The Thread Killer....
Performance Bike In Oceanside Ca.
Hi everyone, I have a question about Performance Bikes in Oceanside.
I just purchased a 2011 Fuji 3.0 that I will be picking up on Friday. Does anyone have any feedback on well they "Fit" a rider to their new bike? Do they get into it, or is it a seat adjustment and send out the door?
My guess would be the latter - but you may be able to get them to do more with some persistence. For instance getting bar height set assuming they haven't already cut the steerer down to nothing. I doubt they'll have the ability to swap out handlebars but you may be able to get them to swap stems for a shorter or longer version of the same model if they have it - again this is a 'maybe'. I'd try and get setback on the saddle adjusted, bring your shoes and have them install pedals and adjust cleat position. They could also rotate the bar a little perhaps and/or make slight adjustments in the hoods but assuming the bars are already wrapped etc they won't be able to do more than minor tweaks. I'd focus on:
- bars: height, fit/position of hoods, stem length (and rise/drop as pertains to bar height and reach)
- Saddle: height, setback, make sure it's level
- Pedals/cleats: proper position of feet relative to pedal axle
miles to posts ratio is > 30:1
I've had good and bad experience with the service at that particular Performance.
Never know what you're going to get.....
- You may not post replies
- You may not edit your posts
Forum Rules
