Results 1 to 6 of 6
Thread: 28 tires/brakes
    Jan 2015
    28 tires/brakes
    I picked up some continental 4000s 28s for my bike. Bike is 2015 specialized roubaix sl4 with axis 1.0 brakes. Are there any brakes that would prevent me having to deflate the tube to take on and off. Once you get it on, it has proper clearance but getting on and off is the issue. I read reviews on Shimano 105 brakes and the description says fits 28 tires.....does this mean I wouldn't have to deflate? Any brake that could help would be better.
    Reputation: Lombard's Avatar
    May 2014
    I have used Shimano 105 brake calipers with 28c tires and never had to deflate tires to get the wheels off. I'm also pretty sure you will notice improved modulation over the stock Axis 1.0 calipers.
    Feb 2002
    Quote Originally Posted by gasman777 View Post
    How close to the rim do you have the pads set? Some people set them much closer to the rim than necessary, which makes it hard to remove the wheel and also makes for poorer brake modulation because you have to brake with your finger tips on the levers.
    May 2014
    Most bikes come from the factory with the pads set too close to the rims.
    CX'er
    Reputation: bikerector's Avatar
    Oct 2012
    Keep in mind, conti GP 4000's tend to measure a little larger than advertised so it may not fit right in. However, I haven't had trouble with the conti's, or any 28mm tires, with sram red brake calipers and I assume shimano allow similar widths of tires when opened.
    Jan 2015
    Good point, I'll have to check.
  1. 28mm Tires, 6800 Brakes?
    By dwl in forum Components, Wrenching
    Last Post: 06-21-2015, 07:06 PM
  2. Can I run 28c tires without going to 57mm brakes
    By chrisclougherty in forum Components, Wrenching
    Last Post: 02-24-2012, 09:51 AM
  3. Build help-wheels, brakes, and tires
    By tn29'er in forum Cyclocross
    Last Post: 07-14-2010, 12:53 PM
  4. Brakes, Cranks and Tires
    By SSSasky in forum Fixed/Single Speed
    Last Post: 03-27-2005, 04:22 PM
