Page 1 of 6 123 ... LastLast
Results 1 to 25 of 133
    Jun 2011
    Pulling up on the pedals
    There seems to be some debate as to the effectiveness of pulling up on the pedals.
    From the riding I've done so far (which isn't that much, only 700 or so miles this year), I've found that pulling up on the pedals is a great way to temporarily alleviate the lactic acid buildup in the thighs.
    I also don't like how it seems to be an all or nothing debate. Yes, your legs are already balanced by the weight of the other leg. However, pulling up in a way that doesn't actually strain that lower abdominal group very much seems to be far more effective than trying to lift the weight of your leg every time.
    Also, most of the power is already coming from the thigh in that part of the pedal stroke. So, again, it seems more like a way to temporarily alleviate the thighs rather than as a way to improve efficiency for a long period of time.
    Also, as far as pulling back and pushing forward in the spin: I feel like it's best to try to maintain momentum, and you will lose a very slight amount when the pedals are in a vertical position if you are not spinning.
    But I also feel like putting too much effort into this small part of the pedal stroke will also run you out of gas early. So, my sense with this is to pull back and push forward slightly on this part as to maintain momentum a little bit, but using all of these muscle groups intensely seems to waste energy.
    All you're doing in any of these movements is balancing forces on the crank arms. The weight of your legs is already balanced, but there are still a number of factors to consider.
    Thoughts? I'd love to hear more opinions on this, as well as some more solid research as well as what the actual current status quo is amongst the top riders in terms of pedaling technique.
    Where's that GPS?
    Reputation: LostViking's Avatar
    Jul 2008
    No science here to back this up - just my impression - I have a smoother cadance and go faster when I pull-up as well.
    Ask a Pro - or even an almost Pro - they must make a science out of getting the most bang-for-the-buck and endurance out of thier pedal stroke. It is after all the key contact point as well as the point where your body's energy becomes forward momentum.
    Hard to say when it comes to endurance - did you have a bad day because you pulled up on your stroke or would you have had a bad day anyway?
    I'm interested to see what everybodyelse thinks about this.
    1980's - Centurion
    1990's - Peugeot
    2000's - Specialized
    2010's - Bianchi
    ''This story was so perfect for so long. It's this myth, this perfect story, and it wasn't true.'' - Lance Armstrong
    Sep 2011
    I only purposely and intently employ the pulling-up technique when
    1) I'm riding tempo by myself and in zone3 heart rate. This allows me to pull the pedals in a controlled way. Once my heart start to race and I'm hammering, I can't pull, then it becomes mostly mashing.
    2) I'm riding in a group and I'm drafting someone. In this case, I sit and pull and spin.. conserving energy. Cadence is usually high. You can't pull up on low cadence or else your cleats might just pop out.
    3) on climbing, I've tried pulling but sometimes this cause my rear wheel to hop. It's probably my bad technique as I tend to "jump up" on the pedals during the pull stroke.
    All in all, I find pulling to be most effectively employed when sitting in the draft of a group and spinning at a high cadance (100+ rpm).
    Apr 2003
    Quote Originally Posted by Alkan View Post
    The only debate is between those who've seen and understood the data and those who haven't or choose to ignore it. If the goal is to go fast, push down as hard as you can on the pedals at whatever cadence feels best to you and don't worry about the rest.
    I'm pretty sure Hunter Allen and Stephen Cheung go over the research on this in Cutting-Edge Cycling: Hunter Allen, Stephen Cheung: 9780736091091: Amazon.com: Books
    Apr 2003
    You might be conserving something, but it sure ain't energy. The power to propel the bike doesn't depend on cadence so there's no saving there. Then since humans are most efficient at cadences between 60-70 rpm, if anything, a higher cadence means consuming more calories for the same work at the pedals.
    Feb 2002
    Actually, there isn't. The data show that experienced professionals push down and nobody pulls up. Stronger riders push down harder. Simple as that. If you are learning to spin smoothly and think of "pedaling circles" that is improving your style. The only time you can successfully pull up is at low cadence which should only be taking place when climbing and then you can only sustain pulling up for a very short period of time.
    Arguments among misinformed people do not constitute a "debate."
    Target
    Reputation: bigbill's Avatar
    Feb 2005
    Efficiency is about relaxing the leg that's not pushing down.
    Retired sailor
    'brifter' is a lame word.
    if you're pulling up on the pedals you're doing it wrong. plain and simple. NO racers pull up on the pedals. don't take this the wrong way, but the only people that do are the ones that don't know any better.
    2012 Trek Cronus Ultimate w/ SRAM Red Black
    2010 Cervelo T1 sprint bike
    2011 Cervelo P2 pursuit bike
    FMF 24" cruiser
    Bianchi Pista road fixed gear
    1949 Columbia 26" cruiser w/ SRM & fenders...and rust
    '05 Suzuki DRZ400SM
    Reputation: redondoaveb's Avatar
    Jan 2011
    I don't think Kerry, bigbill or cx could have said it any better. That sums it all up. The only time I ever remotely feel like I'm pulling up is climbing and at a low cadence.
    If you try to fail, and succeed, which have you done?
    Jun 2011
    Yeah, this is actually pretty much exactly when I do it and what comes naturally to me: while climbing and momentarily to relieve lactic acid buildup in the thighs without wasting the energy of getting out of the saddle.
    Otherwise, yes, it completely feels like a waste.
    Reputation: Ventruck's Avatar
    Mar 2009
    How slow can you be pedaling to start noticing a reduction in lactic acid build up? My word.
    Apr 2011
    I'm a puller-upper.
    But the only time I do that is when I'm stopped. With my right foot planted on the pavement, I pull my left foot to about 1 o'clock.
    I'm pretty unclear as to how you "Puller-uppers" do that, but if it works for you, great. Just seems a little difficult.
    Thread: Non-scientific study on roadie waving today...
    How original. n00b. robdamanii
    Thread: Back spasms after long ride
    Clueless as usual. What are your medical credentials again?
    robdamanii
    Aug 2010
    Many cycling book I've read says concentrate on the 3 o'clock to 9 o'clock position of the stroke. The best way to describe it is pretend to scrape mud off the bottom of your shoe. This will give you a power stroke that helps you do a proper circular motion.
    When I concentrate on this stroke, I gain 1 or 2 mph without even thinking about it.
    "pulling up" is what I hear from spinning instructors who don't actually ride outside.
    Nov 2012
    Show the data please.
    Apr 2003
    Quote Originally Posted by SauronHimself View Post
    You'll just have to buy (or borrow) the book.
    Quote Originally Posted by asgelle View Post
    Nov 2012
    The truth should be told and not sold.
    Jun 2011
    Quote Originally Posted by Ventruck View Post
    When it helps me accelerate to spin faster and use my thighs less.
    It helps. Maybe when I'm in better shape I won't see a need.
    Reputation: velodog's Avatar
    Sep 2007
    Which rule is this?
    Apr 2010
    Capmal S and Vandewalle H, “Torque-velocity relationship during cycle ergometer sprints with and without toe clips”, European Journal of Applied Physiology. 76: 375-379, 1997
    Coyle EF, Feltner ME, Kautz SA, Hamilton Mt, Montain SJ, Naylor AM, Abraham LD and Petrek GW, “Physiological and biomechanical factors associated with elite endurance cycling performance”, Medicine and Science in Sports and Exercise. Vol 23 No 1: 93 – 107, 1990
    Jorge M and Hull M “Analysis of EMG measurements during bicycle pedaling”, Journal of Biomechanics. 19: 683-694, 1986
    Ting LH, Kautz SA, Brown DA and Zajac FE, “Contralateral movement and extensor force generation alter flexion phase muscle coordination in pedalling”, Journal of Neurobiology. 83 (6): 3351-65, 2000.
    Or did you mean summarize the research and hand feed it to you?
    trust me, we speak the truth. one more time...
    if you're pulling UP on the pedals, you're doing it wrong.
    end of story.
    FMF 24" cruiser
    '05 Suzuki DRZ400SM
    Jun 2011
    You know what? Now that I think of it, I may have been pulling up because my bike wasn't fitted right.
    I just fit my bike far more properly last night and am doing hill repeats today.
    I will get back to you on that. I've heard that being too far behind makes pulling up more comfortable.
    Nov 2012
    Quote Originally Posted by skinewmexico View Post
    No, I meant the data and not your pointless condescension. The standard I'm trying to hold is simply that one supplies evidence when they make an assertion (i.e. "The data shows..."). I'd rather view the sources myself, because hearing someone else's interpretation of the data is a marginal improvement over someone making an assertion without any supplementary evidence.
    Nov 2012
    end of story.
    That's not begging the question at all...
    it's rather easy to see how little it helps to pull in the pedals.
    Try cycling only doing that.
    Blows your hair back.
    Sep 2007
    Quote Originally Posted by den bakker View Post
    The source don't get no better than this.
