Cycling Boob
isnt endurox a recovery drink? makes no sense to me eithe rbut i just follow the directions and drink accelerade for my cycling
pinoy thunder
Endurox is quite heavy in the stomach.
Mi piace la mia pasta al dente..
I've actually used Hammer's Perpetuem...basically an endurance electrolyte drink that also has protein. Muscles get fed while the "gatorade" like component of the drink keeps hydration and energy high. No cramping, no next day soreness.
Taste isn't terrible, but definitely takes a few ounces to get used to it.
Exactly. That's why it would be horrible to drink on the bike. 270 calories per serving is a lot.
Some guy
You could probably get away with Endurox on the ride, but you'd need to train with it first and you'd need to be going at a reasonably low intensity. Otherwise that heaviness isn't going to sit well. But then, if you're doing 24 hours you'd have to drop the intensity.
Everything breaks down once you get into the 6+ hour range. Things you thought would taste good, simply don't. If you don't occasionally train in that time frame you may have a tough time of it once you get there. Solid food is almost always a must on the longest rides.
I quit using Endurox the last few weeks and I feel there is a noticable difference in next day soreness. I also feel there is a cumulative effect that is causing my riding to stall a bit. Timed climbs that have been improving thru the summer are slipping back. I stopped because I was interested in switching to the Hammer products and haven't got around to it-but I'm convinced a recovery product is worthwhile. And no, I don't think I'd use it on the bike. Enough folks have trouble with Accelerade and digestion, I'm sure Endurox would be even tougher.
Cycling 4 Life
Has anyone tried Pedialyte as a substitute for hydration during rides?
Coming to this from a running background and just starting into biking for triathlon training; I've used endurox and accelerade as recommended by the manufacturer and couldn't tell any difference between the two. However, I did find that using them definatly made a difference to my after workout exhaustion and recovery. So I saved the money of buying both and just stuck with the endurox.
At the present time I use Cytomax but never had any problems with the Endurox products.
consuming some whey protein during longer rides (or any multi hour athletic endavor i.e alpine climbing) - along w/ water and a energy drink - is a great idea
- You may not post replies
- You may not edit your posts
Forum Rules
