Results 1 to 6 of 6
    Apr 2013
    Project Mountain Cycle Moho Road.
    Hello everyone! I'm from MTBR.com, and being a Mountain Cycle fan, I want to do another Mountain Cycle project.
    I'm looking for a Mountain Cycle Moho Road frame. My plans are to strip the frame and polish it. I want to make it a fixed gear/SS, using a White ENO flip/flop hub to get chain tension. I want to run a carbon disc compatible fork, probably a Trigon, to run a disc brake up front, carbon bullhorn track bars and no rear brake. So, I am here to learn as much as I can.
    One question I have is: I have two sets of vintage Cook Brothers MTB crank sets. I would like to polish one of the sets and use it for this project. Can I do that? Or, being a MTB crankset, will the chain line be messed up? I guess I can get a square taper BB in what ever size I need to get a proper chain line?
    Also, I don't know anything about road bike sizing. I'm about 5' 9" tall. What size frame should I be looking for.
    What size BB shells to road bikes typically have?
    I probably have other questions, but I don't know enough about the road side to know what I need to ask.
    Here's a picture of a Moho Road:
    Thanks,
    Shawn
    Apr 2013
    Please, don't everyone reply at once.
    Apr 2013
    Im serious!
    Get me to In&Out
    Reputation: spookyload's Avatar
    I had a Moho STS MTB years ago. Stiff as hell. The BB shell should be 68mm if it is a Mountain Cycle. Can't speak to what you will need to make a MTB crank work in it. I would assume you could get a UN-72 or UN-52 (if shimano still makes them) with a short enough axel that it should work. Nice part about the UN72 is you could add a mm spacer behind the fixed cup to move the chainline if you need too, and the non-drive side won't be totally jacked like outboard bearing BB's. As for size, I rode a medium on the hardtail I had and am 5'9" so you should be fine. I stripped the powder coat off my Moho as well. It was a pain in the a$$ to get it out of the CNC section on the rear triangle. Best solution I found was aircraft grade paint remover from the auto parts place. I am guessing you will have to Dremel the inside nooks and crannies on the rear triangle.
    Cyclists really need to learn a little Rule #5.
    Jun 2013
    i have one if you are interested
    Jul 2015
    ello
    [QUOTE=spondella;4379289]i have one if you are interested[/QUOTE
    did you still have that frame , sir ?]
  1. First 'proper' road cycle today
    By seanyboy501 in forum General Cycling Discussion
    Last Post: 08-12-2009, 09:36 AM
  2. 1st Annual Snot Cycle mountain bike race
    By c-lo in forum Cyclocross
    Last Post: 12-31-2008, 04:08 PM
  3. Cycle Cross vs Road Bike
    By LeeReno in forum General Cycling Discussion
    Last Post: 01-09-2007, 01:49 PM
  4. Specialized issues cease and desist to Mountain Cycle of Portland, OR
    By weiwentg in forum General Cycling Discussion
    Last Post: 02-04-2006, 03:24 AM
  5. Mountain bike conversion project
    By rcnute in forum Components, Wrenching
    Last Post: 01-13-2006, 12:34 PM
