Results 1 to 6 of 6
    Feb 2016
    Giant SLR 1 wheels hub
    Is the Giant Wheel Hub made by DT Swiss ?
    I found this link
    http://www.sykkel.com/teknisk/GIANT%20WheelSystem%20Service%20Info_V01.pdf
    and the hub during then seems to be DT Swiss 240 and 350.
    I got a SLR1 disc road from my TCR Adv 1 that I am using if it is DT switch 370. Trying to service the hub.
    Perma-Newb
    Dec 2009
    Yes, it is made by DT Swiss for Giant and uses a DT 360 hub internal (pawl driven, not star ratchet).
    Hope it helps!
    Aug 2017
    SLR 0 = DT 350 Hub (Ratchet, 18T I think)
    SLR 1 = DT 360/370 (Basically the same hub as above, but different freehub body and drive ring. 3-Pawl system. Can be upgraded to the ratchet system but you need special tools to uninstall the old drive ring and install the new drive ring plus the ratchet kit of course)
    Feb 2016
    Hope it is going to be useful for others.
    See https://dycteyr72g97f.cloudfront.net...WEB_EN_001.pdf
    The front hub looks like the hub in Page 11.
    The Rear hub looks like the one in page 36.
    Front hub bearings are 1 x 6802 (24x15x4) and 1 x 6902 (28x15x7)
    Rear hub bearings are 2 x 6902 in the hub. I dunno what is in the freehub.
    Gonna replace the bearing with Japanese bearing.
    However, one of the rear hub bearing seems to be blocked by the ring nut, and I don't have the special tool to remove it.
    Feb 2016
    Hope this can be useful for others.
    Below is the bearings in the freehub in order. 6802, snap ring, alu spacer, 6902.
    I have since replaced them with NTN non-contact seal bearings.
    Jun 2017
    Thanks for the info, ongbenghui.
  1. Why isn't an SLR an SLR an SLR?
    By Cheers! in forum Components, Wrenching
    Last Post: 07-06-2007, 09:21 AM
  2. SLR vs. SLR XP
    By TACSTS in forum Save Some Weight
    Last Post: 12-30-2005, 02:14 PM
  3. White SLR or SLR Carbino or SLR XP
    By TZL in forum Components, Wrenching
    Last Post: 09-29-2005, 08:28 AM
  4. SLR vs SLR XP
    By deastin in forum Components, Wrenching
    Last Post: 03-24-2005, 05:24 AM
  5. Selle SLR vs SLR XP - worth the change?
    By Tommasini in forum Components, Wrenching
    Last Post: 07-26-2004, 09:05 AM
