Page 1 of 3 123 LastLast
Results 1 to 25 of 53
    a real member's member
    Jul 2016
    €@&#! my rubber cement dried up
    must've been two years since i last flatted. happened today at the far end of my ride. and i found the rubber cement in my patch kit had dried up! i ripped the little cement tube open and tried to use the dried cement to bond the patch. don't do that. doesn't work. i just wasted precious co2 finding out. so i hoofed it to the hardware store and bought some cement. patched the tube. yay! but ran out of co2. boo! hoofed it to the bike shop (which, by now, i'm almost back home) and properly inflated the tire.
    man, that sucked.
    check yer patch kit, foo!
    Dec 2006
    Sorry for your pain, but that was a great story!
    Reputation: velodog's Avatar
    Sep 2007
    Spare tube and glueless patches, maybe a pump.
    They're temporary but I've used the glueless patches for a flat and left it there till the tire was wore out.
    Too old to ride plastic
    Reputation: Lombard's Avatar
    May 2014
    I carry a patch kit as a backup in the unlikely event that I have such a bad day that I run out of spare tubes.
    I also carry a Topeak Mini Morph pump. They don't run out or air and the weight won't slow you down - really!
    Reputation: Oxtox's Avatar
    Aug 2006
    carry two tubes, three CO2 cartridges, and a couple of glue-less patches...have never had to patch a tube on the road.
    hfc
    hfc is offline
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    The little tubes of glue are pathetic. I carry the adhesive patches for emergency use and have used duct tape before in desperation. I have decreased the amount of CO2 I carry and use a nice mini hand pump almost exclusively now.
    Nov 2002
    Maybe a pump?
    Sep 2007
    Maybe a pump?
    Many have an aversion to pumps, hence my mild suggestion. But I will say if pumping up the tires is going to rest solely on co2 it would be wise to carry at least 3 or 4 of them, but then that defeats the whole idea of them.
    Nov 2002
    I buy a big tube of Slime glue at Wal-Mart. Cheap and takes long to dry out. Bulk patches of 100 Remas too.
    Sent from my iPhone using Tapatalk Pro
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    And the moral of the story.... carry a spare tube (and glueless patches). It's much easier to patch your tubes at home rather the side of the road.
    Carrying a 100g tube is much better than hoofing it to the hardware store and bike shop.
    Sep 2007
    I'm surprised to read that blackfrancois was so ill prepared having seen pictures of the large Carradice saddle bag he has posted he uses.
    tlg
    tlg is offline
    May 2011
    You could fit a dozen tubes in that thing.
    The ultimate saddle bag
    Feb 2002
    This. I've never understood the idea of depending on a patch kit at the side of the road. What if you're caught in the rain? What if your glue has dried out. Makes no sense.
    Nov 2002
    Plus you should not ride on a newly patched tube (according to Jobst Brandt).
    Aug 2006
    'defeats' them how...? not sure I'm following...
    would rather carry multiple cartridges than resort to stroking some crappy mini-pump a couple hundred times on a scorching hot summer day...btdt, it sucks pretty hard.
    simply cracking the valve on a CO2 rig is pretty effortless. makes the whole process of flatting much less of a pita.
    Sep 2007
    Quote Originally Posted by Oxtox View Post
    I say it "defeats" them because many carry one, maybe two, of them to be minimalists. 3 or 4 ceases to be minimal.
    I carry a pump or co2 or sometimes both, depending on what's on the bike or how long of I ride I'm planning on. To tell the truth, I don't care how I air up my tires, as long as the flat is repaired and I can be on my merry way.
    The draw back of co2, in my eyes, is bleeding it off and pumping the tires up with air before the next ride.
    Nov 2002
    They are also somewhat hazardous in that the freezing cold can burn the skin and if your inflator malfunctions, you can't simply unscrew the full but punctured cartridge cause it will take off like a rocket. Happened to me with an Innovations pump that's also a CO2 inflator. I screwed in the cartridge and nothing came out. I had to unscrew the pump from the cartridge with my foot on it and it took off like a rocket. Good thing I pointed it away from people. Upon later review there was an o-ring missing from my pump where the cartridge seats.
    Aug 2006
    carrying a single cart isn't very prudent. pretty sure I can get home with three tho...covers a misfire and two flats.
    dumping the CO2 and airing up at home with a floor pump is a big meh for me...
    Apr 2011
    Feb 2002
    Not sure where that comes from. You let the glue fully dry before applying the patch (another reason not to use a patch kit at the side of the road) and that is as good as the adhesion is going to get.
    Nov 2002
    Don't know. He said it continues to dry (even though it looks dry) and that it's easy to pull off a patch that you just stuck down and it's almost impossible to pull off a patch thats been stuck down for a couple of days thus proving his point. Whenever I patch I don't put the same tube back in the tire and save it for another time.
    tlg
    tlg is offline
    May 2011
    I guess this is what he's referring to.
    I think it depends on the type of patch and glue used. With vulcanizing glue and a Rema patch, after a minute or so, that b!tch isn't coming off.
    Patching Tubes by Jobst Brandt
    To test how fast patches cure, a patch can be pulled off easily shortly after application, while it is practically impossible after a day or so. For reliable patches, the freshly patched tube should be put in reserve, while a reserve tube is installed. This allows a new patch more time to cure before being put into service.
    Jul 2016
    i don't know why you would think bag size has anything to do with flat preparedness.
    as i wrote, i haven't had a flat in two years. so i hadn't checked my patch kit. i didn't know cement could dry out in its container.
    but it's all good. i added a new co2, new tube of cement, and a couple new patches in my road kit.
    and yeah, i still have plenty of room in my bag for some sweet components i might buy at the shop or a couple subs from the vietnamese deli.
    May 2014
    Quote Originally Posted by blackfrancois View Post
    and yeah, i still have plenty of room in my bag ........
    For a spare tube maybe?
    Sep 2007
    Good idea.
  1. Rubber cement for patching tubes
    By tarwheel2 in forum Components, Wrenching
    Last Post: 10-21-2009, 06:17 AM
  2. Replies: 4
    Last Post: 06-05-2009, 07:41 AM
  3. Rubber Cement or Gasoline
    By MisterC in forum Fixed/Single Speed
    Last Post: 02-28-2008, 07:01 AM
  4. ultralight hiking recipe "dried tortellini"
    By gutfiddle in forum The Lounge
    Last Post: 01-29-2008, 01:52 PM
