Results 1 to 7 of 7
    Roadbike Rider
    Reputation: Chainstay's Avatar
    Mar 2004
    142mm wheel in a 135mm frame Yes/No?
    I have a set of disc wheels that have 12mm thru axles and a 142mm rear locknut dimension. It would be nice to run them in a second bike that is set up with a 135mm rear spacing and quick release skewers. It's an Aluminium framed Spec Secteur
    Can this work by spreading the frame? Should I.
    "It's supposed to be automatic, but actually you have to push this button. "
    John Brunner (Stand on Zanzibar)
    Reputation: velodog's Avatar
    Sep 2007
    I don't positively know, but I've read that it's bad juju to try and force or cold set an aluminum frame. I myself, would reserve that practice for steel frames.
    Too old to ride plastic
    Russian Troll Farmer
    Sep 2016
    You can NOT spread an aluminum frame. Sorry, it will not work.
    "L'enfer, c'est les autres"
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Your only shot is if the wheel set in question has 135mm QR endcaps/axle conversion made for it.
    Ditto.
    Roadbike Rider
    Mar 2004
    Ditto.
    That's it, a simple solution. They should be available from Alexrims
    Thank You
    Jan 2005
    Quote Originally Posted by Chainstay View Post
    Thank You
    Word of warning: Alex lists lots of parts and stuff in their catalog....that no one in human history has ever been able to actually buy from them.
    Aug 2013
    12x142 is the thru axle version of 135 mm hubs. The "extra" length sits within the ledge on both sides of the bike rear triangle.
    So, the 12x142 will not work on your bike b/c it is a thru axle and your frame is not.
    If the hub has replaceable end caps, you may be able to get 135 mm QR end caps.
  1. Specialized SCS 135mm vs 142mm - What's better for road riding?
    By vitasoyboi in forum Bikes, Frames and Forks
    Last Post: 05-13-2016, 04:22 PM
  2. 130mm wheel on a 135mm frame?
    By tetedecourse in forum Components, Wrenching
    Last Post: 05-07-2010, 09:16 AM
  3. Yes! Yes! There IS a God.
    By rkb in forum Politics Only
    Last Post: 01-24-2009, 05:32 PM
  4. Amy Winehouse says yes, yes, yes to Rehab
    By Bocephus Jones II in forum The Lounge
    Last Post: 08-14-2007, 11:34 AM
  5. yes, yes, YES!!! (spoiler!)
    By lonefrontranger in forum Pro Cycling - Tour de France
    Last Post: 05-19-2004, 12:09 PM
