Results 1 to 25 of 33
    Feb 2009
    Do I need a better base layer or a heavier jersey?
    Hi,
    Trying to extend the riding season a bit. I am in central Massachusetts and my chest is getting chilled after 30 minutes in mid-40* weather. I tend to be on the cold side, I think slow metabolism. Am hoping to ride into the high 30's. After that we'll have snow on the ground and that is too hard core for me.
    I have a Cannondale jacket that is fairly windproof - it was the heaviest one on the rack when I bought it this past April. I wear that with an aging thermal undershirt (not cotton, some synthetic fabric). No jersey as the ones I have are all short sleeved and meant for warm weather.
    I suspect I may need an improved base layer, but wonder if a long sleeved jersey would be a better way to add layers so keep the old thermal shirt and add the jersey. Are the long sleeved ones heavier than the summer weight jerseys or just as lightweight?
    I am currently unemployed. Although not destitute I am trying to make a careful purchase here hence the debate about base layer vs. a jersey.
    Also, Is this a decent base layer??:
    http://www.underarmour.com/shop/us/e...ew/1004600-418
    Hope you can help....Mike
    Nov 2006
    Heavy baselayers help, a windbreaker helps, heck, just a cotton shirt between layers will help.
    If you're looking a baselayer, this thread has some deals. Craft Pro Zero Long sleeve Base
    Jul 2009
    layers layers layers. if your chest is the problem, maybe just throw a short sleeve jersey on over the undershirt.
    and on a budget....check out one of those 'Ross' stores if you have one near you. they always seem to have some reebok/underarmor/nike undershirts for $10 or so. made for football, but itll have the same wicking properties as some $80 undershirt at your LBS. i have a couple and they've been great through some cold colorado days (sub 30*) so far.
    Jul 2009
    Quote Originally Posted by nomit
    Exactly what I was thinking. Or any other sort of layer -- even a t-shirt. The outer layer will block the wind, the inner layers are to help keep your heat in. It's better if they're a little loose, though, as the air between the layers is what helps insulate.
    Asad
    Oct 2007
    Quote Originally Posted by asad137
    Asad
    Definitely. I might posit that the base layer and the top layer are by far the most important/ I personally prefer to wear a fleece-lined or wool shirt underneath my outer layers even if the shirts aren't super fancy new-fangled materials. When its really cold, its more important that you keep your core nice and warm.
    May 2007
    I had the same problem with my chest getting cold....and I bought a craft Wind Stopper base layer and it's works great. It has a windproof shield in the front that keeps you warm.
    http://www.craft-usa.com/cra_shop_zo...id=489&bcsex=m
    Dec 2004
    You can try to look for some merino wool shirt from Target to keep your core warm. And you need something that is 100% windproof on the outside. Also wear a scarf or buff around your neck to prevent air from entering from that end.
    Jul 2008
    DO NOT spend $40 for Underarmour. That money would be far better spent with one (or two) of these: http://www.probikekit.com/display.php?code=C0988 use the code 10pbk and get another 10% off. Craft is awesome. I hate the compression feel of the Underarmour as it chaffes my chest hair and nips.
    Get the Craft base layer and then layer on top of that with long sleeve t-shirts or even a sweatshirt and top it off with a windstopping jacket. As someone else said, start with a good baselayer and a good outer shell. You can add regular clothes in between until you get the temp right.
    I have a vest I got from Performance. It's windbreaker fabric on the front and mesh on the back. Keeps my chest nice and warm...
    Banned forever.....or not
    Aug 2002
    More layers, thermal jacket, or ride harder.
    Dogbert.
    I>U
    Sep 2005
    Quote Originally Posted by ptfmb71
    I have the same.....keeps the cold of my chest, no need for a heavy shirt or jacket. just wear a shirt and vest to adjust your temp without wearing any heavy crap.
    Jul 2008
    Quote Originally Posted by gormleyflyer2002
    How does Craft run in sizing?
    Sep 2005
    generous compared to most Euro sizing if i recall........i'll check tonight when i get home.
    i'm a mutant (6'6")
    Impulse Athletic Coaching
    Reputation: iliveonnitro's Avatar
    Feb 2006
    FWIW, a thick "jersey" worn on the outside of a short sleeve jersey (or base layer, etc) can be used multiple times before needing to be washed, saving on laundry and hassle of buying 4-5 base layers that make up for the one thick jersey. It would be the more practical purchase, imo.
    May 2007
    Quote Originally Posted by rydog9991
    I bought a medium and it fits true to size. Pretty much every jersey I buy is a medium and this fits well.....snug
    I am 5-9 143 lbs
    VIP
    Reputation: saird's Avatar
    Aug 2008
    Newspaper.
    Jul 2009
    I am 5-9 143 lbs
    I have a Craft Pro Zero base layer in medium and it works well for me too, 5-8", 175 lbs, 40" chest, ~30-31" waist. Sure, it's a little snug across the chest but not uncomfortably so (the material is very stretchy), and a large would be too baggy everywhere else.
    Asad
    Reputation: multirider's Avatar
    Nov 2007
    These are great -- don't add to sweat in the small of your back or overheating arms:
    http://www.thewarmfront.com/main.html
    http://www.cdisports.com/index.php?m...roducts_id=268
    Jan 2009
    I was out shopping for a good base layer and went to all of the local sports stores and decided to stop at Ross just for the heck of it. I found a Reebok long sleeve base layer for $4.99, I have very long arms and it fit so great I bought two of them. Beats $45 bucks at the sporting goods store right next door.
    When it gets chilly here I'll wear a polypropylene base layer under a short sleeve jersey, my next step is a long sleeve jersey instead of the short. When it's downright cold I'll wear a windproof vest over the two layers, it has sleeves that can be zipped in and out but typically I leave them out. My problem with the windproof stuff no matter how high tech it may be is I sweat much more and in turn get colder on the longer base mile rides.
    Dec 2002
    try foxwear lou makes custom stuff very reasonable
    Feb 2009
    Guys, thanks for all the replies. I'll take a look at the Craft stuff and the other suggestions.
    Usually have been a warm weather rider but I test rode the new bike I bought this year in February and was amazed riding in mid-30* temps wasn't all that bad.
    My wife, the frugal one, likes the newspaper idea best.
    Best regards...Mike
    Feb 2009
    Quote Originally Posted by mikefm101
    Under armour is TERRIBLE for riding. TERRIBLE. You can wear ten of them and freeze your butt off. What you need is a craft base layer. http://www.craft-usa.com/cra_shop_zo...id=543&bcsex=m
    They are so warm. I wear a craft baselayer and a long sleeve jersey. That keeps me warm down to thirty degrees, if I'm wearing a headband as well (and gloves, booties, etc). Seriously, this was one of the top five cycling items I have ever bought.
    Nov 2007
    Quote Originally Posted by kreuzberg
    Wow!!! $70 for a base layer!!
    The WarmFront that I recommended previously looks like a steal! $25 and easy-on-easy-off during a ride. Does exactly what the OP requested, too -- keeps the chest warm.
    I'm sure the Craft piece is great, but that is a big chunk of change for a base layer.
    Jan 2009
    cotton t-shirt long sleeved sweatshirt and your jacket should be plenty. loose fitting clothing is much better than tight fitting clothing. You're thinking too much.
    Feb 2002
    Cotton? Really?
    Quote Originally Posted by g-dawg
    A cotton T-shirt, or cotton anything, will just get wet and stay wet. Cotton is a very poor choice of fabric for cold weather exercise.
