Results 1 to 6 of 6
    Dec 2011
    Hiding a Shimano junction box on a TCR ?
    Here,shoot your best ideas.
    I'm fed up with that thing dangling under the stem,so any suggestion is greatly appreciated. Please do not spare details like if I may end up in need to have some new longer connecting cables.
    Forever a Student
    Mar 2014
    They have new ones now that go in the end of the bars in place of the bar end plug.
    use a torque wrench
    Dec 2011
    Yeah I've thought about that but one needs a proper bar,right ? I mean,you need to need to be fully internal cable all over the bike I guess.
    Forever a Student
    Mar 2014
    Quote Originally Posted by Devastazione View Post
    It would need any of the bars that have the internal routing that are out now. With a hole by the shifter and a hole before where the bar clamps. Wire would run next to rear brake housing to exit.
    Do you have a Garmin mount out front? If so they can hang off the bottom.
    Pointing backwards.
    use a torque wrench
    Reputation: rtalain's Avatar
    Dec 2009
    I took mine off my stem and moved it to the bottom of a BarFly mount. I looked at the bar end junction box, but couldn't bring myself to swap out bars just to hide the box; plus, I would have to buy new (or extend) the current cables to reach the bar end.
    People have also mounted them under their saddle as well, which requires you to drill a hole in the top of your seat post, and I'm not sure if the guy had an internal battery in his seat post or not.
    Dec 2009
    And here's a photo of the setup under the saddle. It's a TT bike though, and the oval seatpost probably allowed room for the cable to get past the internal battery.
    Hiding a Shimano junction box on a TCR ?-165924338.3yxv9cmx.cloakanddagger53.jpg
  1. Dura Ace Di2 Junction Box clip replacement?
    By iridepinarello in forum Shimano
    Last Post: 12-08-2014, 12:00 PM
  2. Di2 Junction Box Hanger
    By blairellis in forum Specialized
    Last Post: 11-25-2014, 06:54 AM
  3. Replies: 5
    Last Post: 04-17-2014, 12:32 PM
  4. Shimano DI2 install. Should I wrap internal junction box B?
    By Billrush in forum Components, Wrenching
    Last Post: 06-01-2013, 03:36 AM
