Or maybe phrased the other way around: Many would run deeper in front in still conditions, but choose to go a bit shallower in front to minimize impact in crosswind performance.
More aero to run 60 front rear, a bit less 60 front 45 rear, and less yet running 45 front 60 rear. Only reason to run a shallower rim in front is to reduce susceptibility to crosswind gusts.
Crit is punchy in nature, lots of hard accerlation out of corners. If you don't have the brute strength to accelerate like the big guys, then you're better off using lighter wheels so that you can accelerate with them. You save at least 20% of your energy drafting them you will ever will by using any aero wheels.
I'm a lightweight (130 lbs) and there is a crit course here that has a segment that is about 1 mile long straight away with a backwind and slightly downhill grade (1-2%), and the big guys will hit 38-40 mph for this stretch every time. There is no way I could hit this speed by myself every time without cooking myself up (aero wheels or not!), but by drafting the big guys, I can go with them with gas to spare in my tank, and I'm only using the Dura Ace C24 wheelets (shallow wheelset).
Road race, same thing. Most of the time I stuff myself right in the middle of the pack (or any pack) and cruise along with them.
Smart racing beats aero wheels any day. Only time it really counts i time trial as you're all on your own.
For crits and road races the best all rounders are probably the enve 1.45s. They're one of the lightest sets of wheels and at 45mm, you're going to get decent aerodynamics. If you are more concerned about aero benefits you should probably go with the zipp 404s or hed stinger 6s.
I found myself thinking about this last summer, when I was out at the velodrome a lot.
I'd take that .5 mph. It doesn't matter how much sooner I get my hub to the line - just that I do.
For me, I found that part of "racing smart" was knowing when to do something really stupid - attacking off the front and seeing if I could "get away with it." Having some fancy wheels to help, if only a little, makes a difference in that circumstance.
That said, I'm still just doing 32-spoke wheels for now. I'm not even sure if I'm going to get to race track this season, let alone in a position to throw a bunch of money at aero.
I think not only getting a higher top end speed but also the ability to keep that speed is well worth the extra grams.
I can drop 5 pounds in a week and that would probably suffice any weight gain on equipment.
I really appreciate the real world input.
One thing for sure though, if any of us are worried braking parts then why race? That's the least of my worries. Priority #1: Try to win. Priority #2: If avoidable, don't be a part of any wrecks. Avoid trying not to brake parts....not on my list.
You can get light and aero, I had this debate with myself till the LBS made me an offer on a set of Mavic CCU's I couldn't resist. 45mm and weight was 1095 without skewers, lighter than posted on their website. I however have no knowledge on how they perform over my DA 50mm clinchers.
For road races and crits, I really think the shallower carbon wheels in the 40 mm range are the way to go. You want a fairly light (under 500 gram) rim to keep the accelerations quick.
You can do more for aerodynamics by adjusting your bike fit so you are more horizontal on your bike during the race. There is a reason pro's ride long stems with plenty of drop between handlebars and saddle.
Related Threads
Road Bike, Cycling Forums
5.4M posts
205K members
Since 1990
