Results 1 to 9 of 9
    Mar 2004
    Internal cable routing
    I have an 83 vintage steel internal cable routed frame I'm building up. I'm looking for some direction as to how the derailleur cables are routed through the BB. My bike has a 3mm hole in the chain stay BB area for the FD cable to exit. I'm wondering if anything special is done here. I have in my mind over time the cable rubbing against the edge of the hole will cut into the base metal. How's yours?
    a real member's member
    Jul 2016
    unless it causes a known problem, i always go with the designer's intentions.
    WA outdoor enthusiast
    Mar 2002
    Which manufacturer was internally routing FD cable in 1983?
    Does it have downtube shifters?
    Pics are invaluable.
    Mar 2004
    Here's a couple of pictures.
    Mar 2002
    Well, you won't be getting a piece of housing in that tiny hole in the NDS chainstay.
    On the positive side, the tension on a FD cable shouldn't be enough to damage a chromed tube. I would be more concerned about the derailleur cable becoming abraded.
    Mar 2004
    I' going to get some delran? and just use it right there. I may end up re finishing the frame if so, I'll add a tube with a bend in the bottom bracket.
    Out riding.
    Reputation: 1500SLR's Avatar
    Sep 2018
    You're going to have fun with cables and fitting a bottom bracket. I know I did with my custom build. It's doable but its a bit of a nightmare and you're not going to want to ever swap your bottom bracket once you've got cables in there also.
    Reputation: Fivethumbs's Avatar
    Will the Shimano cable liner fit?
    Out riding.
    Sep 2018
    The cables will fit inside the bottom bracket it won't be easy for you to get your bottom bracket in once you're done though.
  1. Replies: 2
    Last Post: 04-04-2018, 01:05 PM
  2. Cable rub in top tube for internal cable routing....
    By Dcmkx2000 in forum Components, Wrenching
    Last Post: 04-30-2014, 11:20 AM
  3. Replies: 3
    Last Post: 12-06-2013, 10:00 AM
  4. Replies: 2
    Last Post: 11-19-2013, 05:43 PM
  5. internal cable routing
    By kenyonCycleist in forum Components, Wrenching
    Last Post: 12-29-2004, 09:19 PM
