Results 1 to 8 of 8
    Reputation: gigemaggs99's Avatar
    Aug 2004
    knee warmer question
    Can someone tell me how to size knee warmers? When I look at the sizing charts for Pearl Izumi or at Perfomarnce.com it does not give a sizing chart for knee warmers. Any ideas?
    If anyone knows how to size legs warmers please pass that along too.
    Thank you!
    Travels by Map
    Reputation: nate's Avatar
    Jun 2004
    If you can't try some on at a LBS, I would suggest you look at what size you would need in tights and then go with the same size in warmers. For instance, if you wear medium in tights, then go with that size.
    rock n rolling resistance
    Reputation: 6was9's Avatar
    Who makes best fitting ones?
    I have PZs that drives me betty because they slide down... no they are not too big for me as they fit rather tight at my thigh...
    I've heard Sportful make great fitting warmers but where do you buy them though?
    “nobody hears about dick cheney having an existential crisis.” - MKUltra3
    Mashers only!!
    Reputation: HUGH's Avatar
    Aug 2004
    Quote Originally Posted by 6was9
    PZs are not that great because they do not have gripper stuff at the top (where they need it). I am a Single Speeder so keeping the knees warm is a must!! I have tried all brands and the ones I leke the best are..... Biemme, Giessegi, and Castelli (all have grippers top and bottom). I use large shorts and large leg warmers. My sister uses medium shorts and medium leg warmers. Hope this helps..
    HUGH
    Aug 2004
    Smile Thank you!
    Quote Originally Posted by HUGH
    HUGH
    Thanks for the info and advice!
    Bickety bam!
    Jun 2004
    Check out..
    Quote Originally Posted by gigemaggs99
    I'd highly recommend DeFeet Kneekers. One size fits all. They don't move once they're on, and they're pretty warm.
    Apr 2004
    I like my Nikes
    Kyle
    Do you put them under your shorts or over it? I've never had a problem with any sliding down... but i put them under the shorts
  1. Inner knee pain
    By dgangi in forum General Cycling Discussion
    Last Post: 10-03-2004, 07:39 PM
  2. Replies: 54
    Last Post: 10-02-2004, 03:37 AM
  3. Just had a knee operation.
    By High Gear in forum General Cycling Discussion
    Last Post: 08-19-2004, 04:08 AM
  4. Newbie question on knee problem
    By rengaracchi in forum General Cycling Discussion
    Last Post: 07-15-2004, 08:12 PM
  5. Knee Problems, Not the usual question, really
    By witcomb in forum General Cycling Discussion
    Last Post: 06-12-2004, 08:13 AM
