Results 1 to 2 of 2
    shorts/bib fit with compression fabrics
    How does one determine proper fit when using some of the newer compression-type fabrics? Obviously these should fit snug but how does one tell the difference between snug and too tight?
    But it's a good hurt.....
    Jul 2006
    Go by the measurements they give to find your correct size. Then buy one size larger.
    You will still look like 10lbs of sausage in a 5lb casing if you have any body fat, but you will be more comfortable.
Sea Otter Classic
Contest
