Results 1 to 13 of 13
    Roadbike Rider
    Reputation: Chainstay's Avatar
    Mar 2004
    160 pounds, rough roads. What rims for road bike?
    Looking for a recommendation for custom wheels as follows
    • Weigh 160 pounds
    • FTP, not even 200 Watts
    • Frame is a Merlin Extralight
    • I already have Ultegra 32 hole, 10 speed hubs
    • I use the bike on broken pavement, urban bike paths, chip-seal and light off road
    • Also used on group rides on wet and gritty winter roads
    • Currently run 28c Conti 4 Seasons
    • Not that concerned about the price
    I have a LBS with a very good builder so I just need to figure out rims and spokes.
    I'm looking for a durable alloy rim but I don't need something for a Clydesdale either. I looked at Velocity, HED and the new Mavic Open pros. What would be the best option?
    Thanks: Chainstay
    "It's supposed to be automatic, but actually you have to push this button. "
    — John Brunner (Stand on Zanzibar)
    Jan 2014
    With those hubs you can ride any rim you want. Use double butted spokes. I have h plus son archetypes and like them. My wife has pacenti sl23, and they are also nice.
    Sent from my XT1565 using Tapatalk
    Click here to edit signature.
    Feb 2003
    I built a set of wheels for my wife with those hubs and used Velocity A23 rims and Sapim Laser spokes and she uses 28C Gatorskins. 1 flat in 5 years. You could use the Kinlin 31W rim and spokes of your choice. Mine would be C X-rays.
    Reputation: Lombard's Avatar
    May 2014
    Before I recommend rims, a few questions. What wheels are you using now? How wide are they? What is your frame clearance like?
    If your frame clearance is tight and you go to a wider rim, your 28c tires will expand and may not fit.
    Roadbike Rider
    Mar 2004
    My current rims are Eastons and the outside measure is 17mm. The 28c tires fit on with a 27mm width. The chain stays are 33mm across at the tightest point. Will I be pushing it with a 27mm rim?
    May 2014
    Quote Originally Posted by Chainstay View Post
    Are you sure it's your outside rim width that's 17mm? Did you measure this yourself? It's the inside width that matters. Measure where the tire bead mounts.
    Roadbike Rider
    Mar 2004
    [QUOTE=Lombard;5139679]Are you sure it's your outside rim width that's 17mm? Did you measure this yourself? It's the inside width that matters. Measure where the tire bead mounts.[/QUOT
    The inside measure is 14.5mm. I took all measurements with digital callipers and rechecked. They should be good. Thanks for your help.
    May 2014
    Ouch! So from the info you have provided, it sounds like you have only 3mm on each side between the tire and chain stay. If you are running 14.5mm rims, a 17mm may not fit, or at the very least, you will rub the chain stays when you flex the wheel climbing a steep hill. If you really want to go to 17mm rims, you may have to step down to a 25c tire in back.
    I bolded 27mm rim as I am assuming you meant 17mm rim.
    Roadbike Rider
    Mar 2004
    Yes I meant 17mm, not 27mm rim.
    I will try to borrow a wheel with a 17mm rim to try. That's the only way I'll know.
    I did read to expect a change of 0.8mm on tire width when going up 2.0 mm in rim width
    May 2014
    Good idea!
    That is about what I noticed when going from a 15 to 17mm rim.
    Thanks: Chainstay
    H Plus Son Archetype. Hed C2 is very good too but having used both I can't tell the difference between those and Archetypes so would say there's no point in paying more for the Heds.
    CX'er
    Reputation: bikerector's Avatar
    Oct 2012
    Velocity A23 is a good rim. Hed Belgium are better but more expensive. Flo 30 or one of their carbon rims might not be bad. I think you can get some boyd altamont rims from prowheelbuilder, or a few other builders now I guess, which are good.
    I've had the most experience with A23's and have really enjoyed them on road bikes and CX bikes since they came out. I haven't ridden HED's rims but they're well respected. I've ridden the altamonts wheels from Boyd and they were trouble free while I had them for a season of training which included gravel miles.
    May 2014
    OP,
    As you can see, there are many choices out there and many opinions to go with them. You may want to read this excellent rim review below:
    Alloy Rim Roundup - Fairwheel Bikes Blog
    The DT Swiss RR440 may be a good compromise for you. At 16mm internal width, this one may work for you and is a good quality rim.
  1. Solace rattling a little on rough roads
    By olijay in forum Scott
    Last Post: 07-11-2017, 09:43 AM
  2. Riding on rough roads
    By davidm724 in forum Components, Wrenching
    Last Post: 07-23-2012, 03:31 PM
  3. which tire for rough roads
    By g-dawg in forum Wheels and Tires
    Last Post: 05-10-2009, 05:08 PM
  4. How do 585's fare on rough roads ?
    By BenH in forum Look
    Last Post: 04-21-2008, 01:00 PM
  5. Tire sizes for commuting on rough roads.
    By Zero Signal in forum Commuting, Touring and Ride Reports
    Last Post: 03-01-2008, 08:52 AM
