Results 1 to 1 of 1
    We have met the enemy...
    Reputation: paredown's Avatar
    Oct 2006
    Persechini Custom Road / Show frame
    As seen on http://cgi.ebay.com/Persechini-Custo...efaultDomain_0 (and thanks again to the CR folks) I think this is one of the more beautiful retro modern frames I have ever seen--love the color/finish..
    "Here are the specs for this frame. It was made to be a bit more comfortable then the typical road bicycle frames with a little lower BB drop, a slightly shorter TT and a bit higher head tube:
    57 cm Seat Tube c-c
    56 cm Top Tube c-c
    73 deg. Head Tube
    73 deg. Seat Tube
    75 mm BB Drop
    425 mm Chainstays
    12 cm Stem
    43 mm Rake 1 threadless fork
    Columbus Zona Tubeset 0.8mm/0.5mm/0.8mm main tubes
    31.8 mm Down Tube / 28.6 Top and Seat Tubes
    This frame has been presented at several custon framebuilder shows (NAHBS and San Diego Custom Framebuilders Show) and has drawn great interest at each of the showcases with David's fluid and careful working of the lugs and composition. The lugs have been masterfully built up around the transitions.
    This frameset is in *MINT* condition and it's only use has been as a display of Davids craftsmanship. The reserve is less then 2/3 of what this would sell for as ordered. The R. Brian Baylis custom paint job is the icing on the cake!
    The auction is for the Frame, Fork and matching stem."
    Attached Thumbnails Attached Thumbnails Persechini Custom Road / Show frame-1.jpg   Persechini Custom Road / Show frame-2.jpg   Persechini Custom Road / Show frame-3.jpg   Persechini Custom Road / Show frame-4.jpg
    "When the spirits are low, when the day appears dark, when work becomes monotonous, when hope hardly seems worth having, just mount a bicycle and go out for a spin down the road, without thought on anything but the ride you are taking."
    (Sir) Arthur Conan Doyle. Scientific American, January 18, 1896
Sea Otter Classic
Contest
