Results 1 to 12 of 12
    Jan 2010
    2012 Windsor Wellington 3.0 reviewed
    Hey, All. Just returned from my second ride On my son's new Windsor. I bought one 3 years ago which now has 7,500 miles on it, and my 15 yr. old son was desiring a "real" road bike. He is 6 feet 192 lbs, I am 5'11'' and 165 lbs. We both have the 59cm. The box looked great and all the parts looked good, well packed. My bike was made in Taiwan, this new one is made in China. My bike came with toe clips, this one has flat pedals, which I know it might. The stem and handlebar on this new bike are HUGE, and I will be replacing them. I assembled it and dialed it in pretty well, though the wheels needed to be trued quite a bit. I was experiencing some noise from the rear derailleur and had some trouble in the front going from the middle chain ring up to the large and back. After our first 10 mile ride we stopped by our LBS to have them look at the derailleurs. They managed to remove the noise from the rear but determined the space between the middle and large chain rings was too great, causing shifting problems. I was reminded that when I set things up, the chain actually fell between the two rings and got stuck! Fortunately the fix was simple- remove some of the spacers between the rings and reduce the distance.
    All in all, it has some problems that can be worked out, but for $400 it will be a great bike! Crappy saddle, terrible brake pads, cheap tires, fix a few issues and you still will have a good bike for not too much money! Hope you enjoyed the review.
    Jan 2010
    A few more thoughts
    Two more comparisons between the 2009 and 2012 models. There are now indicator arrows at the top front of the hoods that'l let you know which chainring and approximate cog you're in which is pretty cool. On the downside, the barrel adjusters for the brakes are no longer knurled but are now conical chromed cylinders which are difficult to turn.
    Apr 2010
    My girlfriend's Motobecane that we bought in early 2011 was made in Taiwan. My Gravity Liberty 2 is made in China.
    The Gravity had bent rims and a couple other issues. The Moto was perfect right out of the box, aside from the normal setup needed.
    The box for the gravity was sort of beat up, so I assumed it was damaged in transit. But, I wonder if it's because it's from China, not Taiwan? I wonder if the Taiwan bikes are put through stricter quality control?
    I generally find Taiwanese products to be better than Chinese products.
    2011 Gravity Liberty 2
    2010 Trek 7.1 FX hybrid
    2011 Motobecane Grand Record (GF's bike)
    2007 Giant Boulder SE (GF's bike)
    Jan 2010
    Agreed!
    Stephen, I couldn't agree with you more. I bought a Motobecane ti Heat in Sept. of 2010 which was Taiwanese and the quality is fantastic. I am a little disappointed with the Chinese Windsor, but whaddya gonna do? I look at it like this- you buy a bike for $400, put another $100-150 in upgrades and fixes, and you've got a bike comparable to a $900 Trek or Cannondale. Still a good deal.
    Jul 2012
    I just bought a Windsor Wellington 3.0 from Bikes Direct.Fuji Kinesis Fame, Fuji Kinesis Carbon Forks. The rims and tires that came with, along with the seat and chain where krappy. New Vuelta XRP Aero rims, Kenda Kaliente Iron Tyres, Sella Max Gel saddle. HOLY ****!!! What a Rocket Ship......Cheap ....Kicks Major Ass. Buy a spare tube and a pump, 'cause you will be riding.
    Idiot at large
    Apr 2010
    got mine in June.... definitely didnt have vuelta rims....(it's not advertised to have it) the paint on the braking surface doesn't help you to stop
    it did come with kenda tires, but not the kaliente iron cloak. just some generic kenda 700x25c tires
    the seat sucked. the first thing I did was put a new seat on.
    2010 Specialized Secteur Elite upgraded with 32T cassette and does not have Stan's (yet)
    2009 Specialized Rockhopper Comp 29er upgraded with 36T cassette and Stan's Arch EX rims and tubeless. Considering a 1x10 upgrade
    2013 Cannondale CAADX-6 Tiagra upgraded to 32T cassette and Stan's Alpha 400 rims and tubeless
    2008/2009 Burton T6 156cm with Burton Triad Bindings & DC Judge boots
    Aug 2012
    Looks good. What made you get the wellington over the liberty 1?
    Aug 2012
    good looking bike
    Idiot at large
    Apr 2010
    Quote Originally Posted by preslove View Post
    I didn't like the look of it.... the way the seat stays don't really meet up with the top tube
    Aug 2012
    Just bought Wellington 3.0
    Just bought my first road bike and took of on two 5 and 10 mile rides. Wow what @##@ing workout. alot of fun.
    I have nothing to compare to the Wellington 3.0. I pedel and it goes, seams to shift gears easly and is not that heavy of a bike. For 300 of craigslist so far i say it was worth it.
    Jan 2014
    I just put in the first 100 miles on my Wellington 3.0 this month, and it's going great so far. I took it to the local co-op for assembly, where they helped me spend a bit of time re-greasing and truing the wheels. Otherwise, it was pretty quick to throw together.
    I swapped out the brake pads after the first week with the low-end pads off Amazon. That's made quite a big difference, but I'm still a little skittish on steep downhills. I also put in a larger stem for a better fit (I have a long torso). Otherwise, I plan on keeping the rest stock for a while.
    The biggest downside so far is the front shifting (rear works great after a quick adjustment). The middle gear rubs too much when used with the larger gears in the back, and I can't figure out how to adjust that. Also, downshifting the front gear gets _very_ difficult at the end of my ride. Sometimes my left thumb just can't push the tab hard enough to engage a shift, and I have had to resort to using my right hand.
    Overall, it was the best way I could find to dip my toes in the road biking waters without breaking the bank. I've learned a lot in just this month, and I'll see where I'm at in a few months to see if it's worth going all in on a nicer bike.
    Jan 2010
    Vince,
    It sounds like your front derailleur cable has stretched a bit (normal) which may be the cause of your shifting problems. Try to tighten the cable by turning the barrel adjuster a bit- you should actually be able to see the derailleur move closer to the center of the chainring. Hope that helps!
Sea Otter Classic
Contest
