Results 1 to 12 of 12
    Reputation: GlobalGuy's Avatar
    Jun 2015
    Tweak shifting performance by "partial" upgrade?
    I easily can find out from my LBS when I get around to it but thought I would for fun ask a question of the forum.
    Iíve recently gotten a Trek FX3 rim brake bike as a get around town errand bike. So little use and very low mileage on any given day when I use it.
    The shifting isnít, (as expected) the best. Low-cost parts on a triple.
    Shifters
    Shimano EF65, 9 speed
    Front derailleur
    Shimano Acera
    Rear derailleur
    Shimano Alivio T4000
    Crank
    Shimano Acera M371, 48/36/26 w/chainguard
    Cassette
    Shimano HG200, 11-34, 9 speed
    Chain
    KMC X9
    In other words it sure isnít a Shimano 105, (my Domaneís drivetrain.)
    I was wondering if I were so inclined could I upgrade the shifting quality of the FX3 by just upgrading one thing such as just the chain or the derailleur? And so on. You get the picture.
    Thatís all I would like to know. Just that. Nothing else.
    Thanks.
    'brifter' is a lame word.
    Should be posted here:
    Components, Wrenching
    And no...'upgrading' a chain or a derailleur won't change anything.
    I work for some bike racers
    and a bunch of skateboards
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    First thing to do (entirely free) is disconnect the shift cables. Pull on the cable end in your hand while shifting. Does is feel smooth? If not you have:
    A gunked up or corroded cable. Your cables probably aren't stainless. If they got some moisture on them they could have some corrosion.
    Or bad cable routing.
    Or the ends of the housing weren't cut right and/or have a burr on them.
    Reputation: Lombard's Avatar
    May 2014
    ^^^This.^^^
    Cables are everything when it comes to quality shifting. You can have a cheap drivetrain and good quality stainless steel cables and housings and the bike will shift reasonably well. You can have the most high end drivetrain and if you have cheap or old oxidized cables and your shifting will be cr@p!
    Replace your cables and housings!
    ďStatistics are like bikinis. What they reveal is suggestive, but what they conceal is vital.Ē -- Aaron Levenstein
    Nov 2009
    Could be some other things as well and the cables could be fine.
    Derailleurs out of adjustment, bent rear derailleur hanger etc.
    Don't foolishly just "replace" all cables and housings.
    Oh my, a troll who doesn't know the difference between your and you're. What will they think of next?
    May 2012
    If you're not using the 48t front chainring that often, you could upgrade your shifting and save a pound and a half or so of weight by going to 1x11 for about $350 including a 38T chainring from Ebay.
    Shimano XT M8000 1x11 Drivetrain Groupset | Chain Reaction Cycles
    Jun 2015
    To the thread: Thanks for the advice and opinion. However, in case it was not clear in the OP:
    The bike is brand new. It is kept inside. It has perhaps 30 miles total per an estimated six rides.
    ngl
    ngl is offline
    Jan 2002
    Quote Originally Posted by GlobalGuy View Post
    Can you describe what "shifting isn't exactly the best" means? Until we know more, posts #2, #3 or #5 may still apply.
    tlg
    tlg is online now
    May 2011
    New bikes can, and often do, have crappy cable instalations. Check your cables. It's FREE
    The Slow One.
    Reputation: Alaska Mike's Avatar
    Sep 2008
    Cables and derailleur alignment/adjustment are my guesses for less-precise shifting. My kids' bikes all have lower-tier groupsets (8 or 9 speed) and triples, and they all shift just fine.
    If you bought it new, take it back to the store you bought it from and describe clearly what you see as wrong. After an initial "break in" period, adjustments may need to be made.
    If you don't know how to do this yourself, now's a good time to learn. Pick a wrench you trust and like, buy a twelve pack of their favorite beer (or a similar, pre-agreed upon bribe), and have him/her teach you how to set up derailleurs.
    Nov 2009
    Check cables Yes, Arbitrarily replace tehm, No.
    May 2014
    Quote Originally Posted by factory feel View Post
    Agreed. But as TLG said, new bikes can have crappy cables and cable installations. If it has internal routing, it is entirely possible the cables are crossed inside the downtube and were installed that way from the factory. It happens. Ask me how I know.
    Also, many bikes, especially lower end bikes come with cheaper galvanized cables. To find out if you have these cheaper cables, run your finger along one. If it leaves a residue on your fingers or feels rough, it's galvanized. Good quality stainless steel cables will not leave a residue and will feel smooth.
  1. If you were to "tweak blood volume" ...is that legal?
    By WeakMite in forum The Doping Forum
    Last Post: 07-25-2010, 12:52 PM
  2. Partial upgrade to 11 speed
    By gusthebus in forum Campagnolo
    Last Post: 01-28-2009, 02:55 PM
  3. Tweak my training
    By iliveonnitro in forum Racing, Training, Nutrition, Triathlons
    Last Post: 12-05-2006, 04:35 PM
  4. Brake lever tweak help/advice
    By Armchair Spaceman in forum Fixed/Single Speed
    Last Post: 12-06-2005, 05:27 AM
  5. Hamstring tweak only a week before an event
    By Spunout in forum Racing, Training, Nutrition, Triathlons
    Last Post: 06-10-2005, 03:48 AM
