Results 1 to 25 of 25
    Sep 2016
    Seat Post question
    General question but relatively hard to look up, so decided to post. When riding, I have found that some slightly wider seats give me additional lever point when I try to get a lot of power in. I push with hamstring against wide part of seat on each side and feel extra watts. Is there a technique that validates that or am I just making it up? Also any seat that helps in that without trade-offs. I am heavy rider and work hard on hills, so might affect the experience.
    Apr 2011
    Quote Originally Posted by jsoeph View Post
    Measurement of watts would validate what you felt.
    Seat help would be in comfort aspect. Better bike fit and training would help in performance aspect.
    Dec 2005
    I always learned while riding (30+ years ago, mind you) that if you shift back on your saddle, you'll have more 'torque' to ride up hills in a larger gear, albeit at a lower cadence. Perhaps a similar effect to having a longer crankarm, although I'm sure I'm over-simplifying things and someone will undoubtedly correct me. Could the wider saddle be enabling you to shift back a bit? I do tend to scoot back on my saddle sometimes on steeper climbs. As bvber said, a PM would give you the ultimate answer.
    Reputation: Fredrico's Avatar
    Jun 2002
    Quote Originally Posted by bvber View Post
    Add to that saddle set back.
    If forward, the hamstrings easily come into play. They're in a better position to assist scrolling through the bottom of the stroke. That's why you see racers "on the rivet," working off the nose of the saddle in sprints, and why track bikes have steep seat tube angles. Developing high watts at fast cadences comes naturally when rider is "on top of the crank."
    If saddle is set way back, the quads have more room to push down, which is great for low cadence climbing as Ogre points out. But the hamstrings have more stretch to overcome unweighting the upstroke and moving the leg over the top ready to deliver power on the downstroke.
    I wouldn't change the saddle if you're getting the support you want. If it cuts into your legs, move forward on it.
    Not sure I understand exactly what you mean but you can also generate more power by standing (most likely). But road cycling is 99% about stamina and 1% about doing what you need to do for short term power needs.
    If you're generating more watts you're spending more watts you won't have later. If this works for you on an 'as needed' basis that's great. But if pushing against the saddle feels like it's giving you more power I wouldn't jump to the conclusion you've discovered a revolutionary pedaling style that's sustainable and makes sense as a way to ride.
    Russian Troll Farmer
    Sep 2016
    So.....what exactly do watts feel like? I've experienced volts before, and it's not pleasant!
    "L'enfer, c'est les autres"
    Cycling Addict
    Nov 2013
    See if you can find video footage of Bernard Hinault climbing a grand col. He was a master of the technique of sliding back in the saddle and pushing a big gear on a tough climb.
    I used to emulate that, but then my knees didn't like it. Come to think of it... he had some knee problems during his career, didn't he?
    Life is short... enjoy the ride.
    Reputation: BCSaltchucker's Avatar
    Jul 2011
    if you've felt volts, then you've felt watts. said one smartalec to another smartalec
    Faith is pretending to know things you don't know
    Apr 2011
    I wouldn't mind watts.
    Apr 2012
    bvber!
    No fair.
    Forum foul! You're in the penalty box as now I can't remember what I was going to write
    Reputation: velodog's Avatar
    Sep 2007
    Quote Originally Posted by BelgianHammer View Post
    bvber!
    No fair.
    Nothin' like a good distraction.
    Too old to ride plastic
    a real member's member
    Jul 2016
    even at age 49, i'll take some of that naomi.
    Sep 2016
    Quote Originally Posted by BCSaltchucker View Post
    If I remember my circuitry class (as well as physics), W=V*A, so technically, if you feel a volt, it's actually a watt over an amp...
    Oct 2005
    Post
    I know what you mean somewhat when you say you push with the wide part of the seat [saddle] when climbing. I've experienced that too, but I don't know if you're feeling "more watts" or just experiencing more thoughtful pedal strokes while climbing...lower cadence, the mental game of climbing, etc... The voices in my head get louder when I'm focused on a harder climb.
    By all sorts of conventional wisdom (and bike fitters) my saddle has probably always been a bit too far forward. Has it hurt my power output? Who knows. I came along too late to care about or afford/have a use for power meters.
    The one and only thing I do know for certain after 20+ years of riding as an adult is that there seems to be a direct correlation (for me, at least) between comfort and perceived power. Stated differently, after fit sessions in my younger, crit-focused years, fitters of all stripes always wanted to put me in a position that was notably different than what I was accustomed to. Out of respect for the craft, I gave their recommendations a chance, but always drifted back to what worked - for me. Frame after frame, year after year, my position has been pretty consistent when I do it "my way". I'm fast enough, but more importantly...comfortable.
    Being uncomfortable just plain sucks. I don't, and have never made a dime riding a bike. I do what works. That's what I recommend to just about anybody these days. If it feels good to you, and your buddies aren't riding you off their wheel on a regular basis, do it...Naomi Watts notwithstanding...
    Reputation: Lombard's Avatar
    May 2014
    And considering the human body has a fairly high internal resistance of around 100kOhms or more, you become the voltage divider. And given a high enough current, a very stiff voltage divider.
    Aug 2013
    I know what you are talking about, but I have only pedaled like this for a short while when out of steam and trying to grind out the last bit of a long climb. I found I was trying to find any other muscle groups to use that weren't as exhausted.
    Sep 2016
    I remember an electrician once told me the 1st law of electricity:
    "It's not the voltage that'll kill you, it's the current".
    Jun 2015
    "It's the volts that jolts, but the mills that kills."
    May 2014
    This is true, but misleading. You can't have current without potential.
    I believe it is accepted that 5mA flowing through the human body can kill an adult, less if you have a heart condition. In the US, grid voltage is 120Vac. Divide that by 100kOhms and that would be 1.2mA going through your brain and your heart. Unlikely to kill a healthy adult, but you would still get a nasty rap.
    The way I explain it to non-electrical people is to think of it in terms of water pressure vs. flow. You can't have flow without pressure.
    And now that we've totally derailed this thread................
    Apr 2011
    Then what is voltage equivalent in plumbing term?
    Yup, we sure did, a thread titled Seat Post question with question about saddle and pedaling technique.
    Didn't Gordon Gekko (in movie Wall Street) say something like it's derailed because it's derailable?
    May 2014
    Voltage would be like water pressure.
    Current (amps) would be like water flow.
    Power (watts) would be like both.
    You need both water pressure and flow to get water, right?
    Well, you need both voltage and current to get power.
    Sep 2007
    It can be fixed...
    May 2014
    It can be fixed...
    No it can't.......
    jkc
    jkc is offline
    Jun 2014
    Sep 2007
    No it can't.......
    Oh yeah, it can. They make tools for that, and they ain't a pair of needle nose pliers and a pipe wrench.
  1. Replies: 1
    Last Post: 07-18-2010, 02:48 PM
  2. seat post question (x-post from retro forum)
    By seeborough in forum Fixed/Single Speed
    Last Post: 12-03-2007, 03:46 AM
  3. How much seat post extended is too much seat post
    By climbin'junkie in forum Components, Wrenching
    Last Post: 05-31-2006, 03:53 AM
  4. How much seat post in the seat tube is enough?
    By Vinokourov in forum Components, Wrenching
    Last Post: 10-11-2005, 12:36 PM
  5. Cordura seat bags and carbon seat post (potential) issue
    By Lt. in forum General Cycling Discussion
    Last Post: 08-06-2005, 12:18 PM
