Results 1 to 22 of 22
    Nov 2009
    Are Seat Post clamps often overlooked ?
    When installing a seat post clamp, is there a proper way to align the slot? Does it matter if the frame is carbon?
    Does it matter if the frame is aluminum? How about a Carbon post, would that change anything?
    Most of what I can find states to put the clamp slot 180 degrees from the frame slot, for carbon frames.
    Aluminum frames I'm not sure if it matters.
    Is the rule always to have clamp slot 180 from frame slot no matter the frame material?
    Anyone know ?
    Nov 2014
    My carbon frame has slots front and rear, so can't do 180.
    Anyway, I put mine facing the front because...I saw it like that on a pro bike...
    Dec 2006
    Quote Originally Posted by factory feel View Post
    When installing a seat post clamp, is there a proper way to align the slot? If the seatpost is metal, the clamp's slot position does not matter.
    It's been suggested to position the clamp slot 180 degrees opposite the seat tube slot for carbon seatpost equipped bikes to minimize the clamp scoring the carbon post.
    Only if the seatpost is carbon. It's all about preventing the potential to gouge the carbon seatpost with the clamp, and if the frame is metal, then the frame's slot can damage the carbon post as well. Positioning the seat clamp out of phase with the frame minimizes this problem.
    See above.
    It only matters if the SEATPOST is carbon. Anything else shouldn't be an issue.
    Nov 2009
    From Thomson website....
    If the Thomson Seatpost Collar is used with a carbon fiber frame or with a carbon
    fiber seatpost, or both, orient slot in the seatpost collar 180º away from slot in
    frame.
    Nov 2014
    Some of the Bianchis have Miche clamps which have 2 settings, one for a CF post and the other for alloy. That said, these clamps pretty much open at the rear where the slot in the CF seat tube is.
    Sep 2011
    what's the idea behind orienting the collar's slot 180 degress away from the seattube's slot? Is it to minimize the cracking of the seatpost in case you over tighten the clamp?
    When I orient the collar in such fashion, I find that I need more torque on the collar to hold the seatpost down.
    Nov 2014
    The theory is that most clamps open towards the back ,and therefore combine with the "split" in the seat tube at the back to add additional force to the split area grabbing onto the CF post. Not a problem with an alloy post, but with CF the thought is that reversing it so that the tightening force is in front of the seat tube, there will not be exaggerated force on the area of the seat tube slot.
    Of course, there may be some Physics majors here that can dispute all of that theory.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Yes. If you align the slots, when you compress the clamp, the edges can push on the slot and put increased stress at a focused area.
    Even if you just rotate it a little, it's better.
    Sep 2011
    the theory about putting stress on the edges makes sense
    Nov 2009
    I just turned all mine 180 degrees.
    Reputation: OldZaskar's Avatar
    Jul 2009
    I have been doing this incorrectly for 45 years - on steel, aluminum and carbon frames. Yet, it has made absolutely no difference. That said, I'll spin the ones that spin.
    Nov 2014
    Funny that when you look at all the photos of CF frames using CF seatposts, all of them show the clamp facing rearward. Colnagos, Bianchis. etc.Many of these do use the Miche clamp with the dual settings.
    Why aren't they selling the bicycle with the clamp turned 180d?
    Reputation: 11spd's Avatar
    Sep 2015
    Quote Originally Posted by Peter P. View Post
    Wrong
    Sep 2015
    Yes it does but also aligning the relief of the clamp with slot whereby the seat tube slot edges don't touch is a viable practice as well.
    Sep 2015
    Quote Originally Posted by GKSki View Post
    Principle reason of course that the slot exists in the seat tube and relief in the seat clamp is to allow for reduction in diameter for clamping. If there is uneven clamping i.e. one edge of the seat tube slot pushed into either a carbon or alloy seat post, this may in fact help retain it because it creates a stress riser but it can score the seat post and degrade the seat tube. Best the slot edge is either avoided completely...or...the slot is completely covered by the clamp. Either or will work fine.
    Nov 2009
    Quote Originally Posted by 11spd View Post
    I used to do it like this until I researched it. Now I put them all at 180 from seat tube slot
    Sep 2015
    Put them all back. Then, tomorrow, reverse order and repeat.
    Nov 2009
    Nope, not gonna do it. They’re staying. It makes perfect sense now.
    Even aluminum on aluminum are gonna be 180 now.
    I’ve seen the light !
    Feb 2002
    I don't have a fancy clamp like that one, so I just offset mine so that the slot in the clamp doesn't line up with the slot in the seat tube. I can't see any reason wy 180 degrees rotation is functionally any different than a slight rotation of the clamp.
    Sep 2015
    Symmetry and harmony of the universe are the reasons. Go against this grain and you affect your karma.
    Nov 2009
    Oh my, a troll who doesn't know the difference between your and you're. What will they think of next?
  1. Replies: 67
    Last Post: 11-07-2015, 10:34 PM
  2. Poor quality seat clamps FM099 - R041 - FM098 ??
    By Ricey155 in forum Bikes, Frames and Forks
    Last Post: 10-31-2014, 01:08 AM
  3. Replies: 0
    Last Post: 11-12-2010, 11:38 AM
  4. Carbon frames and seat clamps
    By saga in forum Beginner's Corner
    Last Post: 06-12-2009, 05:47 PM
  5. Favorite overlooked albums?
    By Live Steam in forum The Lounge
    Last Post: 01-10-2005, 03:32 PM
