Been curious about Veloplugs for a while. With the
demise of my handbuilt wheels I acquired some Easton (Velomax) Circuits. Juanmoretime hooked me up with the Veloplugs through the mail (THANKS JUAN!). Last night I started popping them in the spoke holes to see how they would do.
Luckily the holes in the Circuits would fit the Veloplugs. I had to clip off two of the four little prongs that hold in the veloplugs. Once that was done I could pop them in with my thumb. After that I mounted up some Michelin Carbons. In the mounting process I managed to dislodge one which was no big deal. I simply popped it back in the hole and continued to mount up the tire.
After a commute to work this morning the tires are still holding air thus these things appear to be working as advertised. I nomally use the Ritchey snap-on rim strips thus I am probably not saving much weight BUT I wanted to give them a shot. Several additional observations:
- I have read that the extra space in the spoke bed makes tire mounting easier. That did seem to be the case with the Easton / Michelin combo as well. Normally new Michelin Carbons can be quite a workout to get onto most rims but these mounted up quickly. That is a plus in my book!
- My first flat will be the true test of these little devices. I'd hate to be changing a tire at dusk and have one of the plugs fall out and not notice it missing.
I'd be curious to hear from others that have used these things... Also which rims did/did not work. I have a buddy who wants to try them on some old Rolf Sestreire wheels...
