Results 1 to 10 of 10
Thread: Weird Issue
    Dec 2016
    Weird Issue
    I've been improving weekly and adding miles. May I hit 200 miles June I hit 315. Getting more and more "in tune" with my fit and ride. Cadence is up there now.
    My last ride was beach side on Long Beach Island NJ. Had to get up at 5am to get a ride in while the kids were asleep. Ended up doing 29 miles.
    At some point my pedal stroke felt off. Didn't think much of it. Return ride killed me...it was a 20 mph wind (forecast numbers) that just didn't stop. Post ride I saw my seat was way off. It had moved rearward about half an inch!! It wasn't loose either. What gives?? It's torqued down a little past the Newton recommendation. Anything I can do to the seat rails? It's and Ergo seat with chrome Molly rails. Post is Bontrager stock with the Domane SLR.
    Oct 2013
    My seat nose keeps coming up, I reset it last week and really torqued the front bolt to hold it down.
    The right mirror on my moto will not stay in position.
    I am going to try putting some emory cloth (like sandpaper) in the mating parts and see how they hold.
    BANNED
    Quote Originally Posted by biscut View Post
    That is strange. There is really not much force being placed on the saddle in the fore/aft direction. I 'd remove the seat, inspect for anything wrong, clean the rails and then re-install
    Reputation: Upnorth's Avatar
    Jul 2013
    Take small amount of clear silicone and mix in some sand. Put it on rails where clamp will sit. Once dried it will not slip again.
    Oct 2012
    Quote Originally Posted by DaveG View Post
    Depends on the saddle specifics, I've had my SMP slide backwards, using a two-bolt micro-adjust seatpost; however, unlike most saddles, the rails on that brand are more angled, and there is a 'kick-up' in the back to keep the rider from sliding backwards while climbing that can be found on other saddles with a curved side profile, although usually less pronounced.
    Marking the clamp position on the saddle rails can be useful to check at a glance whether the saddle has moved.
    With that said, making sure the second bolt is very tight has prevented the problem from reappearing for me, so far with no consequences for the seatpost.
    Apr 2011
    If it happens again after trying the above suggestions, check for holes on the wall or floor of your house. Those gremlins can wreak havoc on mechanical things.
    Reputation: velodog's Avatar
    Sep 2007
    Use a little carbon assembly paste between the clamps and rails, that should have enough bite without scarring anything. Also, like oct3 recommended, mark the saddle rails and keep an eye on them.
    Too old to ride plastic
    Reputation: PJay's Avatar
    May 2004
    Quote Originally Posted by Upnorth View Post
    What kind of silicone? Like silicone caulk?
    Feb 2007
    Is this the bontrager post with a plastic insert on each side of the top of the seat post? I had one like this, seat would move around. Finally took everything apart and noticed the two plastic pieces were not lined up correctly with the rails. You have to pop them out of the post to rotate them. Once everything was lined up correctly nothing has moved.
    Reputation: askmass's Avatar
    Sep 2009
    I'll second the carbon paste recommendation.
    No need to over torque with it... a little dab'll do 'ya.
    “When the spirits are low, when the day appears dark, when work becomes monotonous, when hope hardly seems worth having, just mount a bicycle and go out for a spin down the road, without thought on anything but the ride you are taking.” ― Arthur Conan Doyle
  1. Need help with weird chain-drop issue
    By mtbhead in forum Components, Wrenching
    Last Post: 08-02-2009, 08:57 PM
  2. fork/headset play? weird issue
    By ToF in forum Components, Wrenching
    Last Post: 07-31-2008, 08:44 AM
  3. Reconciling weird knee issue vs. saddle height
    By culdeus in forum General Cycling Discussion
    Last Post: 08-15-2007, 02:55 PM
  4. Weird fit issue...
    By pavedroad in forum General Cycling Discussion
    Last Post: 04-12-2006, 01:02 PM
  5. Weird Tire Issue - ever happen to you?
    By velodoom in forum General Cycling Discussion
    Last Post: 05-13-2004, 04:01 AM
