Results 1 to 4 of 4
    Sep 2006
    23mm (rear) and 25mm front) tires on bike
    Hi
    My frame cannot fit a 25mm tire on the rear rim (using Archetype rims which are a little wider). Has anyone tried using 25mm on the front and 23mm in back?
    Thanks
    Reputation: upstateSC-rider's Avatar
    Aug 2004
    Guess there's nothing wrong with it, it just negates the reason most people use a 25mm in the back, and that's for comfort due to the higher volume. On one of my older race bikes I was unable to fit a 25mm in the rear so I was able to fit a tubeless 23mm for the comfort I was looking for at the time.
    In reference to the Assault on Mt Mitchell...
    Quote Originally Posted by merckx56
    The easier solution is to find a biker bar in Spartanburg the night before, go in and pick a fight. The ass-whipping you'll get will be far less painful than the one Mitchell will give you the next day!
    You can but I probably wouldn't bother. I barely noticed the difference in the front (but in the back helps quite a bit).
    Very minor point but if you like to stock up on tires when you see them on sale using two different tires makes that more complicated/guess work.
    Reputation: Lombard's Avatar
    May 2014
    IMHO, I think front compliance is more important than rear. My arse is fleshier than my hands, so I can deal with less compliance there.
    I see no problems with using a wider tire wherever you can. No a problem using 25mm front/23mm rear. Adjust pressures accordingly.
  1. 23mm tire on 25mm mm rim or 25mm tires on 20.5 rims - questions
    By littlepitboy in forum Wheels and Tires
    Last Post: 01-09-2017, 05:37 AM
  2. 23mm or 25mm tires?
    By GumbyN in forum Beginner's Corner
    Last Post: 01-07-2011, 03:33 PM
  3. 23mm vs 25mm tires...
    By namrufmot in forum General Cycling Discussion
    Last Post: 05-31-2006, 03:37 AM
  4. 23mm vs. 25mm Tires, Handling Difference?
    By who?me? in forum General Cycling Discussion
    Last Post: 08-19-2005, 07:30 PM
  5. Are 25mm tires slower than 23mm tires?
    By UCLA_MCDbio in forum Components, Wrenching
    Last Post: 08-21-2004, 05:56 AM
