Page 3 of 3 FirstFirst 123
Results 51 to 60 of 60
  1. #51
    Reputation: Wetworks's Avatar
    Aug 2012
    Quote Originally Posted by Rnk_3 View Post
    Interesting, I would say I had relief on the bike too, at least the pain never popped into my mind.
    I have seen a pelvic floor pysio a number of times but felt that was making things worse and was uncomfortable af. How long would you say it was from when you first had symptons to when you were able to ride again and be pain free after?
    My symptoms lasted the better part of a year, but I rode despite that. I was treated empirically for prostatitis, had blood flow tested (it was decreased, no surprise if I was in spasm), and went to a PT before finally getting on Elavil. I'd recommend going to a proctologist instead of pursuing the physio.
    Before I was rode the other day, my pain was just a mild discomfort. It doesn't help I sit for 8 hours a day at work. That was the only time it was sztart to hurt a little, after 6 hours or so, but the pain wouldn't linger at the end of the day. I will mention this to the doctor next time I go in. I have an ultgra sound of the perenail area on Tuesday. (I know it won't show anything but it's the steps you have to take to get anywhere)
    Thanks for the quick resonse.
    I'd wager that, much like saddles, the softer the chair you sit in the worse your symptoms? I took to sitting on a piece of wood when at the desk, actually experienced moderate relief.
    I'm not saying that there can't be PN involvement, either, but I'd almost bet your symptoms are stemming from pelvic floor spasming.
  2. #52
    Feb 2018
    Quote Originally Posted by Wetworks View Post
    Yep that is bang on. Took me a while to learn, but a couch with soft cusions that puts pressue on the perenium can case a bad fliar up for a week or two, similar to riding a bike. I bought a cusion your assets seat which has helped quite alot. I take it anywhere I may have to sit on a soft surface.
    I also have found that underware and tight clothing casues discomfort and I find I have to constantly readjust myself when wearing certain underware, does that sound familiar?
    I was riding the specialized power saddle and had it pressure mapped this summer and it was determined my pressure mapping was very good. One thing I did have the seat too high wghich may have caused the issue in ther first place.
    I then did quite a lot of reserch, and ended up purchasing the Rido R2 which is essentially a noseless saddle, with a nose.
    I got my fitter to put it on the day before I rode this week and he confirmed with the pressure mapping that the weight was 100% all on my sit bones. No pressure what so ever on any of the soft tissue areas.
    Did you do any type of pelvic floor pysio?
    Also, did you have any other symptons besides perenium pain? I don't really have any other symptons associated with pelvic floor disfuction or PN besides the dull aching perrenial pain.
    Again thank you very much for your help. Your case sound the most similar to mine that I have heard.
  3. #53
    Feb 2018
    So update, I went and purchased a recumbent (Bacchetta Carbon Aero) assuming that would solve the issue. Nope, later on in the night after the first ride, that all too familiar dull ache in my perineum returned in full force. I was stupid and bought with out trying it ( no where to try it with in hundreds and hundreds of miles) and 4 grand later, it solved nothing. I assumed the reclined position with all of my wight on my back would of solved the issue.
    Must be something with the pedal motion itself.
  4. #54
    Aug 2012
    If I am right (and I think I am) that you have pelvic floor syndrome, then a recumbent is actually going to make it worse. You really need to go back and re-read what I wrote to you. After that, pitch this the same way you did to a PT, proctologist, or urologist. Trust me, alarm bells will go off and they will treat this as what it is, pelvic floor dysfunction.
  5. #55
    I had a similar pelvic disfunction for over a year. Urologists know next to nothing about it--they treat you for "prostatitis" with drugs, when that doesn't work they call it "neuropathic pain" and have no remedies.
    I recommend a pelvic floor physiotherapist--that's what finally helped me. Also have a look at this book http://tinyurl.com/PelvicPain222 .
  6. #56
    Feb 2018
    I have an appointment set up with another PT physio in July, and with an Osteopath in a couple weeks.
    Re reading what you experienced, did the cycling flare you up bad after the fact? I know you said you experienced relief while biking, but if you had been feeling a little better, then biked, would it flare it up?
    Since my ride last Thursday I have been aching bad, especially while sleeping. It's slowly improving, but every time I bike it is back to square one. I guess I have to give it up for a period longer than 5 months like I did
  7. #57
    Feb 2018
    Quote Originally Posted by Ken2 View Post
    I actually read headache in the pelvis and have been doing some of the stretches, though I am not sure how much they are helping.
    What were your symptoms? My only symptom is an ache in the centre of perineum, somewhere in the prostate area. It gets a little better if I don't cycle and try avoiding to sit as much as possible, but easily gets flared and anytime I cycle it is back to square one.
  8. #58
    Pelvic floor dysfunction
    I had perineal pain as you describe, also tip of penis pain. Worse when sitting, in fact I got a standing desk for work because I couldn't concentrate through the pain while sitting. Also got a portable laptop stand so I could lie down and work in bed http://tinyurl.com/LaptopStand11 .
    Like WetWorks, I found some (relative) relief cycling, but only on a noseless saddle like the Hobson. My theory was likewise, that cycling improved circulation some, but it was still far from comfortable, and it was impossible with standard saddles.
    I tried biofeedback, acupuncture, meditating, and exercises after I came to understand that I had pelvic floor spasms/dysfunction. What helped me most was a pelvic floor physical therapist, whom I saw weekly for about a year. If you are located in or near a large metropolitan area you are more likely to find someone who knows what they are doing.
    Also there are seatpads with cutouts for the tailbone area that I found gave me relief when I had to sit, like when driving. Still use one in my car.
  9. #59
    Aug 2012
    It would eventually revert to baseline post-ride, but it wouldn't worsen, no. Ken kind of touched on the reason for improvement during riding; increased blood flow. But that's not how I'd explain it as it obscures the mechanism, which is at the heart of the matter IMO.
    Everyone is going to experience decreased circulation when sitting on a saddle for an extended period of time. The problem for us is we are starting off that process already at less than optimal circulation. So why the improvement? I believe it has to do with sympathetic and parasympathetic parts of the pelvic floor, particularly the external anal sphincter. If you tend to be an internalizing person, there's a good chance you are clenching your external sphincter without even realizing it. A good test is to go sit on the bowl and have a BM. I would wager most people experience immediate relief, followed by a gradual return of symptoms within 30 minutes.
    So, when sitting on a saddle, your mind is concerned more with sympathetic responses, so the parasympathetic nervous system is taking a back seat with decreased motility, increased contraction of the INTERNAL anal sphincter, while the sympathetic nerves are doing their job of keeping you in motion on the bike, looking out for obstacles, etc. The EXTERNAL sphincter, which as opposed to the internal, is innervated by the pudendal nerve, gets a bit of a break due to the anatomical position assumed when sitting on the saddle along with some (possible) partial relaxation of sympathetic external rectal tone.
    So, that's my THEORY as to why I and others may experience relief. And like Ken said, urologists and other MDs are clueless, especially when you lead with "I feel better sitting on a narrow, hard bike saddle." Of course, I could just be talking out of my @$$...
  10. #60
    Reputation: Fredrico's Avatar
    Jun 2002
    Good points.
    I can remember years ago when ramping up fitness, the pelvic floor would tighten up severely when pedaling hard, internal sphincters indeed, and when I rested up after the ride, it would hurt like a bruise. It subsided overnight with slight sensitivity the next day. Learning how to spin solved that problem. I did do some purposeful pedaling up hills careful to keep the power in the legs. The anal muscles still go isometric, but after some training, no longer over-tighten in sympathy with the legs. Definitely something to think about.
  1. Pudendal Nerve discomfort
    By siclmn in forum General Cycling Discussion
    Last Post: 03-28-2014, 06:06 PM
  2. Pudendal nerve Problems
    By tonybaloni in forum General Cycling Discussion
    Last Post: 09-10-2013, 05:41 PM
  3. DGAD syndrome
    By Lotophage in forum The Lounge
    Last Post: 03-08-2012, 12:03 PM
  4. ITB syndrome
    By heffergm in forum General Cycling Discussion
    Last Post: 08-22-2010, 01:04 PM
  5. the fail syndrome
    By asciibaron in forum The Lounge
    Last Post: 05-06-2010, 03:06 AM
