Results 1 to 9 of 9
    Jun 2013
    Schwalbe Marathon plus tires
    I just put my first set of Schwalbe's on my bike. I was told they would be a bear to mount. I was struggling with getting sides of the tire bead to seat on the rim without pinching the tube. I needed about 4 more hands. Then it dawned on me, being a teacher, if I could get both sides of the tire bead to seat and stay in place, in small areas, I could work my way around the tire. So what could I use to hold it place - masking tape! It worked like a charm.
    Start near the valve.
    Make sure there is some air in the tube.
    Get one side on rim as you would with any tire.
    Starting near the valve seat about a 4" to 6" section.
    Wrap around the tire and rim with 1" masking tape to hold in place.
    Seat the next section, 10" or so and repeat until you get around the rim.
    When you get near the end, because you can make sure the tube is in place as you go....just insert your tire iron and get the last part over the rim.
    Mar 2010
    The good thing about these is that you only have to replace them about once every 10 years.
    Reputation: PlatyPius's Avatar
    Feb 2009
    Re: Schwalbe Marathon plus tires
    I've installed several Marathon Plus tires over the years, and I've never had to resort to taping. In fact, I've always found them to be very easy to install; especially compared to Gatorskins.
    Other countries need to stop hatin' or we'll unfriend them. - Christine
    Apparently I left my reading comprehension glasses in my ass. - DrRoebuck
    Still, it felt great and I felt like I was sitting on some kind of vibrator -Touch0Gray
    Jan 2002
    OP - what does being a teacher have to do with it?
    PlatyPius - I've found Gatorskins to be very easy to install - never need to use tire irons.
    Insert something clever here:
    Insert list of every bike I own here:
    Feb 2009
    Quote Originally Posted by AlanE View Post
    You're lucky and have decent rims, then. Try installing them on some Bontrager wheels sometime.
    Like you, I'm trying to figure out what being a teacher has to do with making a simple process much more complex than it is or needs to be. I can't even imagine what would make someone think that taping a tire to a rim is needed or is an inventive way to install a tire. My mind is boggled.
    Lost in Space...
    Reputation: headloss's Avatar
    Mar 2013
    Never used tape... I usually throw the tire out in the sun for a few hours and then saturate it with talcum powder before mounting. I usually need to use a lever for the final bit.
    Reputation: velodog's Avatar
    Sep 2007
    Quote Originally Posted by PlatyPius View Post
    Didn't you ever go to school...
    That's what a teacher does.
    Reputation: mmlee's Avatar
    Apr 2012
    I have a set on my wet weather bike and love the traction and durability. I have them installed on some mavic ksyrium's. I was expecting a fight to get them on but it turned out to only require and little extra effort. In fact I've even rotated the tires on a cold winter morning without too much hassle.
    Bianchi - Infinito - 2012 - Ultegra 6700 Group w/ Fulcrum Racing Zero wheelset
    Boobies!
    Reputation: paredown's Avatar
    Oct 2006
    I put a set of Marathons on, and found them to be a complete bear although I forget what the rims were--and if tape gets them on easier, congratulations...
    If Platy found them easier than Gatorskins--there's a tire I'll avoid--just sayin...
    "There are two novels that can change a bookish fourteen-year old’s life: The Lord of the Rings and Atlas Shrugged. One is a childish fantasy that often engenders a lifelong obsession with its unbelievable heroes, leading to an emotionally stunted, socially crippled adulthood, unable to deal with the real world. The other, of course, involves orcs."
    John Rogers
  1. Mounting Schwalbe Marathon Plus
    By voodooguy in forum Wheels and Tires
    Last Post: 08-21-2011, 05:18 PM
  2. where to buy schwalbe marathon extremes?
    By andy13 in forum Wheels and Tires
    Last Post: 01-21-2011, 07:54 AM
  3. Anyone used Schwalbe Marathon Supreme tires yet?
    By Dave Hickey in forum Commuting, Touring and Ride Reports
    Last Post: 07-09-2008, 08:24 PM
  4. Schwalbe Marathon Plus - For century?
    By CBar in forum Wheels and Tires
    Last Post: 07-19-2007, 06:46 AM
  5. Schwalbe Marathon Plus Tires
    By B2 in forum Commuting, Touring and Ride Reports
    Last Post: 02-08-2007, 08:16 AM
