Page 2 of 2 FirstFirst 12
Results 26 to 43 of 43
  1. #26
    Oct 2005
    aluminum does undergo oxidation, not to the same degree as iron, but it does rust
    But not to any degree that would matter for the case being discussed.
  2. #27
    Sep 2011
    Quote Originally Posted by dir-t View Post
    my mtb wheels got pretty much all their nipples corroded after 3 years, so are spoke holes on the rims
  3. #28
    Oct 2005
    Interesting, I wouldn't have expected that.
  4. #29
    Reputation: velodog's Avatar
    Sep 2007
    Yeah, me neither.
    Too old to ride plastic
  5. #30
    Oct 2005
    Yeah, me neither.
    Kinda makes me wonder if the corrosion wasn't from the threaded part of the spokes. Or, maybe more likely, accumulation of salts precipitating from whatever water was involved.
    Was the corrosion accompanied with a light colored powdery substance?
    I actually thought aluminum oxidation occurs very quickly but is limited to a very thin discolored rind that protects the metal from farther and deeper oxidation.
    Edit to add: Yep. Aluminum oxide, Al2O3, forms a stable passive layer that protects aluminum from corrosion or further oxidation. This layer is about 4 nm thick and will provide corrosion protection as long as this oxide layer is stable.
    The Oxidation of Aluminum – Corrosion Pro Articles
  6. #31
    Reputation: Lombard's Avatar
    May 2014
    Absolutely. And aluminum nipples can corrode and snap.
  7. #32
    Oct 2005
    Read my post and link above. I suspect it's something other than aluminum corrosion causing ACL's problem but that doesn't help the OP any.
  8. #33
    May 2014
    ACL's problem is definitely caused by aluminum corrosion. And there is a very simple solution: BRASS NIPPLES.
  9. #34
    Sep 2011
    my nipples got corroded. I pretty found out after 3 years when I needed to have the wheels true. That was when the mech told me all my nipples were corroded and he could not true the wheels unless all the nipples were replaced. There was probably aluminum corrosion and some other sh8t too. Bottomline, my wheels were ruined after 3 years of riding in the wet, wasn't a happy camper. Surprised me the heck outta me too since I never thought aluminum would corrode this fast.
  10. #35
    Sep 2007
    It's my understanding that aluminum oxidation and anodized aluminum basically serve the same function.
  11. #36
    Sep 2011
    speaking of aluminum corrosion. My Dura ace wheelset also got their spoke bed all corroded when I used Stan's sealant. This was a widely known issue with Stan's. The corrosion is really bad too. Stan's has since changed their formula. I'm not sure if the corrosion caused by Stan's is the same type of corrosion caused by water, but Stan's was definitely causing damage to the rim. I still have these wheels to show.
  12. #37
    May 2014
    If Stan's sealant is water based, then sure it could be the same type of corrosion.
    Brass nipples, my friend!
  13. #38
    Sep 2011
    I don't think most off the shelf wheels use brass nipples do they? Don't brass nipples cost more than aluminum? and heavier?
  14. #39
    May 2014
    Heavier? A very minuscule amount (28g on a 32 spoke wheel - whoooopie!).
    Cost more? No, brass costs less!
    Not sure which off the shelf wheels have which type of nipples. My guess is lower end wheels use brass for cost savings and higher end wheels use aluminum for weight savings because higher end wheels need to be able to claim the lowest weight possible in order to fetch the big $$$.
  15. #40
    Sep 2011
    so that's what's up! Hmm I never new that nipples come in alu an brass. I thought nipples are just nipples!
  16. #41
    May 2014
    Nope. Nipples are NOT just nipples:
    DT Swiss Nipples - Wheelbuilder.com
  17. #42
    Sep 2007
    Yeah, not being that concerned about weight I wouldn't even consider aluminum nipples.
  18. #43
    May 2014
    Same here. I am mostly concerned with longevity and being trouble free. I always use brass nips.
  1. Replies: 17
    Last Post: 07-05-2008, 06:21 AM
  2. Why, WHY must the water bottles fly?
    By litespeedchick in forum General Cycling Discussion
    Last Post: 05-19-2008, 05:11 PM
  3. Replies: 27
    Last Post: 04-30-2008, 09:01 PM
  4. Drinking Water or WASTE WATER?
    By MarkS in forum Commuting, Touring and Ride Reports
    Last Post: 05-08-2007, 06:14 AM
  5. Replies: 7
    Last Post: 08-08-2006, 02:00 AM
