Results 1 to 5 of 5
    Apr 2013
    real wheel is sticking and freewheel does not spin
    Ok, hi, Im new at this, I bought my son a new bike (Huffy Rival, 21 speed), at Target. The rear wheel does not spin freely. If I hold the bike up and spin the rear wheel in the same direction it would spin if riding normally, it rapidly comes to a stop. Brakes are not rubbing, rim is true, tire is not flat, and there's nothing I can see caught in the hub, axle or freewheel.
    Also, The freewheel does not seem to spin freely on the rear axle. If I'm riding forward and stop pedalling, or even just pedal a bit more slowly than required to match the speed of the bike, the chain droops almost to the point at which it begins falling off the front chainring. A hand inspection showed that the freewheel keeps rotating forward even when coasting, and this forces the chain to keep moving forward, drooping against the stopped front chainring.
    LIke I said, I'm new at this, I copied almost all the names of parts and the first paragraphs from someone elses post, but it matches my problem almost word for word.
    Any ideas on what might be causing this?
    fu
    Reputation: ph0enix's Avatar
    Aug 2009
    Why not return the bike to Target and get a working replacement (assuming it's new)?
    My other chainring is a 39...
    Strava profile
    Dr. Flats a lot
    Reputation: zoikz's Avatar
    Sep 2003
    It's either a defect or the bike wasn't set up properly. Seems like it's coming from the hub or freewheel. Target should fix it for you.
    Feb 2002
    Quote Originally Posted by ggonzalez435 View Post
    Excess friction in the freehub (it's very unlikely it's a freewheel). This could be a lubrication problem or it might go away as things "wear in" but it is not something you should be experiencing with a new bike. As the others have suggested, take it back to Target and test a few other bikes to find one that doesn't do this.
    wim
    wim is offline
    Feb 2005
    Check and see if a protrusion from a warped spoke protector is making contact with the back of the freewheel.
    I've also seen freewheels come apart on almost new department store bikes, so there is a good chance that it is defective freewheel. As everyone said, take it back and complain about your unsafe-to-ride bike. Don't even try to advance a theory of why the thing doesn't work. No one at Target will have the slightest idea of what you're talking about.
  1. Sticking, skipping freewheel pawls?
    By Gnarly 928 in forum Wheels and Tires
    Last Post: 08-01-2011, 02:15 PM
  2. sticking things in the back wheel?
    By daivs_T in forum Fixed/Single Speed
    Last Post: 06-24-2009, 10:16 PM
  3. Brake pad sticking to Zipp wheel
    By davgus in forum Wheels and Tires
    Last Post: 09-13-2008, 11:47 AM
  4. Wheel won't freewheel
    By stlutz in forum Components, Wrenching
    Last Post: 01-06-2008, 09:26 PM
  5. Sticking fork/wheel
    By carbonfreak in forum Components, Wrenching
    Last Post: 01-24-2005, 05:55 PM
