Results 1 to 25 of 25
    Oct 2012
    What is your common gear ratio on flat road?
    On 53/39T rear with 11-25T rear,
    my most common ratio is either:
    53/15 = 3.53 (6th)
    53/14 = 3.79 (7th)
    Although my cadence is not very fast.
    Reputation: JCavilia's Avatar
    Sep 2005
    Terminology suggestion: Rather than express those as ratios, or gear-sequence numbers, it is more common, and more understandable to road cyclists, to use something called "gear inches," which is the diameter of an equivalent direct-drive wheel. Divide ring teeth by cog teeth, and multiply times wheel diameter in inches (about 26.3 inches for the common 700/23C wheel size).
    So your 53x15 is about 93 inches, 53x16 about 87 inches.
    Unless you're a very strong rider who goes quite fast, those are big gears, and you are correct that your cadence is slow. For example, if you are going 18 mph with the 53x16, you're turning about 70 rpm. You might try using some lower gears and see if you can get used to spinning a little faster. It works better for most riders. In a 53x21 gear at 18 mph, you'd be at 90 rpm.
    I have no idea.
    Do people really look back to see what gear they are using and keep track of it?
    Reputation: Herkwo's Avatar
    Nov 2002
    Of course on this forum the expected answer will always be: 53 x 11!
    HERKWO
    ____________________________
    2005 Airborne Manhattan Project
    2010 Colnago CX-1
    A wheelist
    Reputation: Mike T.'s Avatar
    Quote Originally Posted by nolight View Post
    The one that feels right for me at the time.
    Mike The Bike's home wheelbuilding info - dedicated to providing Newby wheelbuilder information and motivation.
    I'm not cranky; I just have a violent reaction to stupid people.
    Jan 2002
    I'm comfortable riding my fixie, with 42x16, all day long on flat roads.
    Insert something clever here:
    Insert list of every bike I own here:
    Reputation: serious's Avatar
    May 2006
    I like 80-85 gear inches on a flat road. My single speed bike has 48:16 (about 79 gear inches).
    My rides:
    Lynskey Ti Pro29 SL singlespeed
    GF Superfly 29er HT
    S-Works Roubaix SL3 Dura Ace
    Pake French 75 track
    Feb 2012
    On a 50/36 with 11ó23, I usually ride at 50/17 or 50/18. No idea how fast I'm going since I don't have a computer yet.
    Apr 2007
    Quote Originally Posted by JCavilia View Post
    Really?
    I knew that roadies are an insecure bunch, but I didn't realize that people felt the need to compare gear inches.
    irony intended
    Reputation: carlislegeorge's Avatar
    Mar 2004
    Quote Originally Posted by Herkwo View Post
    No, i have a semi-compact with 12-27, so unless I am ascending a grade steeper then 7% I am always in 52 x 12....
    2011 Tarmac Pro SL3 Project Black (gone but not forgotten)
    2012 Parlee Z5 SLi (because I can)
    Reputation: Cygnus's Avatar
    easy since i ride fixed or single speed:
    44 / 16 = 2.75
    Mar 2013
    Lots of variables but assuming little to no wind in your face I tend to settle into 50/16, 50/17 around 78-83 gear inches.
    Reputation: BostonG's Avatar
    Apr 2010
    I havenít really paid attention to that but now that Iím thinking about it, I guess I am probably in the mid 70ís, maybe the low 70ís actually Ė yeah, Iím gonna go with low 70ís. Thatís a solo cruising speed (comfortable but not beach cruiser effort) on flat ground with little wind. Probably seems slow to all you Interweb strongmen but also know that I like to spin so as not to put too much stress on my delicate and oh so supple walking appendages.
    And anyone who thinks it too slow, I got a finger to show you.
    I ride mostly in the honorable pursuit of being kissed on both cheeks at the same time by one blond and one brunette. But not redheads, they scare me.
    Reputation: axlenut's Avatar
    Sep 2010
    I run 71 gear inches on the fixie and when on flats with the geared bike I'll settle into 77 gear inches. On the geared bike I can always downshift if the wind picks up. On the fixie I run a little less gear for the reserve it offers for strong head winds.
    I play for keeps
    Reputation: locustfist's Avatar
    Feb 2009
    When riding tempo i spend most of my time in 53/17 on flats
    at a comfortable cadence 90ish i'm doing around 22mph
    PhotonFreak
    Guest
    Commuting: 64 gear inches (singlespeed)
    Working out: 74 gear inches (53/19)
    Apr 2011
    Flat road = 119.55 gear inches AKA front ring 50 rear cog 11
    Reputation: Bill2's Avatar
    Oct 2007
    Dead calm maybe 50/17. But it's almost never absolutely flat or dead calm here.
    Reputation: sandiegosteve's Avatar
    Mar 2004
    I always start in the 53/21 (67") and then shift to 53/19 (74"). I like a lite, fast cadence.
    F45
    F45 is offline
    Nov 2010
    There is no flat road where I ride.
    Nov 2012
    Between 70"-80" depending on winds, etc. usually 52x19 or 52x17 if I'm feeling frisky.
    Reputation: GregTR's Avatar
    Feb 2013
    Depends on the ride. I seem to average around 65.2 inches which is the equivalent of a 46/19 which is incidentally the most used gear on my bike. When I started riding I averaged 75 inches but my cadence has increased drastically.
    Jan 2012
    Probably 50/19 or 17 if I'm just riding along without any wind. Wind is usually in pretty ample supply though.
    FTR
    FTR is offline
    Burn baby, burn.
    Reputation: FTR's Avatar
    Sep 2006
    No idea, but I know it is not flat enough that I ride around in a 53 anything very much.
    pedalpedalpedal
    Reputation: f3rg's Avatar
    May 2008
    When I was riding only a singlespeed road bike, I found a 53x16 was best for flat rides.
Sea Otter Classic
Contest
