Results 1 to 25 of 42
    Aug 2013
    Smaller cassette or larger chainring?
    So, I just purchased my new bike and am loving it with the exception of one thing, compact crank. I've read advantages and disadvantages until I'm blue in the face so please spare me.
    My question: I miss the feel of my old standard crank so which is better to achieve same/similar feel? Replacing the crank with a standard set or putting on a smaller cassette? I've read about the smaller cassettes wearing out faster, but that aside which is better? For references, I live in Dallas (pretty flat terrain.)
    Reputation: bwbishop's Avatar
    Sep 2011
    Re: Smaller cassette or larger chainring?
    I'd just do the smaller cassette for nice tight shifting. Plus it's cheaper to change.
    Aug 2013
    Quote Originally Posted by bwbishop View Post
    What's the downside to a smaller cassette? What will I be losing?
    Sep 2012
    Quote Originally Posted by Lovinglifetx View Post
    hill climbing comfort, but you'll shave off a few grams by going smaller casette.
    since you live in flatland, you don't lose much, if anything, definitely waaaaay cheaper than changing crank
    Aug 2013
    The group I ride with likes to throw at least one hill in the mix just to see who lives and dies, so I do use some of the lower gears. But if I'm not losing much on the lower end I will definitely go that way. The guy at the bike shop I ride with suggested it but I told him I wanted to do some research first before I made the switch.
    Reputation: mpre53's Avatar
    Oct 2011
    What size cassette are you running now?
    Aug 2013
    Not a clue, whatever came with the bike.
    Sep 2002
    Or have the shop swap out the crankset.
    From what I can see it is a new bike and still within a return period. If you are not satisfied with the bike it is not totally unreasonable.
    Aug 2013
    For what I got the bike for I don't believe they would be willing to switch out the crankset. That was really the only negative in choosing this bike over the CAAD10 I was looking it (which came with a standard crank). However, this frame and bike felt better to me so I figured I would worry about the gearing later.
    Oct 2011
    Brand and model year? The specs should be online.
    With a compact, you probably have either a 25 or 28 big cog.
    Aug 2013
    Just found it - 25
    Aug 2013
    So, which cassette should I switch to on the back and what am I losing?
    Oct 2011
    Just taking a quick look at SRAM and Shimano, the pickings seem to be getting kinda thin for 11-23 or 12-23 cassettes in 10 speed. SRAM PG 1090 in 11-23 lists for over $300 USD. It would probably be just as cost-effective to swap out the crank to a standard. How often are you using your 25? Do you go down to your 34 on the front, or can you grind out a hill on the 50/25? I'm not a cross-chaining nazi, FWIW.
    Of course, Shimano hasn't updated their site since Tiagra went to 10 speeds, so I can't get a good idea of what they have available now.
    Aug 2013
    Well the guy at the shop said he could throw on a cog for $100 bucks but I don't know what it is.
    Feb 2012
    Is your compact a 50/36? 39/25t is very similar to 36/23t.
    Nov 2010
    As I read this thread, I am wondering if op has an understanding of gearing.
    As has been said, the difference between a standard crank and compact is that with a standard you pick up some on the high end and lose some on the low end. With a compact you pick up some on the low end and lose a bit of the high end. In between the extremes, while their may be some difference in combinations used, when you compare the gear inches, there is no real significant difference.
    On the high end 53/11 = 130 gear inches. 50/11 - 122. Unless you are spinning out the 122, which to me means 110 rpm, a standard crank makes very little sense. Even the pros don't use this large of a gear very often.
    so op what is it exactly that you don't like about the compact. I know you don't use the low gear very often, and I don't either, but I bet I use the high gear even less.
    pmf
    pmf is offline
    It appears you don't like the compact. I symphasize. What do you hope to gain with a different cassette? It doesn't sound like you need more gear for climbing, which is really the only advantage of a compact set up. You can get the same gear combinations on a 53/39 that you can for a 50/34 except at the low and high ends. I find a 27/39 feels about the same as a 25/34. About all you can do at the other end is switch from a cassette with a 12 teeth cog to one with an 11 teeth cog. Probably not worth it IMO.
    Nov 2010
    they are close to the same. 39 vs. 36.5 gear inches
    Hucken The Fard Up !
    Reputation: Salsa_Lover's Avatar
    Jul 2008
    Get a Standard
    you can get almost new standards on the market for cheap from many guy going compact, so you can profit of that.
    second less expensive option, install 53/39 rings on your compact, you could get some flex on the rings though.
    third go with a 11-21 or 11-23 cassette
    Quote Originally Posted by zank
    They're just bikes. Ride 'em in the rain, salt, snow and crap to fully appreciate them.
    Quote Originally Posted by Sean Kelly
    The thing about the cold is that you can never tell how cold it is from looking out a kitchen window. You have to dress up, get out training and when you come back, you then know how cold it is.
    Jun 2012
    Please elaborate on the "feel" you are missing? Front shifting? Can't find the right cadence? Is it on the flats or climbing?
    I switched out my 34 for a 36. Front shifting is much smoother and I can spin up to the mid twenties if a climb flattens out mid way through.
    Be sure you use Loctite on all chain ring bolts!
    That's the longest I've ever ridden without a beer stop.
    Reputation: velodog's Avatar
    Sep 2007
    Here's one of many gear charts out on the interwebs. Punch in the numbers and it'll give you the gear inches of said numbers. With that information you should ought to be able to figure out what will work for you.
    http://www.analyticcycling.com/GearChart_Page.html
    'brifter' is a lame word.
    Quote Originally Posted by DCash View Post
    Really? Most people grease them...no need for Loctite.
    I work for some bike racers
    and a bunch of skateboards
    Jul 2008
    What cassette did your old standard crank bike have on it? If it was 12-25, go to an 11-23 with the compact. If it was 12-23, go 11-21. Your effective gearing will be very similar. The only place you might still see a difference is in the small chain ring as the % change from a standard 39 to a compact 34 is fairly substantial. You can always change from a 34 to 36 small chain ring on your compact.
    The suggestion was made to put full size chain rings on your compact crank. Generally the bolt centers are different, 110mm vs 130mm, so you might have a hard time finding the right parts.
    Here's an 11-23 Ultegra for $70, new. New Shimano Ultegra CS 6700 Road Bike Cassette Sprocket 11 23 10 Speed Lock Ring | eBay
    Burnum Upus Quadricepus
    Reputation: brucew's Avatar
    Jun 2006
    The downside is that you won't be gaining anything.
    Say your replace your 11-25 with an 11-21. The 11 is still an 11, and you're still cross-chained in the small ring at 19 or 20 mph. Worse, it raises the speed where you're cross-chained on the big ring.
    I own both crank types and a whole slew of cassettes. I too am a flatlander. IMHO, the only thing like a standard, is a standard.
    Reputation: JCavilia's Avatar
    Sep 2005
    Before you spend any money, you need to figure out what the heck you're talking about with this "feel" business. What don't you like about your current setup?
    -the shift patterns? Look at the percentage difference between the rings. (you never said what rings you have, only "compact", nor did you say what your cassette is -- the numbers matter; this is all about numbers). You could change that by chainging one ring -- but you have to chart it out, do a little math, and see what would get you the patterns you want.
    -do you need a higher gear at the top end? Not likely, but hard to say since we don't know what your highest gear is now (do you?) If you do, a cassette might be the easiest thing. (example: if your highest gear is 50x12 now, getting a cassette with an 11 would get you a bigger change than getting a 52 or 53 ring.
    -do you have low gears that you don't need? Making the small ring bigger (without a whole new crankset) would adjust that, but getting a smaller-range cassette has the advantage of getting you extra gears and closer spacing in the middle.
    So what do you have now (in numbers, please, not useless desciptors like "compact" and "standard"), what are you missing that you think you need (specifics, not "feel"), and what do you have that you're not using?
    I hope that doesn't sound harsh; I'm genuinely trying to be helpful. A lot of gearing discussion is bs, unfortunately. You gotta do the math.
    Have you ever been to Electric Ladyland?
  1. Smaller vs. Larger frame - Caad9?
    By backbeat in forum Bikes, Frames and Forks
    Last Post: 07-23-2007, 05:27 PM
  2. Bibs: smaller or larger if between sizes
    By texass4 in forum General Cycling Discussion
    Last Post: 12-01-2006, 10:47 AM
  3. Smaller or Larger frame when you're in between
    By hardride27 in forum Bikes, Frames and Forks
    Last Post: 06-24-2006, 05:56 AM
  4. Smaller or larger frame size
    By stupidgringo in forum Bikes, Frames and Forks
    Last Post: 05-04-2006, 09:51 AM
  5. larger vs smaller
    By edgeman in forum Trek
    Last Post: 02-15-2006, 09:20 PM
