Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 61
Thread: Who Patches
  1. #26
    Apr 2011
    Quote Originally Posted by daniell View Post
    When I was a child, I remember the process of hot vulcanizing the patch. I don't think that is done anymore.
  2. #27
    Oct 2013
    I used to hot vulcanize every tube, then they all disappeared to my amazement. Those patches never fail, it is a shame they don't have them anymore!
    I consider a patched tube better than new, it has been tested. I have had several brand new tube with bloched stems and seams leak with 1" holes over the years.
    BANNED
  3. #28
    Reputation: Oxtox's Avatar
    Aug 2006
    My rule of thumb is after five patches, the tube is done.
    think I had one with 9 once...as long as the patches don't overlap, it's all good.
  4. #29
    Reputation: El Scorcho's Avatar
    Dec 2005
    I am a patcher.
    But now I am tubeless so I expect that the 4 tubes I have currently in stock will last a long, long time.
  5. #30
    Nov 2002
    Quote Originally Posted by Oxtox View Post
    Heat will remove a patch. Heat up a frying pan. While wearing a leather glove, push the patch down on the hot pan. You can then peal it off easily. Haven't tried a heat gun. That might work too. I've removed leaky patches or ones that need to overlap (then using a larger one).
    You can't repair a valve stem that unbonds from the tube, however.
  6. #31
    Reputation: velodog's Avatar
    Sep 2007
    I'm all about patching, but I may draw the line at removing a patch so I can renew it.
    Too old to ride plastic
  7. #32
    Apr 2011
    My line is drawn at where the price of patches used on a tube surpasses the price of a new tube.
  8. #33
    Reputation: Fredrico's Avatar
    Jun 2002
    Remember reading back in the day some NY bike messengers had a contest to see who could run the most patches on a tube. The record was 9.
    So good for ya!
  9. #34
    Nov 2002
    Quote Originally Posted by bvber View Post
    I can't see how you would ever get there. You can buy boxes of patches and large containers of glue. Riding on cheap tubes isn't very confidence inspiring.
  10. #35
    Sep 2007
    It seems that it would be easier to just patch the tube than counting the patches, adding the cost of each patch to see if it has reached that breaking point, then deciding if it is still in the budget to use that tube again.
  11. #36
    Aug 2006
    yeah, there's a point where my practicality ends...
  12. #37
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Patch and glue costs less than $.25. So for a $5 tube that's 20 patches.
    Fair enough.
  13. #38
    Banned forever.....or not
    Aug 2002
    Since Michelin smooth valve stem tubes usually cost up to twice that, I usually patch until I'm forced to overlap patches.
    Dogbert.
    I>U
  14. #39
    a real member's member
    Jul 2016
    i broke down today and bought a couple new tubes on ebay for less than $6 ea -- sunlite brand with 32mm stems.
    didn't wanna do it. but i had a blowout yesterday. (pic of our hero in action.) you can't really patch a 2" gash:
  15. #40
    Apr 2011
    Fair enough.
    You must've found a good deal on patches. Around me, it's about 50 cents per patch.
  16. #41
    Apr 2011
    Quote Originally Posted by blackfrancois View Post
    And the tire was reusable?
  17. #42
    Jul 2016
    apparently, the brand new tire wasn't seated properly in the rim, allowing the tube to sneak out and explode. this hasn't happened to me in years -- not since i used michelin krylions.
  18. #43
    tlg
    tlg is online now
    May 2011
    100 pack Rema . Amazon.EBay. Pretty much anywhere
  19. #44
    Apr 2011
    You must be a fast pumper. I've had one or two close case but as soon as I saw a bulge, I stopped, deflated and re-seated the tire. Now I just do couple strokes of pump, then check around the rim edge, then couple more and check again. If all is good, I go to town with the rest.
  20. #45
    Jul 2016
    maybe. but i can also go sweet and slow.
    i mounted the new tire at home and rode 30 min to meet a friend, where i stopped for 10 min. then we rode 15-20 minutes and stopped for traffic. it blew out while crossing the street. the new tube was quickly inflated with a co2 (in two steps) and didn't fail the rest of the day.
  21. #46
    Sep 2011
    I patch both tubes and tubulars, although I usually wait until I have a few, then do them on a cold, rainy day. I prefer Rema patches, and I buy a box of a dozen of those little glue tubes; the cans always dry out before I'm half done.
    ok share your technique and tools for patching tubulars??
    I want to learn this one. Where do you even get the needle and thread? and do you re-use the base tape?
  22. #47
    Sep 2007
  23. #48
    Nov 2010
    Quote Originally Posted by factory feel View Post
    I bought a pint sized tin of glue and have been patching. I put the patched tube back in bike tire and return new tube to spare status. Seems to be working good and it feels like Iím doing something for the environment. Win win
    Same. Iím cheap. On my commuter the rear tube had 6 patches. Now that I use Mr Tuffy tube liners I get a flat 1/3000km
  24. #49
    Reputation: 11spd's Avatar
    Sep 2015
    Who is patches? This guy....
    https://www.youtube.com/watch?v=IvfsfS6NVUc
  25. #50
    Jul 2016
    another ******* flat today! ****! that's two ******* flats in three ******* days. ****!
    fortunately, today's came a block from home on my return ride. it was a huge bent nail. probably the largest wood nail they sell. unfortunately, i didn't see the damn thing until i plowed over it.
    the tube required two patches, 'cause the nail kept right on going through to the rim. fortunately, no rim damage, but it left a little hole in the rim tape. tire seems good too. we'll see. ****!
  1. Most patches on a tube you are riding?
    By spookyload in forum General Cycling Discussion
    Last Post: 05-09-2006, 02:33 AM
  2. Where to buy bulk tube patches
    By filtersweep in forum General Cycling Discussion
    Last Post: 05-30-2005, 04:37 PM
  3. tubes that cant hold patches
    By naawillis in forum General Cycling Discussion
    Last Post: 04-27-2005, 09:05 PM
  4. Century Patches
    By dudamas1 in forum General Cycling Discussion
    Last Post: 10-25-2004, 02:18 PM
  5. Patches - glueless?
    By Mudman in forum General Cycling Discussion
    Last Post: 08-04-2004, 12:56 PM
