Results 1 to 4 of 4
    Sep 2005
    Need replacement Li-ion Battery for L&M Stella
    I need a replacement tricell Li-Ion battery for my L&M Stella 200L. They usually list for $149.95 which is about 60% the cost of the whole light.
    Anyone have a lead on the best prices for L&M replacement parts?
    Sam in Cincy
    Nov 2001
    If you can't find anything, you might want to consider purchasing a magicshine for $80 or $90 and having a much brighter light where replacement batteries cost about $37.
    This coming from a former L&M seca 400 user, who sold the seca for $175 and then purchased 2 magicshines. I'm much happier now, having multiple lights as I only use 1 set on a ride, but I commute several times a week by bike.
    Rookie
    Mar 2010
    agreed on the magicshine...
    check them out at geoman gear or something like that... otherwise, without doing a lot of searching for the battery for the L&M i ddi see its an 11.1v 3 cell battery... I have purchased from these guys in the past when i built my own light. Just cut off a solder your old connectors, and you should be golden...
    http://www.batteryspace.com/11.1V-40...y-Modules.aspx
    or something like this...
    http://www.batteryspace.com/customiz...connector.aspx
    Customize Polymer Li-Ion Battery: 11.1V 1500 mAh (16.65wh) with KPP-4 P connector (1.35)
    Sale Price: $32.95
    Wayne
    Reputation: ChilliConCarnage's Avatar
    Jun 2006
    +++1 on the MagicShine from Geomangear. I've bought lots of lights in the past, and now I roll exclusively with a couple of MagicShines. So cheap you can buy a bunch if you want to!
    Cervelo Soloist Carbon / Specialized Roubaix Disc / Look 585 / Look 555 / Kona Kapu / Spec Carbon Camber 29er 1x11 / Surly Straggler / Fuji CX / Steel SS
    Over 60 bikes owned over the last 20 years!
