a free world.
  7. #57
    May 2011
    Cool. Done.
    And in response.... if you read the forums, there are plenty of regularly-encountered issues like this with disc brakes. Where are all the rim brake problem threads???
    Well, you know, that's just, like, your opinion man. - The Dude
  8. #58
    Apr 2017
    Quote Originally Posted by OldChipper View Post
    Cool. Done.
    Did you read the post you're replying to?
  9. #59
    Reputation: Srode's Avatar
    Aug 2012
    How much were you paying for the resign pads? I just bought a couple pairs of the metalic / sintered pads for $19 each, can't imagine resin pads being 1/5th of that ($4/pair).
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
  10. #60
    Apr 2017
    Oh. I got the G02A for 6€, but apparently that's a major discount, since the J04C price is down too: Bike-Components - G02A, Bike-Components - J04C
    I just remember getting them for 30€ before.
  11. #61
    Nov 2009
    Cool. Done.
    Selection bias.
    The people using rim brakes don't complain because they die from not being able to stop fast enough.
    Sent from my Moto G (5) Plus using Tapatalk
  12. #62
    Reputation: Lombard's Avatar
    May 2014
    Oh dear, I'm out of popcorn.
  13. #63
    Dec 2015
    Cool. Done.
    Perhaps roadies can't handle the extreme complexity of hydraulic disc brakes.
    Poking fun aside they are not a headache to deal with and certainly not a headache to maintain. Squealing is solved by using resin pads more often than not but if your brakes are wet they will most likely squeal. Bleeding is stupid easy with Shimano brakes on the rare occasion you actually need to. It shouldn't take more then 15mins to bleed both ends. You literally never need to clean the rotors unless you're careless and get some sort of lube on them (same as rim only they do need to be cleaned occasionally).
    There's a learning curve to any new piece of equipment. Just like learning how to adjust derailluers for the first time.
  14. #64
    ^All of this...^
  15. #65
    May 2011
    ^All of this...^
    And yet.... lots of threads on disc brake issues...
    I still maintain there’s nothing that isn’t easier/faster with rim brakes. Surely you don’t contest that CX??
  16. #66
    Rim brakes are very easy (most of them anyway) to work on. Some disc brakes are a pain, so are some rim brakes. At least you don't have to deal w/ brake fluid/mineral oil w/ rim brakes. Given the performance and other benefits of disc brakes I'd say they're worth any hassle.
  17. #67
    Nov 2009
    Except when utterly not needed for a pure road bike.
    I love my disc brakes on my mtb and gravel bikes, have had all brands over the years and have settled on Shimano.
    They are cake to operate and maintain.
  18. #68
    Jun 2008
    Quote Originally Posted by factory feel View Post
    I wish I lived where there were "pure" roads instead of these dammed long disracting climbs followed by fast twisting descents.
    It must be like heaven?
  19. #69
    Nov 2009
    Quote Originally Posted by SwiftSolo View Post
    I agree, but I don't do super long climbs all the time with return miles of steep downhills.
    On the occasion that I do a 26 mile mountain climb, I'll just take my aluminum wheeled rig.
    Over heating and boiling the brake fluid would be my only concern on a ride like that with discs.
  20. #70
    Jun 2008
    Cool. Done.
    I'm not seeing many spoon-brake threads either. I guess that's a sign that you folks have worked out the issues?
  21. #71
    Jun 2008
    Yep. That and the fact that brake fluid is a magnet for lightening strikes.
  22. #72
    May 2014
    Not a problem if you know how to apply your brakes.
  23. #73
    Nov 2009
    Yep that too, so why risk it?
  24. #74
    Nov 2009
    I generally squeeze the lever when my brain says Slow Down or you're gonna yardsale.
    Is there any other way?
  25. #75
    May 2014
    Rather than ride the brakes, operate front and rear alternately a second apart each. This will allow enough time in between applications for the discs to cool.
    That is unless you wait until you need the braking force of both and rear at the same time in order to prevent crashing. If you're that foolish, nothing is going to save you.
  1. overhauling Shimano LX Feehub
    By daniell in forum Components, Wrenching
    Last Post: 11-09-2008, 05:12 PM
  2. Overhauling Pedals
    Last Post: 04-01-2007, 06:03 PM
  3. overhauling hub (for beginner)
    By steel515 in forum Components, Wrenching
    Last Post: 08-07-2006, 07:01 PM
  4. Overhauling Mavic Ksyrium SL hubs
    By CoachRob in forum Components, Wrenching
    Last Post: 02-08-2005, 02:30 PM
  5. Overhauling advice on Dura Ace BB (Octalink)
    By NoMSG in forum Components, Wrenching
    Last Post: 12-28-2004, 09:15 AM
