Results 1 to 8 of 8
Thread: Garmin Vector
    Jan 2009
    Garmin Vector
    Some AU sites have the Garmin Vector for an introduction price, e.g., http://www.pushys.com.au/garmin-vector-powerpedal.html for 1450 AUD.
    They ship to the USA (and other countries) and according to an e-mail from their support there is no problem with warranty.
    I wanted to buy it but it turns out the Vector does not fit on my bike :-(
    Reputation: difficult's Avatar
    Aug 2008
    Why would you think that the Vector does not fit on your bike? What kind of cranks are you using?
    Jan 2009
    The Garmin Vector owner manuals states:
    "NOTE: There must be at least 5 mm clearance between the chain and the crank arm."
    when the chain is on "the largest chain ring and the smallest cassette gear."
    For my bike it is less than 4mm (a bit more than 3mm).
    Aug 2008
    That clearance is so the pedal pod does not contact the chain. As the pedal pod is on the outside of the crank I believe you can use a few of the washers included in order to gain enough clearance.
    Jan 2009
    (seems this discussion would be better in a different subforum, but anyway...)
    There's a "rubber cable" on the back of the crank arm that connects the pod to the pedal spindle.
    As can be seen in the video:
    Ensuring_Vector_fits_your_bike
    Garmin "recommends" at least 5mm clearance so the chain does not rub against (and damage) the cable.
    On a bad road surface this can probably happen rather often if there is not enough distance between chain and cable.
    Looks like that's a good reason to follow Garmin's recommendations for chain clearance.
    As someone wrote elsewhere: "why isn't the pod integrated into the pedal?"
    That would resolve this problem...
    However, using two different parts makes it simpler for Garmin to implement this power meter with different pedals (requires "just" a new spindle, not a complete pedal).
    Moderator
    Sep 2007
    Quote Originally Posted by Got Time View Post
    I would guess:
    • Not enough space for the electronics - costly/impractical to make it fit
    • Standard batteries won't fit inside the spindle
    • And the biggie ... ANT+ wireless transmission from inside a metal spindle and obstructed by a shoe and foot is not good
    I'd think that the cable could be taped to the crank to reduce risk of rubbing.
    Old La Honda in less than 20 minutes! Or you can watch race video from the low-key hill climb on Welch Creek. More at www.biketelemetry.com.
    "I think," said Christopher Robin, "that we ought to eat all our Provisions now, so that we shan't have so much to carry.", Winnie-the-Pooh, A. A. Milne.
    Jan 2009
    Well, the question was: "why isn't the pod integrated into the pedal?"
    Note: "into the pedal", not "into the spindle".
    The pedal body could be modified to house the electronics and battery, but see my previous posting why that isn't such a good idea from a commercial point of view.
    Moderator
    Sep 2007
    Oops, sorry. I see what you mean now.
  1. Garmin Vector in September?
    By genux in forum Components, Wrenching
    Last Post: 08-09-2013, 08:09 PM
  2. Garmin comments on Vector
    By 67fb in forum Racing, Training, Nutrition, Triathlons
    Last Post: 08-11-2012, 03:00 PM
  3. Garmin Vector Pics
    By pumaking in forum General Cycling Discussion
    Last Post: 06-25-2012, 10:25 AM
  4. Garmin Vector!!!
    By MaddSkillz in forum Components, Wrenching
    Last Post: 06-14-2012, 09:08 AM
  5. Garmin Vector Question
    By RyanM in forum General Cycling Discussion
    Last Post: 04-22-2012, 02:15 PM
