Page 1 of 5 123 ... LastLast
Results 1 to 25 of 124
    Jul 2013
    How is through axle stiffer than QR?
    Through axle is an idiotic design - one of several that have become popular in bicycles over the last two decades.
    People talk about the stiffness of the through-axle system because it's thicker. That's horseshit. Such arguments show a complete lack of understanding of the forces involved. Every Tom Dick and Harry who builds products for bikes assumes that bigger diameter automatically equates to greater stiffness. This is reliably true for tubes. But not everything else.
    First, the skinny quick release skewer doesn't support any weight to begin with. Its sole purpose is to squeeze the hub and dropouts together and keep everything in place via friction, hence, it need only have significant tensile strength, not stiffness. The hub itself has an axle of its own on which the dropout sits. It supports the dropouts vertically. While this QR axle is still narrower than the through-axle skewer, it also does not dictate the stiffness of the hub-dropout connection. When squeezed together with the skewer, the larger face of the hub's axle pressed against the inner surface of the dropout is large, as are the faces of the skewer's cam and acorn nut. The SURFACE AREA being squeezed against the dropouts is what ensures that the hub is held in place and unable to move relative to the dropouts, and vice versa. This is what dictates the stiffness of the system. It has absolutely nothing to do with the diameter of the axle traversing the dropouts.
    Furthermore, thru axles must be screwed into place. And anyone with two connecting neurons knows that a cam is a vastly more secure method of maintaining tightness than a screw. The through axle by definition depends on screwing the thing tight enough to create significant friction between the axle and the dropout, which is more difficult to do. It also will produce more damage to the dropout each time it's screwed and unscrewed. A cam merely presses against the dropout.
    Nov 2009
    Shirley you can't be serious.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Quote Originally Posted by Waspinator View Post
    People talk about the stiffness of the through-axle system because it's thicker. I don't get it. It doesn't make sense.
    The quick release skewer doesn't support any weight to begin with. Its sole purpose is to squeeze the hub and dropouts together and keep everything in place via friction. The hub itself has an axle of its own, on which the deop
    Short answer: it isn't just the axle, it is how the system interlocks the frame which results in a stronger system....which becomes a bigger deal as you do rougher terrain. Of course, the simple-stupid disc-brake alignment is a nice thing as well.
    Everything you need to know about Thru Axles - The Buzz
    Last edited by Marc; 06-05-2017 at 06:33 PM. Reason: To preserve the OP when he isn't hammered, given his troll in General
    Forever a Student
    Mar 2014
    Is it better to clamp or bolt a bench vise to a table?
    use a torque wrench
    Oct 2014
    I have two very similar bikes. BMC Gran Fondo GF-01 (QR) and BMC RoadMachine RM-01 (12mm Thru Axles).
    I'm a big guy (6' 5", 225lbs). I have an otherwise identical set of wheels for each bike (HED Belgium Plus on White Industries hubs, 25mm GP4000IIs tires, same inflation). I think the most obvious place I notice the thru-axles is in tracking on the high speed corners. I'm not sure I can explain why exactly, and some of it could be down to (very minor) geometry differences, but the Road Machine just feels much more locked in and steady on a high speed descending corner, and it's very noticeable.
    Jul 2013
    My through axles don't have cams.
    But even if they did, my point would remain the same.
    Think about the connection points between the axle and dropout.
    The actual axle of a QR hub (ie the center around which the hub/spoke/wheel rotates) is actually quite large, and this is what is pressed tightly against the inner surface of the dropout. The small extension that sits in the dropout merely suspends the dropout on the hub. But The stiffness comes from the large area of interface between the face of the hub axle and faces of the dropout.
    Does anyone have any PROOF that through axle is stiffer? Research?
    Jan 2005
    Lastly, need I even mention the issue of the threads in the opp
    A) No. It isn't.
    2) It is horseshit to claim the axle diameter is why it is stiffer (in all but extreme 15mm+ TA diameter and XC/MTB riding). BUT...your POV is horseshit that QR is just as stiff...because clearly you don't understand why thru-axle is the way it is.
    In the last 1-2 hours you went from not knowing why TA was stiffer than QR...to suddenly being an expert. I'm sure I speak for the entire internet, in that we all bow to your superior wisdom and knowledge gained in the last hour.
    And, quoted for posterity.
    is riding in MOPP4
    Reputation: Tachycardic's Avatar
    Mar 2013
    Take your meds. Just sayin'...medicine is good.
    Wake me up when it's alarm green.
    Oct 2013
    Must have scratched his paint, somewhere where you can't see it.
    BANNED
    Jan 2005
    He must have been PISSED when Apple moved on from PowerPC architecture.
    Reputation: BCSaltchucker's Avatar
    Jul 2011
    Model T was actually a pretty good car, and most folks could figure our how to use it eventually. No need to change the whole way we shift the gears on an automobile like 3 pedal 1916 Cadillac wanted us to do
    And really flip flop rear wheels enabled racers to complete many Tours de France just fine. Ridiculous idea to give them more gears with a derailleur to shift them.
    Heck toe clips and straps were highly favoured by many pros after the clipless Looks appeared .. Heck Roche stuck with clips and did the triple crown. No one since has matched that feat ... must be because they are all on this clipless pedal nonsense.
    I half agree with the OP. It is a very subtle advantage having thru axles on a road bike. It is a major difference on a mountain bike. I am more than happy with QR on my road bikes. for now. and yes one of my road bikes has disc brakes (well it is a gravel bike)
    Cycling Addict
    Nov 2013
    One advantage to through axle setups is that the wheel will always be correctly aligned - which will help prevent the rotor from rubbing against the brake caliper or pads.
    Life is short... enjoy the ride.
    Nov 2015
    Quote Originally Posted by bradkay View Post
    Disc/wheel alignment isn't an issue with good QRs. The issue is that most bikes don't have good QRs (the closed cam Shimano or DT Swiss style, not the exposed plastic/aluminum setups). I ran my disc MTB with f/r regular QRs for years without issue, at least once I put XT skewers on it.
    My road bike has regular QRs, but one of my MTBs has Boost thru-axles front and rear, and the other a 15x100 up front ('upgraded' from a regular QR). There's no tangible advantage to any of it. Sure, like BB30, it's technically stiffer. The issue is that 9/10mm QRs are plenty stiff already, especially for a road bike. I file this in "new and improved, but really to sell more things".
    Dec 2011
    Since you're not backing up your stuff with scientific facts I will answer with a non scientific reply,just a very practical one. I love my TAs, my bike is a lot stiffer and an 83kg guy like me can totally feel the difference. And yes I run discs too.
    Perhaps my two neurons have disconnected but I'm pretty sure a quick releases has a cam AND screw holding it tight.
    Excellent rant though.
    Nov 2015
    Both thru axles and standard QRs have cams and threads. In addition to just being thicker, a thru axle replaces the nut on the end of a regular skewer with threads in a frame fork. They're functionally pretty much identical; one is just bigger and beefier than the other. The only real difference that I've noticed is that thru axles (at least the half-dozen that I've owned) have a tension adjustment as well, be it an allen screw on the lever side or something built in to the threaded side of the fork.
    I guess one safety advantage of a thru axle is that it can't really drop out of a dropout like a loose QR can. If I recall correctly, this was the main reason why DH MTBers started using these things years ago. It's also supposed to stiffen up suspension systems (which makes sense), though I've never been able to tell a difference. Again, I'm sure it's measurably stiffer in a lab and probably more durable under extreme DH MTB race conditions. On a fully rigid, stiff-as-hell road bike that rides on mostly smooth surfaces though? Meh.
    Forever a Student
    Mar 2014
    For the QR fans, I'm pretty sure you can buy thru axles that have QR cams in addition to their threads.
    https://paulcomp.com/shop/components...quick-release/
    Have the cake. Eat the cake. Still have the cake? You decide.
    use a torque wrench
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Sigh.
    No need to read beyond here. Cause you clearly CLEARLY have no comprehension of the forces involved or reasons for the stiffness.
    I have no dog in the fight. I'm an engineer. I have MTB & Cross bikes with Disc and QR's. They're fine for me and the majority of the population.... BUT there's no question that Through Axle is a superior design.
    The only issue with Through Axle is standardization... but that's a different topic.
    Nov 2015
    Just wait until Boost spacing makes its way over to road bikes.
    Apr 2017
    Sunday morning after Derby, saw two bikes chained to poles with the front wheels stolen.
    QR invites theft. Axles needing tools are too complicated for thieves. I threw the QR hardware away from my bikes, and carry wrenches, tubes, a pump. Thieves can't be bothered to break into my tool kit to remove stuff.
    I use a 10-32 x 5" SS cap screw through the axle with washers & elastic stop nut. Replaced the weird thread QR nut that fell off & required me to gingerly pedal home with a loose front axle, dodging holes and stopping for railroad tracks.
    On the *****y supply front, ordered some weird thread axle nuts from an internet supplier a week ago and still don't have a shipper tracking e-mail. They were allegedly in stock. Pay pal was debited right away. Mcmaster.com the industrial screw supplier doesn't debit until the box ships.
    Jul 2013
    Clearly?
    Well then, professor, why don't you educate me? Let's see if you do.
    'brifter' is a lame word.
    Clearly?
    You probably wouldn't have the ability to understand if he did. Just trust him because he is an engineer...do you require proof for everything you're told? The fact that thru axles guarantee you'll have consistent wheel positioning in the fork/frame and that your rotor will always be lined up properly in the caliper is reason enough to use them. There are more than one variable w/ a q/r that can affect the wheel being properly installed in the dropout. If a mechanical engineer were to tell me that they're better for other reasons as well, I'd most likely believe him.
    I work for some bike racers
    and a bunch of skateboards
    tlg
    tlg is online now
    May 2011
    Clearly?
    https://www.topuniversities.com/cour...chanical/guide
    Nov 2015
    I've never understood this issue, let alone experienced it when using quality items. Fully seat the wheel in the dropout and flip the lever closed. Done. It's not going to move, and it'll be centered every time, just like a thru-axle.
    The only time I've had an issue with a QR not holding a wheel securely or consistently was with a Gunnar steel frame and shitty Stan's QRs. The cheap, soft aluminum on the skewer couldn't get purchase on the frame. It was so bad that it'd even slip/move under power. On the thru axle side, it took a few rides to properly center the front wheel on one of my MTBs with a 15x110 front axle. The culprit was not enough tension dialed up on the tension adjuster built into the threads on the fork. Just like a regular QR, if it's not sufficiently tensioned, it'll have issues.
    Reputation: Lombard's Avatar
    May 2014
    This.
    Also consider that disc braking forces put tremendous torque on your hubs which can pull your axle right out of your fork on a QR. Not so with a thru-axle.
    -- Warren Buffett
  1. Thru axle vs quick release
    By deviousalex in forum Cyclocross
    Last Post: 07-21-2014, 10:43 AM
  2. Replies: 15
    Last Post: 07-17-2013, 08:55 PM
  3. Vastly improve @ Caloric maintenance/deficit
    By grayson in forum Racing, Training, Nutrition, Triathlons
    Last Post: 07-08-2009, 12:30 PM
  4. Replies: 20
    Last Post: 03-19-2008, 06:48 PM
