Results 1 to 12 of 12
    Sep 2010
    Vertical Compliance
    Hi there
    can someone tell me about vertical compliance..(comfortable....... to stiff)
    I totally forgot what it meant
    thanks
    Man, I'm Awesome
    Reputation: brianmcg's Avatar
    Oct 2002
    Its a marketing term dreamed up by some suit to get people to buy a bike in the hopes it will be more comfortable.
    But unless your talking about a shock on a mt bike its purely B.S.
    "I like to ride my bicycle." - Lance Armstrong -
    Formosan Cyclocross
    Reputation: Dajianshan's Avatar
    Jul 2007
    I think on the Seven order form they are asking how comfortable you want the ride. Do you want more road feel or cadillac plushness.
    With Seven you can see that in the rear triangle.
    Compare these seatstays. These are both Axiom SL models from 2011. One is built to be a little more compliant for training rides and everyday use. The other is raced.
    You can see the smaller diameter tubing on the more compliant frame. It does not wrap around the seat tube like the stiffer bike, despite the rider being heavier than the rider of the bike which is raced.
    The racing frame was tuned for road feel and just enough stiffness outside of crits. You feel the bumps, but not the bite. I know of other Sevens that are so plush they are described as "rolling on a cloud."
    I know the more compliant ride was modeled after the Colnago C-40. The racing frame had no model. This is just one difference.
    The term to look out for in marketing is "Laterally stiff... yet vertically compliant."
    Attached Thumbnails Attached Thumbnails Vertical Compliance-stays.jpg   Vertical Compliance-stays2.jpg
    Sep 2010
    thanks Dajianshan
    Now I remember.. the tubing on the seat stays depends on the riders weight..
    simply because a lighter rider may select a more comfort ride (0-5) and still not flex the frame . While a massive rider will have to select stiffness (6-10) so the frame wont flex when climbing/sprinting.
    Formosan Cyclocross
    Jul 2007
    Well... not necessarily. The compliance would allow the tubing to give more or less suspension. The less suspension you want the thicker the stays. A heavier rider may get thicker tubes. A heavier rider might want a cushy ride and get thinner tubes. Seven calculates the rider weight into the tube selections anyways, so the custom sheet asks you how comfortable you want your ride for your weight. The bike with the thicker stays in the picture actually belongs to the smaller, lighter rider (me) because I wanted a bit more road feel and stiffness for climbing and racing. I think the other Seven owner has about 15-20lbs on me.
    Sep 2010
    i recall that I selected more comfort on vertical and more stiff on drive train...
    your seat stays diameter looks the same as mine.. I checked the welds and its also the same..
    Attached Thumbnails Attached Thumbnails Vertical Compliance-img_4604.jpg   Vertical Compliance-img_4605.jpg
    Formosan Cyclocross
    Jul 2007
    Mine is a 5. The chainstays may also be thicker.
    Formosan Cyclocross
    Jul 2007
    Im 140lbs.
    Formosan Cyclocross
    Jul 2007
    By the way... how does it ride?
    Sep 2010
    im 150lbs... sometimes 154 after a party or 147 after a century ride.. ;-)
    the bike rides the way I wanted it to be..I'm trying to recall vertical compliance as I'm planing on getting my second seven but this time the SL version (i think that's the manipulated tubing right?)
    I also recall that I selected 2 or 3 on the vertical compliance.. since I usually ride centuries and double centuries...
    Formosan Cyclocross
    Jul 2007
    I have the SL version.
    The tubing is externally double butted for weight savings and tube manipulation. I think my frame weighs 1300 grams.
    The longest ride on that frame is 105 miles with 7000ft of climbing and it is comfortable enough. Climbs and descends superb. In races it has really come through. I can plow over uneven surfaces without chatter or bite. Very good. It still reminds me it is stiff, but it is never jarring.
    Apr 2009
    Quote Originally Posted by echo7 View Post
    thanks Dajianshan
    As I understand it, you don't pick number relative to your weight. You pick the performance that your looking for and Seven then factors in your weight to get that performance you are looking for.
    Honestly, don't worry about the numbers. Just tell Seven what type of bike that you want, how it should handle, what you want to do with it, how you want it to climb and how you want it to steer ... they then take care of the rest. I didn't really care what numbers I ended up with, what I did want is a rear end that transferred power and a bike that tracked like it was on rails while not being nervous. I'm not sure is Seven could have done any better than what they provided me, it's really good.
  1. brake shoe and vertical compliance
    By PoorCyclist in forum Components, Wrenching
    Last Post: 05-10-2011, 03:54 PM
  2. Compliance with ADA act on a budget
    By Argentius in forum Politics Only
    Last Post: 06-17-2010, 06:04 AM
  3. why vertical dropouts?
    By greg75 in forum Retro-Classic
    Last Post: 06-13-2008, 06:48 PM
  4. How much vertical...
    By Aceman in forum General Cycling Discussion
    Last Post: 07-13-2006, 09:53 AM
  5. vertical storage
    By girishji in forum Fixed/Single Speed
    Last Post: 04-25-2004, 12:48 PM
