Results 1 to 25 of 36
    Forever a Student
    Mar 2014
    Penile numbness and soft tissue pressure are NOT okay
    https://cyclingtips.com/2017/12/cycl...rsation-needs/
    “If you’re a rider and you’re getting numbness in your penis, switch saddles or get a bike fit and make those symptoms go away.”
    In his time in the saddle game, Dr Minkow has come across many men who have chosen to ignore numbness or pain — something he views as a big mistake.
    “Cyclists dismiss these kind of symptoms and go ‘Ah it’s just part of riding. It’s no big deal.’ And they basically tend to deny that there’s a problem,” he said. “And of course many of them do not go on to have erectile dysfunction. But what this study is starting to show is that cyclists should not deny all the symptoms. There are some that have to be taken seriously.
    “If you have certain areas of numbness, pay attention. Pay attention and be careful and do something about it. Change something, get [a bike] fit, change your saddle, change your riding style, but don’t let certain symptoms go.”
    If you’re riding a traditional saddle, switching to a saddle with a cut-out and/or stub nose is perhaps the most significant change you can make. This will ensure that your sitbones are taking the bulk of the compression forces, rather than the soft tissue in between.
    use a torque wrench
    Nov 2009
    prologo zero, my personal fav's
    Proud luddite
    Reputation: azpeterb's Avatar
    Jun 2006
    My suspicion is that penile numbness is directly related to the use of disc brakes.
    Reputation: velodog's Avatar
    Sep 2007
    Quote Originally Posted by azpeterb View Post
    Dic breaks?
    Too old to ride plastic
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    disc brakes on e-bikes.
    Happily absent RBR Member
    Reputation: Kontact's Avatar
    Apr 2011
    Too many people ignore the wrong kinds of discomfort. The damage is cumulative.
    Get off your junk.
    Darling of The Lounge
    Reputation: Retro Grouch's Avatar
    Apr 2002
    The dispensing of common sense is profound.
    Oct 2014
    I've not had any numbness issues since i switched to a seat with a wide center slot.
    I was originally on the Selle Italia SLR Gel Flow. It solved the numbness problem, but it was a little too narrow.
    I'm now on the Shimano Pro Stealth. Been on it on the trainer all winter, and now have on my winter bike.
    It's absolutely perfect (for me)!
    I make Eagles fly
    Reputation: Terrasmak's Avatar
    Jan 2015
    Just changed to a Pro saddle, night and day difference
    If you don't follow the liberal flock, you are called a troll.
    Sep 2015
    Mig,
    Nose looks wide on that thing.
    Wtw, do you know how wide that saddle is in the back?
    Schuylkill Trail Bum
    Reputation: SPlKE's Avatar
    Sep 2007
    The wide nose looks like it would make you ride bowlegged.
    Sep 2011
    I am planning to move to either this or the Specialized Power.
    The doctor mentioned above helped design the Specialized saddle:
    https://cyclingtips.com/2015/03/spec...saddle-review/
    Every climb has its end, for verily with difficulty there is relief...
    Forever a Student
    Mar 2014
    Quote Originally Posted by SPlKE View Post
    The pictured saddle is a "snub nose" saddle where the tip of the nose is missing.
    It's shorter than normal and the nose is wider than normal and designed to be used.
    I know it sounds hard to imagine, but the front of this saddle is actually supposed to be sat on, and it's actually comfortable to do so.
    The back comes in 142 and 152 widths.
    use a torque wrench
    Oct 2014
    Quote Originally Posted by Rashadabd View Post
    I tried this but found that it had more of a curve (arch? i.e the wings drop down more than the others) than the Selle Italia SLR Gel Flow or the PRO Stealth. I had some soreness in the thigh crease as a result.
    Of course as with all things fit related, YMMV.
    Sep 2011
    Good to know though, thank you for the insight. I haven't tried either yet, but plan to soon.
    Sep 2011
    Is there a saddle out there that has these qualities:
    1. a very narrow nose
    2. a dramatic transition between the nose and the part where you actually sits on, i.e., this part is where your thighs would come down.
    So far, the seat that I've found close to having the above characteristics is the Selle Italia SLR/SLS monolink version. Their traditional "rails" version (where there are 2 rails) is not as good for me since my thighs still rub against the rails too.
    anyone additinal options out there for me?
    Sep 2011
    I've heard good things about the Romin, but I haven't really tried one.
    https://www.specialized.com/us/en/ro...=220277-130722
    Apr 2011
    This is no news.
    Sep 2011
    Quote Originally Posted by Kontact View Post
    Get off your junk.
    do you guys make seats with monorail mounting instead of the traditional 2-rail mount?
    Sep 2011
    Wow $200 is expensive for a seat. But my hesitation is that they use the traditional 2-rail mount. My thighs rub against such mounting system. I prefer seats using the Monorail system, but unfortunately Monorail is proprietary to Selle Italia so there are only a few brands that use this
    Sep 2011
    Most Specialized shops offer a fit test for Specialized saddles so that you can try it out before making up your mind. There's actually a whole fit process for their saddles. There are definitely cheaper versions of the Romin as well:
    https://www.specialized.com/us/en/ro...=220152-130126
    Reputation: Veloptuous's Avatar
    Oct 2017
    I switched to the Terry Men’s FLX a few years back. The cut out in the middle helps but I think the key its ability to flex a lot between the right and left sides in the rear.
    Attached Thumbnails Attached Thumbnails Penile numbness and soft tissue pressure are NOT okay-terry-flx.jpg
    Sep 2011
    Here's a couple of reviews for the Pro Stealth:
    Pro Stealth saddle review - Cycling Weekly
    https://cyclingtips.com/2017/10/spec...arison-review/ (comparison test)
    Apr 2011
    We offer only traditional rails, and they work very well despite having a very narrow nose and abrupt transition to the back of the saddle. Probably because the rails don't continue at full width under much of the nose. I also have meaty thighs and the rails aren't an issue.
    As far as I know, only Selle Italia is doing Monolink. Even if other's are, I don't think it is ever going to catch on as a standard.
    Banned forever.....or not
    Aug 2002
    And the use of cassettes with more than 25 teeth......(and too many headset spacers)
    Dogbert.
    I>U
  1. Another soft tissue pain thread
    By Honda Guy in forum Women's Cycling+
    Last Post: 10-05-2017, 03:20 PM
  2. Soft tissue swelling - pubic bone area?
    By roadbike_moron in forum General Cycling Discussion
    Last Post: 06-01-2014, 04:23 PM
  3. Penile fractures and extramarital activities...
    By Creakyknees in forum The Lounge
    Last Post: 10-05-2011, 05:18 PM
  4. Soft Tissue irritation/warmth?
    By SolidSnake03 in forum Components, Wrenching
    Last Post: 08-26-2011, 02:17 AM
  5. soft tissue damage/inflamed lymph nodes.
    By terrasque in forum General Cycling Discussion
    Last Post: 03-16-2011, 08:06 AM
