Results 1 to 25 of 38
    May 2011
    Trek Emonda snaps in half
    Hmmm... maybe they tried a tiny bit TOO hard to prove they could make a disc brake bike come in below the UCI weight limit?
    Trek-Segafredo rider's bike snapped clean in half in Herald Sun Tour crash - Cycling Weekly
    Well, you know, that's just, like, your opinion man. - The Dude
    Oct 2002
    It's a bike component, it got smashed in a smash. Fiber is designed to be light and strong but it's not designed to stand forces outside of the normal parameters. Might look like bad PR but the bike did it's job. I am presuming the damage was done in the crash and was not the cause.
    'brifter' is a lame word.
    Quote Originally Posted by OldChipper View Post
    You trying to stir up **** after the last week and the 'fork debacle'?
    I work for some bike racers
    and a bunch of skateboards
    Oct 2013
    I want to see a vector diagram illustrating how the disc brake forces sheared that frame in half.
    Maybe the front/back balance needs to be address on those disk brakes!
    BANNED
    Reputation: Fredrico's Avatar
    Jun 2002
    Hey, the fork didn't break! . They must be doing something right!
    Oops! Guess not. Have to wonder how flippy it rode when intact.
    May 2011
    Sorry, didn't know about/follow "the fork debacle" (somebody have a link?). Yeah, bikes break, though the others didn't and riders don't often walk away from crashes bad enough to snap a frame in half as Didier did in this case. If you're going to put extra weight on a bike in the form of disc brakes and still be under 15lbs, that weight's gotta come from somewhere. Trek may be trying too hard to prove point is all I'm sayin'.
    Which makes me wonder... does Trek make good bikes?
    Reputation: GlobalGuy's Avatar
    Jun 2015
    Quote Originally Posted by kiwisimon View Post
    Yep, bike broke from bad road race crash. It happens. Nothing to see here, nothing to see.
    Jun 2002
    Here ya go:
    http://forums.roadbikereview.com/gen...ct-363619.html
    Dec 2005
    If only you could see the anti-cogentiveness of your posts and the obtrusiveness of the amorclativity of your posts, then you'd realize that the shallowness of my propensity to blow smoke out of my own anus is only exceeded by the logicalivity of your own posts. Hey, I've been building bikes since I was 10 and I'm an engineer! You couldn't and wouldn't possibly understand. Oh, and everything Spesh builds is completely bomb proof and completely uber-engineered.
    Cycling Addict
    Nov 2013
    We have seen bikes break like that before in racing crashes. This is nothing new.
    Life is short... enjoy the ride.
    Reputation: velodog's Avatar
    Sep 2007
    Quote Originally Posted by ogre View Post
    Oh my.
    Too old to ride plastic
    Happily absent RBR Member
    Reputation: Kontact's Avatar
    Apr 2011
    I would imagine that even a steel frame would have been unrideable after such an incident.
    May 2011
    Quote Originally Posted by Kontact View Post
    So you saw the crash up close and know what forces the frame experienced? I see at least one other non-broken frame on the ground.
    Darling of The Lounge
    Reputation: Retro Grouch's Avatar
    Apr 2002
    Bicycles with crumple zones. It was only a matter of time
    Apr 2011
    No. Did you? What would the other bikes have to do with what happened to this one? They weren't caught in an explosion.
    What I am saying is that forces high enough to sever a frame tube or two should also be sufficient to at least bend any pro level frame's thinwall tubing.
    What are you saying?
    Jun 2002
    Quote Originally Posted by bradkay View Post
    Yep, and most of them were carbon. . Or aluminum.
    Can't remember seeing a steel frame break in half on top tube and down tube. Steel crumples in a crash.
    The lighter the thing is, especially a bike frame that has to handle the torsional flex of a 180# rider barreling down a mountain at 45 mph, the more possibilities of stress failure, if that's the right term.
    It would take more than wiping out on the road in a race to snap a steel frame like the one above. If carbon were stronger than steel, it wouldn't separate so easily. I don't give a durn whut the engineers say. Some of 'em are so locked away with their data sheets, they miss the obvious.
    Apr 2011
    Quote Originally Posted by Fredrico View Post
    There is no advantage in a frame that bends instead of fractures. Unrideable is unrideable.
    Reputation: izza's Avatar
    Jul 2012
    Richie Porte hit a moped last year in the TdF. Froome hit Porte who is softer than a moped. The Pinarello breaks.
    This was the second time Froome broke a Pinarello in that race.
    Why no thread then as to why Pinarello not making a strong enough bike?
    Apr 2011
    Quote Originally Posted by izza View Post
    If a bike was strong enough to not break when you ride into something, how much would it weigh?
    The presumption is that carbon frames are weaker because they break when crashed instead of folding. But carbon frames have similar or even greater ultimate strength, so it is fair to assume that an crash hard enough to break carbon would have severally bent steel or aluminum.
    I'm not a huge carbon fan, but a crash is violent thing. Everything worth riding is going to break.
    Reputation: Srode's Avatar
    Aug 2012
    They used to make the worlds best bikes bar none, but this probably means they have been dethroned and Trek is now #1!
    Another case of a 300lb brother was ramming curbs on a perfect bike from the company that now builds the best bikes in the world!
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Reputation: 11spd's Avatar
    Sep 2015
    This ^^^^ F1 cars are designed to strategically disintegrate in a crash to attenuate energy, why not bicycles.
    Dec 2006
    With a steel frame, even if it was bent would most likely remain in one piece. That means more potential for the rider to retain some semblance of control, and safety, despite the unpredictability of a crash.
    They're building carbon frames so light that they're designed to withstand "riding forces" only. That's because the fibers are oriented to the stresses at the particular locations in the frame.
    Steel is anisotropic; it has the same strength in all directions, which makes it stronger in withstanding certain forces that carbon frames ignore.
    I didn't see the crash that caused the frame in the OP to fail, but it's entirely possible applying the front brake hard or long term repeated brake application, combined with hidden fiber breakage in the underlying layers of carbon, caused the crash. The front of the frame could have been too strong for the rear half. Just speculation, of course.
    flinty-eyed moderator
    Reputation: Coolhand's Avatar
    Jul 2002
    Moderators Note
    I can see thing are getting out of hand. Posting vacations are now being issued.
    Dr. Cox: Lady, people aren't chocolates. Do you know what they are mostly? Bastards. Bastard-coated bastards with bastard fillings. But I don't find them half as annoying as I find naive bubble-headed optimists who walk around vomiting sunshine.
    Sep 2011
    750g disc frame for the win! lol all the weekend warriors reading this now probably get a little scared. But me, I'm not touching it. "Bike does it job", by breaking in half and saving the rider. Is this a joke? Money grow on trees?
    Jul 2012
    Agreed.
    Whether disc or not, things break in a crash.
  1. Domane SL vs Emonda SL vs Emonda ALR
    By ToiletSiphon in forum Trek
    Last Post: 10-20-2017, 12:31 PM
  2. Emonda SL5 105 5800 vs Emonda SL6 Ultegra 6800
    By Cleanneon98 in forum Bikes, Frames and Forks
    Last Post: 08-13-2016, 09:56 AM
  3. Trek Madone 7.9 or Trek …monda SLR 10 for the Tour de France ??
    By Canuckophile in forum Bikes, Frames and Forks
    Last Post: 09-01-2014, 12:17 AM
  4. Is the saddle half right or half wrong?
    By oily666 in forum General Cycling Discussion
    Last Post: 09-13-2007, 06:31 AM
  5. Half empy or half full?
    By Fredke in forum Politics Only
    Last Post: 09-05-2007, 01:35 PM
