Hi,
I don't see lot of information going on about this bike. Maybe 1-2 weeks ago I saw it already on a UK web site but they removed it.. however, i did copy paste the information before they deleted it.
I heard somewhere that the MSRP price of the Tricross Sport '11 would be around 1250 US like the Crux elite.. There is a lot of similarity between this new tricross and the crux.
I must tell you that i was really looking to buy a Tricross Sport '10 but they are saleout in my region so i'm thinking about getting the new one.. I intend to use it to go work, for fun (trails, a bit of road and maybe a little cyclotourism). So.. What do you think of the bike and the Spec.
The differences between the 2010 and 2011 seem to be: No Zertz insert + no rack fitting on the fork, Mavic CXP22 instead of Alex ACE-19, Cassette 11-32t instead of the 12-25, and of course the internal cable routing.. Geometry seems different too but i dont have it.. And 150-200$ approx more than the '10
So what do you think? Would you give it a try and does it worth the difference?
Thanks!
Here is the picture and the component list:
Frame : specialized A1 Premium aluminium, smooth weld fully manipulated tubing, semi-compact Freeroad design, internal cable routing, rack and fender fittings, integrated headset
Fork: Specialized FACT carbon legs, alloy crown & steerer, fender fittings
Headset : 1-1/8 inch sealed Cr-Mo bearings integrated w/ headset, 20mm alloy cone spacer with 20mm of spacers
Stem : Specialized Elite-Set, 3D forged alloy, 4-position adjustable, 4-bolt 31.8mm clamp
Speed : 27
Front mech :Shimano Tiagra
Rear mech : Shimano Deore LX
chainset : Shimano Tiagra 50 x 39 x 30T
Bottom Bracket : BB-7420 w/crank bolts
Chain : HG-73
Cassette : Shimano HG-50, 9-speed, 11-32t
Rims : Mavic CXP22
Tires : Specialized Borough CX Sport, 700x32c, wire bead, 60TPI Front Specialized Borough CX Sport, 700x32c, wire bead, 60TPI Rear
Front hub : Forged alloy Hub, sealed bearings, 32 hole, for J bend round spokes
Read hub : Forged aluminium, 32h, double sealed ball bearings, cassette, QR
Front break :Tektro wide canti
Rear break : Tektro narrow canti
Seatpost : Specialized Elite, carbon wrapped alloy, two-bolt clamp, 27.2mm
saddle: Body Geometry Riva Road, w/ steel rails
extra : *Chain stay protector, chain catcher, derailleur hanger, clear coat, owners manual
Thanks!
Speed : 27
Chain : HG-73
Rims : Mavic CXP22
