Results 1 to 2 of 2
    Jun 2013
    Giant TCR ISP problems! Help!
    I've bought a giant TCR with ISP second hand. The previous owner had trimmed the seat, so I've added 7.5mm of spacers to make it fit me. Initially I had no issues. I moved the seat backwards slightly along the rails and since then my problems began! Basically one day when riding I noticed the spacers rattling together. When I stopped to check, I could see a gap between the top of the seat post and the first spacer, so they were able to move around. So what seems to be happening is that the clamp is able to move back and forth, even when tightened to 4Nm. I will tighten the clamp, however I assume that when I move my weight back on the seat, the clamp just slips. So here's what i've tried:
    - Running just one 5mm spacer - the seat still moves, there is just no rattle heard
    - Swapping clamps - the longer clamp seems to hold a little better, but still slips
    - Friction paste on the post - no difference
    So basically I want to know - is this a common, known problem with the giant ISP clamps? Has anyone else had this problem? What can be done to fix it? Are there alternative clamp designs that will fit my seat post? Any help/advice is much appreciated!
    Jun 2013
    1st thing to check is the flatness of the cut that was done on the ISP. Hopefully you got the cutting guide with your frame cause that makes this much more accurate to check. The cut needs to be perpendicular to the seatpost, not horizontal to the ground. Also, after cutting, I used 400grit sandpaper on a sanding block to make it perfectly flat with the cutting guide. It ended up lowering the seat clamp by ~2mm more than the initial cut, by the time I got it perfectly level, but then the seatclamp has even pressure on the spacers and shouldn't ever rattle loose.
  1. 2003 Giant TCR 1 vs. 2007 Giant TCR C3
    By friendgman in forum Bikes, Frames and Forks
    Last Post: 06-30-2012, 05:39 AM
  2. Giant OCR3 Vs Giant Avail
    By MelAnnie in forum Giant
    Last Post: 01-29-2011, 11:32 AM
  3. Giant Frame Question(tried the giant discussion but no one responded)
    By osky in forum General Cycling Discussion
    Last Post: 10-22-2009, 03:41 PM
  4. Replies: 28
    Last Post: 10-13-2009, 06:16 PM
  5. Giant OCR Composite 3 VS Giant TCR (Aluminum) 1
    By Cnumb in forum Bikes, Frames and Forks
    Last Post: 05-07-2006, 06:37 AM
Sea Otter Classic
Contest
