Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 61
  1. #26
    Oct 2013
    If you leave your bike outside, in the sun, in AZ, 2 years. Otherwise....
    The British Rubber Manufacturers Association (BRMA) recommended practice, issued June, 2001, states, "BRMA members strongly recommend that unused tyres should not be put into service if they are over six years old and that all tyres should be replaced ten years from the date of their manufacture."
    Several European vehicle manufacturers of high performance sports cars, coupes and sedans identify that "under no circumstances should tires older than 6 years be used" in their vehicle owner's manual.
    BANNED
  2. #27
    tka
    tka is offline
    Jun 2014
    How does he know bicycle tires use "inexpensive" elastomer compounds? Is that all bicycle tires or "inexpensive" bicycle tires?
    What about lawn mower tires? Car tires? How about the tire on my wheel barrow? Those all look fine after 3 years. Does he replace all those too... just because?
    Sorry, I don't believe your co-worker. I've got lots of bicycle tires older than 3 years that I've got no qualms riding.
    That's the great thing about the internet - you can choose to believe what you want. I trust this chemist, and so does our business group. He and his team formulate the elastomers used in products that have sales approaching $500M annually.
    I owe you a mea culpa on my first post - it was getting late and I wasn't careful with my wording. I used inexpensive to imply cheap and unsophisticated, when the tire formulation are anything but unsophisticated and use lower-cost materials driven by the nature and use of the end product.
    He said tires and tubes don't particularly benefit from some of the additives he adds to the industrial formulations. And for most of the ones that would extend the rubber life we probably wouldn't be willing to pay for them. He estimated that the cost for one anti-oxidizing agent that the bicycle tires & tubes could benefit from the amount needed in a tire would cost more than the tire. Other anti-aging compounds would adversely affect wear, friction, or rolling resistance.
    Is 3 years too conservative? Probably, but he's a conservative guy on these matters. He has said he would probable trust 3 year old tubes more than 3 year old tires, but I know I've pulled unused 3-year old tubes out of their box and had the presta valve fall off, the joint between the valve and the tube had dried out just sitting on the shelf. More than likely poor manufacturing, but time does tend to uncover those issues as well.
    I tend to not worry about it as the tires and tubes in my bikes rarely last more than 3 years, either due to wear or damage.
    I don't know about my co-worker, but I just replaced the tire on the Porsche because they were 4 years old even though they had less than 15,000 miles on them. They were noticeably less grippy and compliant than the new tires that went on.
  3. #28
    Reputation: JCavilia's Avatar
    Sep 2005
    Quote Originally Posted by blackfrancois View Post
    you don't know what that term means or have never been around someone who suffers from it.
    my bikes don't ******* squeak. that's the sign of someone who doesn't know his **** or maybe a deaf person.
    Apologies for inadvertently poking some personal hornet's nest. I will avoid using psychological terms so loosely in the future. I was using the term not in the clinical sense, but in the informal way it is often used, to describe what the observer perceives as excessive meticulousness. Advising the OP to change his tubes to put his mind at ease, even after acknowledging that there is no functional reason for that, seemed to me (and still does) to be pointlessly over the top.
    But different strokes for different folks. I withdraw anything that may have been perceived as criticism. You ride your way, and I'll ride mine.
    Here's wishing you pleasant, quiet rides. I'm not deaf, but I do sometimes ignore the occasional squeak after satisfying myself that it doesn't indicate anything serious.
    Peace out. :-)
    Have you ever been to Electric Ladyland?
  4. #29
    Oct 2005
    Or someone who "frees his mind" by not sweating the small stuff.
    I used to be hyper picky about my bikes. That ended a year after I started working at a bike shop. Lube the chain, make sure the brakes work, check the headset.... off I go.
    Maybe it's because I come from a MTB background where bent rims and DNA shaped derailleur cages are common yet still rideable.
  5. #30
    a real member's member
    Jul 2016
    Quote Originally Posted by JCavilia View Post
    i don't think i did that.
    i only wrote that a rider should pursue what makes him more confident on the bicycle. confidence is most important to me. it allows me to bomb down a hill with traffic with a free mind.
    concerning tubes, i use them until i no longer can. usually, the valves fail first. if tubes are old, patched, but still hold air, i put them on a bike that i will flip, and buy new tubes for my keeper.
    tubes are relatively cheap, so no one should really get upset if someone feels the need to change them out every couple years. just take the old ones to you lbs, so they can be recycled.
  6. #31
    Jul 2016
    Quote Originally Posted by dir-t View Post
    I don't sweat the small stuff, because i fix the small stuff before it turns into a bigger issue.
  7. #32
    Jul 2016
    found an email today from planetcyclery.com in my promotions gmail folder for $1.99 tubes (700x25c). it read, "this weekend only." i don't know the shipping cost. i usually buy 'em on ebay for under $6 shipped.
    edit: bought 4 for $12.56 total, or $3.14/ea.
    i made sure the valves are short ~ 33mm. i hate long stems.
  8. #33
    Oct 2005
    Touche'.
    I must admit, I currently have 3 bikes that probably need new drive trains because I haven't been preemptively replacing my chains.
  9. #34
    Reputation: Lombard's Avatar
    May 2014
    2005? Has anyone here ever seen what happens to a rubber band after 12 years?
    Not sure if that applies to butyl rubber. Possibly applies to latex tubes. Hint: Latex condoms have an expiration date.
    Like others here, when my rear tire wears out, I put the front on the rear and put a brand new tire on the rear. When I take the tube out of that rear tire, the tube is pretty stuck to the inside of the tire to the point that I can't imagine I haven't done some damage getting it out.
  10. #35
    Jul 2016
    Touche'.
    I must admit, I currently have 3 bikes that probably need new drive chains because I haven't been preemptively replacing my chains.
    i'm really bad at keeping up with which chains i've replaced and when. should probably just take a pic of the bike with its new chain, so i can later check the photo's date when needed.
  11. #36
    May 2014
    Don't sweat the petty things, and don't pet the..........oh, never mind!
  12. #37
    Jul 2016
    ... when my rear tire wears out, I put the front on the rear and put a brand new tire on the rear...
    sounds like you toss both the rear tube and tire?
    i try to rotate the tires so they both wear at the same rate. then toss both at some point. but i'm not always vigilant about it.
    B^)
  13. #38
    Reputation: PJay's Avatar
    May 2004
    I was contemplating this issue several days ago.
    I was wondering whether I should throw out spare tubes once they get to a certain age.
    Rubber deteriorates with time. But I know I have had tubes in an operating bike, with occasional use, for over 4 or 5 years.
    I got to this point: since switching a perfectly good tube is an opportunity to introduce a problem, when is it worth it to switch, versus don't switch since that has its own likelihood of introducing error?
    The one thing you know about a tube that holds air - for months at least - is that it sure holds air.
  14. #39
    May 2004
    Exactly. Don't be a cheap F ker. Buy some fresh rubbers.
  15. #40
    May 2014
    Quote Originally Posted by PJay View Post
    Past performance is no guarantee of future returns.
  16. #41
    But if you haven't used it by that point you probably aren't going to need to worry about it
  17. #42
    this is almost better than the periodic "will using the stationary trainer make my bike asplode" threads
    Blows your hair back.
  18. #43
    May 2014
    Quote Originally Posted by jay strongbow View Post
    but if you haven't used it by that point you probably aren't going to need to worry about it
    lol!!
  19. #44
    Apr 2011
    I've heard that some guys wear two layers condoms for extra protection. I didn't know they are on this forum...
  20. #45
    Feb 2002
    Quote Originally Posted by tka View Post
    I work with a PhD Chemist. His job is to formulate rubber-based elastomer compounds used on several of our products. He is also a serious cyclist. He changes his tires and tubes at least every 3 years. He said his experience with formulating rubber elastomers shows that the inexpensive elastomer compounds used on bicycle tires dry-out enough in 3 years due to typical environmental factors that they should be replaced.
    He must not ride much if he doesn't wear out at least a rear tire in 3 years. I doubt he can cite a single study that might even suggest that a butyl rubber inner tube, mounted on a wheel, will deteriorate in any way in three years. Rubber doesn't "dry out," it oxidizes, and the amount of oxidation taking place inside the tire is miniscule. Your friend is either pulling your leg, trying to lord his expertise, or really doesn't understand what is going on. Ask him which it is.
  21. #46
    tka
    tka is offline
    Jun 2014
    You don't know the guy but by all means go ahead and attack him.
    I know nothing I say will convince you that he actually knows what he's talking about - a half a billion dollars in sales rides on his work - so I'll just check check out of this discussion.
    H
  22. #47
    Jul 2016
    how many bikes do you have?
    that's all i got. B^)
  23. #48
    May 2014
    OK then. Now my question is, how long will a spare tube in its box last?
  24. #49
    Feb 2002
    Depends on many factors (quality of tube, storage conditions) but 5 years is certainly not an issue in my experience.
  25. #50
    Feb 2002
    It's nice to know that "he actually knows what he's talking about." Did it ever occur to you that maybe some other people might know what they are talking about as well? Or would you say that this guy is the ONLY person who actually has any experience in rubber compounding, oxidative degradation, industrial chemistry, etc.?
  1. Preemptive statement to the annual mileage thread
    By El Scorcho in forum General Cycling Discussion
    Last Post: 12-12-2011, 07:07 PM
  2. Preemptive Strike
    By f3rg in forum The Lounge
    Last Post: 10-09-2010, 06:42 AM
  3. Preemptive Suzue overhaul? (long-ish)
    By >>ECB<< in forum Fixed/Single Speed
    Last Post: 01-04-2006, 06:41 AM
  4. Preemptive strike
    By taar44 in forum General Cycling Discussion
    Last Post: 07-28-2005, 05:48 AM
  5. Seat Tube replacement on Trek OCLV?
    By mtbdcd in forum Components, Wrenching
    Last Post: 04-12-2005, 11:38 AM
