Results 1 to 5 of 5
    Sep 2008
    Are 2012 TCR Advanced SL ISP Di-2 Ready?
    thinking about buying an 2012 Advanced SL ISP frame, and build it up with my di-2. I heard they are Di-2 ready, with internal cable routing, is that true?
    Thanks!
    May 2005
    Yep they are. Check out the review on bikeradar.
    Sep 2008
    Thank you for the info.
    Reputation: meezo's Avatar
    Jul 2011
    Question guys, sorry if it already has been mentioned, but when i run my brake cable through my TCR Advanced 2012, do i run it with 5mm housing, it seems to go thru and then stuck just before the exit, when i tried to pull out the cable and run through the other-side, it was jammed, and had to use the spoke method to get out.
    I haven't received any cable stops for the rear brake cable like i have for my derailer cables.
    Jul 2011
    Quote Originally Posted by meezo View Post
    ok found reply on other thread my bad
Sea Otter Classic
Contest
