Results 1 to 25 of 28
    Aug 2012
    Vittoria Zaffiro Trainer Tire - Should I Bother?
    Hello:
    I searched for this subject, but did not have any luck. If this is a repeat, I apologize.
    I am new to cycling, and plan on using a Blackburn Mag 3 I picked up from CL this winter for indoor training. I will be using my mountain bike, as I have not been able to procure a road bike as of yet.
    My main question is: Should I bother with a trainer specific tire? The Vittoria Zaffiro gets mixed reviews on Amazon (http://www.amazon.com/Vittoria-Zaffi...=INBNODL6YSEPE), but has a good price point. Much more so than the Conti trainer tire's price. Would I be better off just using cheap tires? I am not sure how many people end up going through in a winter, or how noisy my current semi-slicks would be. I am going to try to get up to 40 miles/day.
    Any input appreciated, especially on the Vittoria Zaffiro. Thanks!
    Not a rocket surgeon.
    Reputation: tihsepa's Avatar
    Nov 2008
    I ride rollers so my opinion really dosent count. Just get some cheep tire and you will be fine.
    waterproof*
    Reputation: Creakyknees's Avatar
    Sep 2003
    I have a trainer-specific wheel and I put my worn out rear tires on it.
    * not actually a Rock Star
    Nov 2008
    Quote Originally Posted by Creakyknees View Post
    That works too. I usually cut them before that are way worn out though.
    Apr 2010
    For as much as a good tire costs and how fast a trainer will wear a tire, anything under $50 for either will save you money. Oh, and don't forget they are quieter.
    I have used both Conti and Vittoria. I liked the Conti a little better as it was easier to get on. Although, I only had to do it 2 times. Yeah, I got a flat on my trainer.
    It's a fire road.............
    I'm on a road bike..........
    They have enough in common to blast down it.
    Reputation: partyofone's Avatar
    Feb 2012
    I bought a big heavy cheap tire from walmart and use it. You might be able to get a slick or something without mt. tread on it from there. I didn't really care about the weight of the tire because it is only for use on the trainer, even though I have had it on the road when the weather breaks enough for a ride.
    Jun 2004
    I've used both old tires and the Vittoria trainer tire. Either works, but the trainer-specific tires are quieter and less messy (if, like my husband, you're one who actually shreds tires on the trainer).
    Aug 2012
    Thank you for all of the input. I am still unsure which way to go, but have a lot more to think about.
    Jul 2008
    Quote Originally Posted by bradlyaolson View Post
    I take it from your posts you are looking for a tire to put on your MTB in order to ride the trainer until you get a road bike. Whatever part of the tire contacts the roller needs to be slick. (grooves running perpendicular to the roller are okay) I bought a cheap tire that did the trick. You should be able to find something in the $15 range.
    Once you get your road bike, you can use tires that you feel are too worn for the road. I have yet to see a "need" to buy a trainer specific tire.
    Reputation: JimP's Avatar
    Dec 2001
    I have used old tires, new cheap tires, Conti Trainer, and the Vittoria Trainer. The road tires tend to shred and leave a mess and are noisier than the trainer tires. The Conti was good and lasted quite a while. I now have the Vittoria and it seems to be lasting longer than the Conti did. Also, the Vittoria seems to be a little tacky and stick to the shaft better with less slippage. The tire does get hot which is what kills the tube after a while so I keep a spare ready since patching the tube is futile. A patch may last only a day or so since the rubber in the tube has been fried.
    Jim Purdy - Mansfield, TX
    Aug 2012
    Quote Originally Posted by JimP View Post
    Thanks, I appreciate the first hand info!
    Jul 2010
    Hi all, I thought this might be a good thread to post this picture of the Zaffiro Home Trainer tire I've had for a while... should I be concerned?Vittoria Zaffiro Trainer Tire - Should I Bother?-img_2273.jpg
    Quote Originally Posted by junglejay View Post
    Hi all, I thought this might be a good thread to post this picture of the Zaffiro Home Trainer tire I've had for a while... should I be concerned?Click image for larger version.
    About what? Crashing? It either works or it doesn't.
    Jul 2010
    I perhaps should have been clearer. I am wondering about the cracks that have developed parallel to the threads of the tire. Not sure if they are normal wear & tear (and nothing to worry about), or presage to catastrophic failure. Here is another picture.Vittoria Zaffiro Trainer Tire - Should I Bother?-img_2271.jpg
    I perhaps should have been clearer. I am wondering about the cracks that have developed parallel to the threads of the tire. Not sure if they are normal wear & tear (and nothing to worry about), or presage to catastrophic failure. Here is another picture.Click image for larger version.
    I guess that doesn't change what I have to say. It either works or it doesn't and I don't know what you are concerned might happen on a trainer.
    Reputation: Lombard's Avatar
    May 2014
    I would say as long as you don't use it anywhere except on the trainer, it should be fine. After all, if it fails, the trainer mount will keep you from falling.
    However, I wouldn't take it out on the road - not even around the block. New tires are a lot cheaper than a trip to the ER.
    -- Warren Buffett
    Dec 2009
    I bought one to use on our tandem but stopped using it, forgot exactly why though.
    You are better off just using a worn tire.
    Jun 2015
    Your trainer tire is unusually filthy also. My Zaffiro trainer tire would get slightly gray, bu it wouldn't turn shiny black down the center. You should probably thoroughly wash your trainer's roller and put on a new tire.
    As far as whether trainer tires are worth it. I would say yes if any of the following conditions are true.
    1) You have a spare rear wheel anyway.
    2) You use your trainer a ton...thousands of miles in the winter off-season.
    3) Your normal tires are cotton-wall tubulars or open-tubular (non-vulcanized clinchers) with glued on treads.
    I can't recall if my Zaffiro started cracking...if it did it was very slight. What did end up happening is I would occasionally forget to loosen the roller tension afters sessions and eventually the tire developed a kink/bulge in one spot that made the ride lumpy and could have potentially led to a bigger failure. I don't think the Zaffiro is the only trainer tire this happens to.
    Eventually I just switched to a direct-drive trainer and have been much happier with the user experience.
    Reputation: DeepV's Avatar
    Feb 2016
    Catastrophic failure on a trainer?
    You yourself say you have had it for a while, buy another one. $30 on Amazon.
    May 2014
    Quote Originally Posted by ceugene View Post
    Junglejay lives in NYC. Of course his tire is filthy! I live in North Jersey and you wouldn't believe the amount of black soot I wipe off my tires after a ride before I bring it back in the house.
    -- Warren Buffett
    Aug 2007
    I have the same tire and after two years of trainer use it looks like this. Seam to be the way trainer tires wear.
    I say keep riding it and when you start to see a bump form, replace the tire.
    Slowski
    Reputation: eboos's Avatar
    Mar 2011
    Is that tire/bike kept in an unheated environment (garage, shed, etc.) The cracking may be a result of the tire freezing. While it looks pretty rough, as long as the casing isn't compromised, the tire should not blow out. That being said, I wouldn't use it on rollers, but a stationary trainer should be fine.
    Aug 2007
    This is normal wear. I have the same tire on it’s third season it looks just like your.
    May 2014
    Quote Originally Posted by Kendogz161 View Post
    No, that is not normal wear, that is dry rot. If you like playing Russian roulette, that is your privilege, but you shouldn't be giving advice to others to do the same.
    -- Warren Buffett
    Aug 2007
    Ok if that’s what you believe.
    You know this is an indoor trainer tire, right?
    To be used on a trainer only.
    If he has a failure it will be on his trainer, and what a blowout.
    Before the blowout the tire will bubble.
    Russian roulette on a trainer, now that’s a funny one.
