Results 1 to 4 of 4
    May 2013
    Fascinating mystery (suspect high end) steel frame with longitudinal ridges?
    I have recently acquired this bike built by Albuch Kotter (German). I suspect the bike was built in the late 80's Note the Cinelli spoiler BB, racing number braze-on, Campag dropouts. The seatpost is 27.2mm. The frame tubes have external longitudinal ridges, which I can't find the origin of. What type of tubing is this? Any thoughts about the bike would be appreciated!
    Attached Thumbnails Attached Thumbnails Fascinating mystery (suspect high end) steel frame with longitudinal ridges?-image.jpg   Fascinating mystery (suspect high end) steel frame with longitudinal ridges?-image.jpg   Fascinating mystery (suspect high end) steel frame with longitudinal ridges?-image.jpg   Fascinating mystery (suspect high end) steel frame with longitudinal ridges?-image.jpg   Fascinating mystery (suspect high end) steel frame with longitudinal ridges?-image.jpg
    merckxman
    Jan 2002
    Could this have started out as a regular tubeset and then he took off material in strips to lighten the frame?
    May 2013
    Quote Originally Posted by merckxman View Post
    No, definately ridges in the steel itself. I have managed to figure it out : the tubing is without a doubt Oria GM 0.0. It was used by a few Italian builders/ manufacturers in the late 80's, early 90's (Pinarello, F.Moser, Coppi, Bianchi), including a TdF winning frameset used by Indurain. Apparently quite rare.
    is riding in MOPP4
    Reputation: Tachycardic's Avatar
    Mar 2013
    Congratulations! Looks like a great bike!
    Wake me up when it's alarm green.
  1. mystery frame... ideas?
    By beno in forum Retro-Classic
    Last Post: 02-12-2012, 04:21 PM
  2. Mystery Italian Frame
    By arabiangoggles in forum Bikes, Frames and Forks
    Last Post: 11-17-2011, 05:59 PM
  3. Mystery Steel Supplier in Milan
    By iyeoh in forum Colnago
    Last Post: 08-22-2010, 06:54 PM
  4. Need Help Identifying Mystery Frame
    By lonelobo in forum Retro-Classic
    Last Post: 06-28-2010, 04:58 PM
  5. Help identify Mystery Frame
    By dryn in forum Bikes, Frames and Forks
    Last Post: 09-07-2007, 12:31 PM
