Results 1 to 3 of 3
    Jul 2017
    Wahoo vs Garmin Speed/Cadence Sensor Compatibility with Trainer Road
    Ok, so I got a new bike, a 2017 Fuji SL 2.1 Disc. I also bought a Wahoo Kickr Trainer, Wahoo Elemnt Bolt computer, and the related ANT+/Bluetooh speed/cadence sensor. To make a long story short, their sensor is a piece of garbage and will not work with my frame's thick chainstays. The only place I can put the sensor so that it picks up my cadence magnet also puts the speed sensor solidly into the spokes regardless of how it is adjusted. If I put the sensor so it safely picks up the speed magnet, the cadence magnet is well over 1/2" away, far outside of the recommended 1/8" max distance. It simply is not adjustable to work.
    I have a Garmin speed/cadence sensor that only transmits via ANT+, and it is very adjustable and is easily mounted on the bike to pick up both cadence and speed. I know the computer will find that sensor, so that's not a problem. The question I have is this... can I use my Kickr Trainer with an ANT+ speed/cadence sensor and a Bluetooth HR strap while using Trainer Road? I want that app to pick up and display the Kickr's power, HR, and cadence. What do I need to make this happen? I'm brand new to most of this crap and am extremely frustrated that I'm having to fight with a brand new $60 sensor to even get it to mount on my bike. I barely have any time in my days and to waste an entire evening screwing around with a crappy product really makes me mad at the Wahoo Fitness company.
    Reputation: Srode's Avatar
    Aug 2012
    Can't say about TrainerRoad but I know on Zwift you can combine Bluetooth and ANT+ sensors. As I remember it's done through your phone and the mobile App on Zwift, but could be wrong, it's been over 6 months since I played with it.
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Reputation: pittcanna's Avatar
    Oct 2014
    Which wahoo speed/cadence sensor are you using?
    Also with the kickr you don't need a speed sensor. All you need is the cadence, there is the wahoo based ant+ magnetless cadence sensor that just clips in your shoe.
  1. Wahoo element just got smaller and simpler - The wahoo mini
    By pittcanna in forum General Cycling Discussion
    Last Post: 08-18-2017, 02:45 PM
  2. Can Garmin speed and cadence sensors be used with the Wahoo Elemnt?
    By ToiletSiphon in forum General Cycling Discussion
    Last Post: 01-14-2017, 06:28 PM
  3. How to mount Garmin Bike Speed Sensor and Cadence Sensor
    By DennisMadsen in forum Components, Wrenching
    Last Post: 06-15-2014, 11:28 AM
  4. I would like some feedback on the Garmin Speed/Cadence Sensor
    By rellimreeb in forum General Cycling Discussion
    Last Post: 01-07-2009, 09:17 AM
  5. Polar S710 - speed sensor/cadence sensor
    By mrroll in forum Components, Wrenching
    Last Post: 09-04-2005, 10:16 AM
