I would like to build up another bike and am thinking along the lines of 8 speed DA 7400 series components. I am not familiar with this era of DA components and have some questions.
What would be an appropriate group for a 1990 Miyata Team? I find that there are 7400, 7401, 7402, 7403 and 7410. What is the difference between all of these? Which should I focus on that would be of the right age +/-. I want to use downtube shifters. Any particular parts to look for or to avoid?
Thanks for any advice,
James
Edit: I just found the Miyata catalog from 1990 and it shows the DA components but doesn't list exactly what they are other than 8 speed. Any ideas? This bike is really going to compliment my '82 Miyata Team and Pro!
I think your overall troubles in rebuilding isn't what group series you should use, it's more if you'll be able to find the parts.
8spd stuff is really hard to find now. I believe a friend of mine fought to the death for used 8spd downtube DA shifters... let's just say it cost as much as Ultegra STI6600 ~150 bucks.
'09 Voodoo Wazoo
'08 Pedal Force RS2
'06 Raleigh Cadent 5.0
'01 Trek 4300 MTB
'93 Norco Nitro MTB Touring
'88 Schwinn Prelude Fixie
1 hour of running = 1 hour of wasted time when you could have been riding. - Alaska Mike
James
The Dura Ace 74xx numbering system is weird...There never was a complete 7401, 7402,7403, or 7410 group....These numbers were limited to an upgraded part only..That could be just a brake
If the frame is is a 1990, you should be using an 8 speed but stay away from 7410 series parts..(cranks, BB, headset and front derailleur).they are too new...
Anything earlier the 7410 will work and look fine....
I did a Dura Ace timeline in this forum that I updated last year....I'll try to find it or you can do a search
If the frame is is a 1990. You should be using an 8 speed but stay away from 7410 series parts..(cranks, BB, headset and front derailleur).they are too new...
here is the timeline....again to be period correct, stay away from the 7410 parts
I started this with the 7400 series even though there were the original DA group starting in 1973 and the DA AX and EX series prior to the 7400 series...If someone has part numbers for these, please feel free to add them
Dura Ace timeline
7400 6 speed SIS (198?)
Uniglide 6 speed cassettes
BR-7400 single pivot brakes (non SLR)
HP 7400- ball bearing headset
HB-7400 last non-cassette hub
MF-7400 last freewheel
FC-7400 standard profile crankarms
RD-7400 (6spd)
ST-7400 (8spd STI used with RD-7402 below) works on 7spd also
PD-7400 aero pedal with clips (still used on track a lot!)
SP-7400 A and B- A= fluted B= aero
BL-7400 - non aero brake levers
7401 FH - 1st cassette hub for 7400 series.(126mm)
SL-7401 7 speed SIS downtube
PD-7401 Look compatible pedals (Used by Lance to win TdF)
7 spd Uniglide cassette
RD-7401 (7spd)
BL-7401- aero brake levers- no return spring
7410 SP - Easton seatpost
HP 7410 - Cartridge bearing headset
PD - SPD pedals
BB 7410 - Cartridge BB 103mm spindle
FC 7410- Low profile crankarms w/ SuperGlide chainrings (the best looking crankset ever made by Shimano)
FD 7410 - ft derailleur
7600 Track
7600 -high flange hubs -Still made today for Keirin racing
1/8" or 3/32" chainrings and cogs available
7600 Cranks arms- Still made today for Keirin racing
7600 headset- Blueish colored cups
7700 ST-7700 9spd STI (1997)
BB-7700 splined BB with needle bearings
FC-7700 hollow low profice splined crankarms
PD-7700 SPD-R pedals (No longer used by George Hincapie!)
FH-7700 Ti cassette body, Al QR levers
CS-7700 9spd cassette, Ti large cogs
HB-7700 Al axle, Al QR levers
BR-7700 Dual Pivot SLR, smaller & lighter than 7403
CN-7700 Narrow chain with annoying master pins
25 Anniversary Group 1999 ( 7700 series parts highly polished and some ti bolts)
7710 Track group - still produced today
FC 7710 splined crankarms
HB 7710 low flange hubs
BB 7710 sealed version of splined BB
For the sake of this retro discussion, we'll stop at 7700 series
I am not too worried about finding the parts. I just need to know what would be correct. I managed to find the parts to build up my two Miyatas with 6 speed DA AX and EX groups.
Dura Ace timeline
Hey Dave, thanks a bunch. I'll definitely save that info on my computer. By the way, I just recently bought this Pinarello.
It has 8 speed DA for the most part. I guess I can always swap those DA parts onto my Miyata, right? I have not yet actually seen them but they seem to be the right age. I plan on building that Pinarello up with C-Record, so if I went this route, I'll save a bunch of time, effort and money. This is dependant on those parts being the right ones that I need. Can you tell by looking at the pictures if they are? There was concern that the shifters are particularly difficult to find.
I've never had a problem locating 8 speed DT shifters...i see them for sale all the time for about $50-60...The 8 speed STI shifters go for big bucks....The irony is that 9 speed 7700 shifters were designed by Shimano to shift 8 speed when connected to a 7400 series derailleur. I guess most people don't realize that or they wouldn't be spending huge dollars on 7400 shifters
What about the components in the pictures. Do they look like 7400 series?
How about those shifters? I definitely want to stick with downtube shifters on this build.
I bought it originally to strip and polish the chrome. I haven't yet seen it in the flesh and hope it is as nicely preserved as in the pictures. I would like to keep it with that black chrome finish if at all possible.
I just picked up a used ~1990 Bianchi Columbus SLX tubed roadie with a mix of Camp/Shim parts on it.
The hubs are old DA 8 spd. The rear is the original cassette style where the last cog is the lockring. Unfortunately it's a 12-21 and I live in the Rockies. I put a 34/46 cobbled crank on the front for now to get a decent climbing gear, but I'd really like to find a different cassette to go on there.
Or I might just keep an eye out for a whole new rear wheel. Shame, cuz those DA hubs are nice. It's got DA front and rear der's too...Shimano 600 DT shifters.
The bike rides really nice, but it's had a hard life. Only paid $200 for it though...
Double check that it's not threaded inside the freehub body too for a lockring...In the crossover years from Uniglide to Hyperglide, Shimano had a DA hub that would work with both. It was right around that time period
The hard part is the cassette cogs don't have the "big gap" that newer cassettes do, so I can't slide any old 8 speed guy on there...and finding and 13-25/26 cogs are impossible.
Bumping an old thread.
I've got a DA 8-speed equipped Merlin circa 1991 with down-tube shifters. I'd very much like to put STI shifters on it (I have a circa 1983 Guerciotti in case I get nostalgic for down-tube shifters, or friction shifters, or steel frames...). This is the only place that I have read that 7700 shifters are compatible with a 7400 rear derailleur. It would be great to have more options than just the ST-7400 when shopping for old, used shifters. Can you explain how this works? This isn't mentioned in "the bible" (sheldonbrown.com).
Thanks!
-- Larry B.
As long as you are using a 7400 series RD and 8 speed cassette, all you need to do is connect the 7700 shifters normally( no special routing needed)..you just don't use the extra click...
Sheldon's DA chart shows it but he doesn't go into detail on the page..Look at the top of the DA chart. It says any 9 speed shifter .( the fact that it's not yellow only means no special routing is needed)
This works like a charm.....it only works because the 7400 RD has a different cable pull than other Shimano RDs. One click with a 7700 shifter will move a 7400 series RD for 8 speed spacing...
As further proof, look at the label on the Shimano 9 speed bar end shifters, they say "compatible with RD-7700 9 speed and RD-7400 8 speed"
I've been using this set up for years because I like the silver 7700 downtube shifters.. I run 7400 components with 7700 shifters with zero issues and perfect shifts
Thanks to your tip I managed to complete a second 7400 groupset by using 7700 DT shifters. Works flawlessly.
Thanks for the additional information! So, any 9-speed STI shifters should work with the 7400 RD? (If I read Sheldon's chart correctly, now.)
Alternatively, any post-1997 8-speed STI shifter and post-1997 Shimano rear derailleur should also work with my old Dura Ace 8-speed cassette?
Finding either ST-7400 or ST-7700 shifters in good condition seems difficult right now. Well, there is the NOS set of ST-7400 on ebay for $1200...
I shouldn't be in any hurry, but I test rode a couple of new bikes. They can keep the carbon frames (light as they are), but I've been seduced by STI-style shift levers.
OK, I know this is probably too late but HG sprockets fit UG cassettes - apart from the smallest 2 (which are the threaded one and another one). I've added 2 larger HG sprockets to my UG cassette. It just needs some minor hand-filing of one of the splines. Its really simple though.
If anyones still interested, I have pictures somewhere I can post if requested
Rob
