Results 1 to 7 of 7
    TZL
    TZL is offline
    May 2005
    which is lighter? DA7800 crankset or FSA MegaExo SLK?
    i'm out to build the lightest bike that can handle my 200 lbs and my big gear mashing style
    what are the weights with BB?
    am i better off with a conventional FSA crank and BB setup instead?
    thanks
    Mountainbiker
    Reputation: Knut's Avatar
    Jul 2004
    Check out the listings here: http://www.weightweenies.starbike.co...type=cranksets
    DA seems to be the lighter alternative @ 735 grams incl. BB.
    Both should be able to handle your weight no problem.
    TZL
    TZL is offline
    May 2005
    thanks !
    Quote Originally Posted by TZL
    thanks
    FSA's megaexo cranks have all come in WELL over their initial claims. even the new K-force is basically the same weight as DA10 (and more expensive). the previous ISIS K-force (not megaexo) was quite a bit lighter than DA9, and with a nice, light BB, would be lighter than DA10. not sure if you can find ISIS K-forces, though. also, ISIS has a poor reputation on mountain bikes. I know some posters here use ISIS on their roadies without problems, but the small bearings are very vulnerable to dirt contamination and failure, which is admittedly much more of a problem on MTBs.
    I would go with the D/A 10.....
    I would recommend against the ISIS at your weight and "mashing" style. IMO the SLK crankarms seem like a step down from the old Team issue (EXO B.B., however, is a definite improvement).For FSA go with the K-Force, but the D/A 10 crank is a better value. I use Campy with an FSA triple(ISIS), but would love to try the new D/A 10 triple crank(when avail.) with my Campy drivetrain; I'm not sure how D/A 10 rings work with a Campy 10 chain, however.
    Big "mashers" claim there is a noticeable difference between D/A 9 and D/A10 cranks: no FD rub. If you are changing your crank/B.B. there is really no reason to go with ISIS unless you are getting a deal you absolutely cannot refuse.
    aka Zonic Man
    Reputation: Jed Peters's Avatar
    Quote Originally Posted by twelvepercent
    DA rings work perfectly with a campy 10 chain, for what it's worth.
    Thanks for feedback on D/A10 rings with Campy chain!
  1. My new FSA MegaExo Compact 50/34 shifts great w/ DA 10
    By SFG in forum Components, Wrenching
    Last Post: 04-29-2005, 03:45 AM
  2. FSA Cranks- Pro Carbon Isis or SLK MegaExo?
    By gibbons in forum Components, Wrenching
    Last Post: 03-24-2005, 07:52 AM
  3. Any one else have this issue with FSA Compact Megaexo?
    By Taskmaxter in forum Components, Wrenching
    Last Post: 03-09-2005, 02:28 AM
  4. spam: New FSA Idea Megaexo Crankset....REDUCED PRICE!!!
    By stumpy232 in forum Components, Wrenching
    Last Post: 03-02-2005, 08:09 PM
  5. Shimano Riders, Do not purchase an FSA K-Force MegaExo Crankset.
    By technocycle in forum Components, Wrenching
    Last Post: 02-28-2005, 09:09 AM
Sea Otter Classic
Contest
