Results 1 to 4 of 4
    old school drop out
    Reputation: laffeaux's Avatar
    Dec 2001
    Shimano 600 (RD-6207) rear derailler
    I have an old rd-6207 that I'm trying to put on a bike with index-shifting, but not having much luck getting it to work. Is the 6207 rear derailler pre-index? It seems like it's pulling too much cable.
    old school drop out
    Dec 2001
    It has to be pre-SIS. I put on a new derailler and everything is good.
    Hey, I might remember why that won't work.
    This is from memory, but I think indexing rear derailleurs have a little lateral play in the upper pulley, to compensate for slight imprecision in the clicktion. The early 600s didn't have that and won't work with indexing shifters. Maybe.
    old school drop out
    Dec 2001
    I think that the amount of cable pull need to move the derailler "x" amout is different on SIS versus non-SIS deraillers. I was trying to shift through seven cogs, and I eventually figured out that I wasn't hearing six clicks along the way, yet the limits were set right. The derailler seemed to be moving more than I wanted.
    I'm not sure if there was a set cable pull ratio prior to SIS. There would have been no need for one.
Sea Otter Classic
Contest
