Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 72
  1. #26
    Nov 2009
    my first attempt with the 40t cassette with a long cage on the 105 derailleur. Worked beautifully except in the big/small combo when letting off the pedaling quickly then the chain slapped badly...
  2. #27
    Nov 2009
    my second attempt to run the 40t, now with a long cage xt derailleur and the tanpan. works good so far. the clutch helps a lot with chain slap.
  3. #28
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by factory feel View Post
    Note the difference in cage length and derailleur geometry. Even with a clutch, the 105 would not have worked well.
  4. #29
    Nov 2009
    that particular pic may have been before I swapped the cage with a longer one.
    it really did shift nicely. note; the only issue I had was in the 11 tooth, the other cogs seemed to pull enough tension to eleminate the harsh chain slap.
    I removed a link from the chain but almost went big big when I was tired and woulda ripped off my derailleur.
    here is a pic of the 105 that definitely has the longer cage..
  5. #30
    Oct 2014
    There are certainly use cases for a clutched derailluer on a road bike, however, probably not enough to warrant adding the feature to the U-8000 system (or Dura Ace for that matter). For those rare situations where someone might actually *need* a clutch (like yours), there are other solutions out there (like yours), including a Di2 setup with an XT rear derailluer.
  6. #31
    Nov 2009
    this is something I want to investigate for a bike i have with ultegra 10s di2.
    I want a stronger spring for the derailler because I'm running an xt 11-36 cassette on it with the road link.
    I haven't ridden it yet to see if chain slack will be an issue though.
  7. #32
    Forever a Student
    Mar 2014
    The XT derailleur not only has a longer cage (total chain wrap capacity) than the longest (mid-cage) Shimano road derailleurs, but the geometry of the derailleur is different as well.
    So this is why even with the long mountain bike cage, the road derailleur will have problems. A clutch will not change this.
    If the XT works, no reason to change it.
    The shadow design now on DA and Ultegra is more than just the inward position. The second design feature of this is that the guide jockey wheel has more consistent spacing to the cogs across the range of the cassette vs. road designs.
    So the geometry advantage of the XT is now also on r9100 and r8000.
    But if the clutch is what you want, the XT is basically a clutched r8000 now right?
    use a torque wrench
  8. #33
    Nov 2009
    hmmmm....not sure the pull ratios are the same.
  9. #34
    Oct 2014
    On one of shimano's tech videos they said they are. The only caveat they mentioned regarding backwards compatibility was, as MMs said, you should match the new front mech to the new front crank for optimal front shifting.
    Sent from my Pixel using Tapatalk
  10. #35
    Jun 2014
    AKAIK, you can't mix 11-speed road shifters with mountain rear derailleurs in mechanical (Di2 is ok). Different pull ratios.
    https://www.cxmagazine.com/shimano-x...ible-questions
    That's why the Tapan (shown above) is needed/useful.
    https://www.wolftoothcomponents.com/...roducts/tanpan
  11. #36
    May 2014
    Let's see:
    Shimano changed the shifter pull ratios of their mountain groupos when they went to 10-speed.
    Shimano changed the shifter pull ratios of their road groupos when they went to 11-speed.
    You are using an XT (mountain) rear derailleur and 105 (road) shifters and they shift correctly. Right?
    It appears to me they are compatible, unless pull ratios were changed again with the 8000/9100.
  12. #37
    Jun 2014
    Let's see:
    Just because they changed does not mean they changed to be the same. It is possible, but not what happened in this instance.
    You missed the most important part from his post that proves your assumption wrong.
    "my second attempt to run the 40t, now with a long cage xt derailleur and the tanpan. works good so far. the clutch helps a lot with chain slap." (Look at his pic and see the Tapan attached to the derailleur where the cable enters)
    The Tapan is needed to correct for the difference in the pull ratios. See my link above in post #35.
  13. #38
    May 2014
    Quote Originally Posted by Chader09 View Post
    Ahhh, so that's what the Tanpan is for. I stand corrected!
  14. #39
    Nov 2009
    exactly.
  15. #40
    Reputation: jason124's Avatar
    Jul 2006
    IIRC, R9100 series Di2 is no longer compatible with M9000 Di2. Which means R8000 may not be compatible with the new XT Di2.
  16. #41
    This whole thing is like complaining an Aero frame missed the boat by not having clearance for 40mm tires and rack mounts.
    If your ability and/or terrain doesn't allow you to use a regular road racing set up you bought the wrong thing or need to live with jerry-rigging.
    Do you expect them to redesign what's designed for road racing so 1% can use a 40 cog while probably making the other 99% unhappy?
  17. #42
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    So what are you supposed to buy if you want 11 speed and brifters and lower-range gearing exactly. Do tell. Oh wait...Shimano ceased selling products that did. So their "road racing set-up" is now the only game in town. Same for Campag.
    "Gravel" is a segment taking off (again) because there are millions of miles of MMR unmaintained roads in the USA and elsewhere. And Shimano doesn't sell a product that serves it.
  18. #43
    Jun 2014
    It's not like we are expecting an entire group. All we need is a clutch-equipped rear der that works with their road shifters.
    One that has a wide range like the new R8000 or even closer to the M8000 could be nice. 36t to 40t max seems reasonable.
  19. #44
    Jan 2005
    It's not like we are expecting an entire group. All we need is a clutch-equipped rear der. One that has a wide range like the new R8000 or even closer to the M8000 could be nice. 36t to 40t max seems reasonable.
    Or a lower-geared crankset. Shimano voluntarily killed the triple with 11speed, and suddenly expects everyone to get by on a 34T min LOL.
  20. #45
    Get Sram rival, a smaller crank or jerry-rig (like I said) Shimano. yes, gravel riding is taking off and everyone doing it seems to be doing just fine so I don't know why Ultegra off the shelf not being suited for it would be a big deal. Don't run Ultegra stock then.
  21. #46
    Road Warrior
    Reputation: n2deep's Avatar
    Mar 2014
    Shimano and others want to eliminate the triples but failed to recognize that a large segment of their consumers (yes includes roadies) need lower gears for extreme or lengthy hills. Currently the only mod that makes sense if you own 6800 stuff is changing the standard 50/34 compact to FSA's 46/30.. Its the same ole stuff, they fail to recognize that the new design does not fit all!!!
  22. #47
    Road Warrior
    Mar 2014
    Quote Originally Posted by n2deep View Post
    One other option,, some bike stores will install triples on new bikes.
  23. #48
    Oct 2014
    If there is market demand, someone (shimano or otherwise) will fill it.
    FSA (and probably others) offer a line of 'adventure' cranksets that can be used to augment gearing.
  24. #49
    Jan 2005
    What 11 speed road group supports a triple? None.
  25. #50
    Road Warrior
    Mar 2014
    Your correct, 11sp will not work in the front/triple,, you have to go old school,, like I said i's mix and match..
  1. Shimano Ultegra R8000 officially announced
    By cobra_kai in forum Components, Wrenching
    Last Post: 06-13-2017, 05:19 AM
  2. Music you missed the boat on
    By Jay Strongbow in forum The Lounge
    Last Post: 03-24-2014, 07:16 AM
  3. well I missed the boat this morning...
    By DM.Aelis in forum Giant
    Last Post: 12-12-2009, 01:00 AM
  4. I missed the boat
    By pigpen in forum Campagnolo
    Last Post: 08-22-2009, 08:00 AM
  5. New Bike Q's: C-Dale R8000 or Six 13
    By Surly in forum Bikes, Frames and Forks
    Last Post: 05-09-2005, 10:47 PM
