Results 1 to 25 of 42
    2X on T-11 = Sad Spokes.
    Just finished up a build with T-11 hubs and Pacenti rims. It's a 28 hole rear with 2X on both sides using CX Rays. My Non drive side spokes are sad. I bet they only have about 53 kgf on them at best. I ended up with 125 on the drive side. Is this about the norm? Is this going to be o.k. for 150 lb rider?
    I did a build earlier this week on the same rim and hub with 3X on the drive using Race Spokes, and 2X NDS Lasers. I don't remember the NDS being that slack.
    Reputation: jmorgan's Avatar
    Apr 2012
    Sounds about right.
    2012 Cervelo S5 Team
    2012 Felt Z6 (sold)
    Online Wheel Builder
    Reputation: Zen Cyclery's Avatar
    Mar 2009
    Sounds like your right on the money. Just make sure to stress relieve properly and retrue, and you should be good to go.
    That's just spooky. I had to make a bunch of trips around the wheel to negotiate that out of it. I was eeking every bit of tension I could find out of the NDS spokes. This 11 speed offset just isn't very promising.
    After looking at dcgriz charts on another thread, it doesn't look like there is much more tension to be had regaurdless of the pattern.
    Oct 2012
    Sounds like producers of spokeprep and OC-rims should now start increasing their production.
    grizzly moderator
    Reputation: dcgriz's Avatar
    Feb 2011
    2x/2x on a 28h Pacenti with T-11 will give you a calculated Tnds of 53.8 kgf when Tds is at 125 kgf so your 53 kgf is spot on.
    However, I would not dismiss your feeling that the spoke feel too loose. The accuracy of your measured 53 kgf value depends on the accuracy of your tension meter. Meters like the Park Tools are best used to measure relative tension between spokes rather than absolute. Furthermore, if we are to reliably measure up to that accuracy level then the meter should be calibrated for the specific spoke at hand.
    Some time ago I read Musson's impressions on meters and how dispersed the readings are even within the same gauge spokes of different manufacture because of manufacturing tolerances. So the chart that Park shows for every possible spoke in existence may be a far cry if accuracy of absolute values is in question.
    If your DS spokes feel nice and tight, leave it alone. The NDS is what it is and at least theoretically you've reached nirvana. When down to these values, I have started using spokeprep for added insurance but no goo can replace proper balance and stress relief. If you think your DS needs a bit more tightening, I would not be afraid to do so although my Park showed 125 kgf.
    You are absolutely correct on the 11 speed. This thing "fixed" a problem that did not exist and created a whole bunch of new ones, but that's the bike industry, isn't it? I think 135 mm OLD road hubs are getting closer and closer.
    With bicycles in particular, you need to separate between what's merely true and what's important.
    grizzly moderator
    Feb 2011
    Quote Originally Posted by Orfitinho View Post
    .....or the other way to look at that is to optimize the balance between the hub geometry stiffness and stability. The T-11, at a BAR range between 2.3 and 2.4, shows pretty good stiffness but its doing so at the expense of Tnds.
    A person like myself would prefer the preference on stiffness, but a person that does not need it would do better choosing a hub that puts more emphasis on compromising the lateral stiffness in favor of higher tension at the NDS.
    wheelbuilder
    Reputation: ergott's Avatar
    Feb 2006
    I use radial heads out for that combination. You get a few more kgf on the NDS. Not a lot, but every bit goes towards durability.
    Apr 2012
    Quote Originally Posted by ergott View Post
    Which would results in:
    Tds Tnds BAR
    125 66.9 1.87
    Do you use a stiffer spoke on the ds?
    2012 Felt Z6 (sold)
    wheelbuilder
    Feb 2006
    yes I do.
    grizzly moderator
    Feb 2011
    Quote Originally Posted by jmorgan View Post
    Tds Tnds BAR
    125 66.9 1.87
    I'm getting totally different numbers than yours for the 28h Pacenti SL23, T-11, 2x DS and radial NDS.
    Radial NDS bracing angle is 7.9 deg, 2x DS bracing angle is 3.5 deg, that makes the BAR 2.3. The Tnds comes out at 52.3 kgf with Tds=125 kgf.
    2x DS / 3x NDS shows me the highest Tnds at 55.4 kgf with Tds=125kgf
    3x DS / 2x NDS shows me the lowest Tnds at 51.7 kgf.
    I got a chance to check the set I built earlier this week . THe 3X Race spokes on the drive side seems to help a little. I was getting closer to 56 kgf on the 2X NDS Lasers.
    I think Ergot is correct in using heavy spokes/ radial lacing in order to get every once of tension on these hubs. It's like you have to use every trick in the book to squeeze the max out of these new offsets.
    wheelbuilder
    Feb 2006
    Quote Originally Posted by dcgriz View Post
    Not in front of calc.
    Are you checking radial heads in or out? Heads out is a smaller bracing angle which makes tension closer to DS than 2X will.
    May 2012
    Quote Originally Posted by Enoch562 View Post
    Every time I hear about those T-11 hubs, it brings back bad memories:
    Wheel re-lacing: need help!
    Radial lacing plus a liberal amount of spoke adhesive might work for you.
    But I can't shake the thought the the hub is poorly designed WRT to flange spacing and dimensions and that the T-11 will never build a strong and durable wheel. Others seem to be happy with it though so it may just have been my bad luck of getting a poorly built wheel to start with.
    I now own Fulcrum Racing Zero and have done zero maintenance in 4 months of owning them. These wheels have zero flex and I paid less for them than I paid for my T-11/C2 wheels.
    grizzly moderator
    Feb 2011
    When I measure the hubs myself, I measure the center-flange to the inside of the flange however I have found that this is not always the case with the published hub specs.
    The T-11 published data shows 38 mm as the C-L offset. I don't know where on the flange this is taken from and unfortunately I did not confirm the measurement when I had a chance. So I experimented running the numbers from 38 down to 36mm in steps of 0.5mm to allow for the heads out; when at 37mm I saw a very small increase to the Tnds (0.7 kgf to be exact, Tnds=53) and a reduction to BAR by 0.1 (2.2). At 36mm, Tnds=55 and BAR=2.2. When 2x/2x at 38mm C-L, I calculate the Tnds=53.8kgf. So the difference appears to be very small at best and only if we accept that heads out imposes an effective offset reduction by 2mm.
    I think the radial spoking is more effective in reducing the effective flange diameter to a theoretical 0 and in doing so reduces spoke stretch which in turn adds a degree of safety on maintaining the Tnds as the wheel turns.
    Edit to add: at 36mm the bracing angle is 7.5 deg from 7.9 deg at 38mm
    Apr 2012
    Using Spoke calc, radial nds angle heads out is 6.2deg and 2x ds is 3.3deg
    I am using specs posted by Fairwheel's website.
    This results in the numbers I posted. 1x nds is 7.9deg like you posted. You might check your formulas and make sure they are referencing the correct cells.
    2012 Felt Z6 (sold)
    grizzly moderator
    Feb 2011
    I see where you got the 6.2 number from. I'm trying to understand what the 3.5/2,1 portion of his formula stands for. Flange thickness?
    Now look at the spreadsheet cell c31. If you input 0 (for radial) then the bracing angle it gives you is 7.9. Also notice that now he is also giving you the tension ratio (44%) which he did not before for either case of heads in or head out. If you calculate it using the 6.2 and 3.3 values, its value is 53% and that's a 23% increase in tension which I find humongous. If you were to use alternating head placement, the left hub offset would have to be reduced to 29.5 mm from 38 mm to give you the 6.2 bracing angle. That's a 8.5mm reduction and looking at the laced hub I can not comprehend how such reduction could be possible just by flipping the spokes.
    So something else its going on and I believe it's on our interpretation of what Rinard is trying to tell us. I don't think it's accidental that he did not list the R/L tension on the spreadsheet using the radial heads in/out angles considering the outmost detail he included on everything else.
    Now, lets approach this a different way; leave the bracing angle degrees alone and look at deriving to the Tnds by using the hub offset W and the spoke length L (which are the entities defining the bracing angle). The spoke length is the spoke length regardless of head placement. The offset will change somewhat when the heads are out. I create a sequence of iterations by progressively reducing W in steps of 0.5mm and determine the effect on Tnds until an offset reduction of 2 to 3mm is reached
    My formula is Tnds=Tds (Wds/Wnds) (Lnds/Lds)
    Feb 2006
    Also notice that now he is also giving you the tension ratio (44%) which he did not before for either case of heads in or head out....
    Who is "he"?
    grizzly moderator
    Feb 2011
    Quote Originally Posted by rruff View Post
    Who is "he"?
    Rinard. Jmorgan is picking the radial heads-out bracing angle of 6.2 deg from spocalc
    Apr 2012
    3.5/2,1
    "3.5/2" im guessing is the change in angle depending on heads in or out (+-1.75deg), the ",1" is just denoting how many significant digits to round the result to. So he more or less is adding or subtracting 1.75deg.
    Im guessing when you alternate the heads (2x) they are effectively canceling each other so you just take center to flange.
    I wonder if his equation is a little messed up.
    Playing around with a caliper and a wheel I have (which is laced radial heads out on the nds) the only way I come up with 1.75deg which is ~8mm difference is:
    Spoke thickness + Flange thickness + Spoke thickness (2mm+3.5mm+2mm)=7.5mm difference between heads in and out
    =ROUND(DEGREES(ASIN(7.5mm/spokeLength)),1) <---1.6deg for 269.5mm spoke
    So the difference in the inner most part of a heads out spoke vs the outer most part of a heads in spoke is ~7.5-8ish mm which equates to a total difference of 1.75deg heads in vs out. Which means you should add half of 1.75 for heads in and subtract half of 1.75 for heads out. He adds 1.75deg for heads in and subtracts 1.75deg for heads out, which is where I think he might be off.
    He is more or less saying there is a 3.5 deg difference in in vs out, which seems like a bit much and would result in a ~16mm difference and I cant find a possible 16mm difference on the wheel I have.
    I could be be wrong though.
    So if im correct his formula should be
    =CONCATENATE(ROUND(DEGREES(ASIN($D$32/E24))-1.75/2,1)," heads out; ",ROUND(DEGREES(ASIN($D$32/E24))+1.75/2,1), " heads in")
    2012 Felt Z6 (sold)
    grizzly moderator
    Feb 2011
    3.5/2,1
    I dont think there is anything wrong with Rinard's formula. What I believe may be wrong is the spreadsheet user applying the bracing angle from the spocalc spreadsheet cells G24 and H24 in determing the Tnds. Not because the trigonometry is wrong but because, IMO, the relationsip between bracing angle ratio and tension ratio is not as linear when there is no crossing of the alternating spokes.
    It seems to me that when alternating spokes cross, the push against each other and finally rest at a point between their original undisturbed paths. This crossing point appears to have an effect to the tension ratio analogous to the flange height and, I believe, that is one of the reasons why we get different stiffness and tension values with the different crossings. When radially lacing heads-in or heads-out there is no spoke crossing and the spoke path is unnafected from stress/strain imposed by the following spoke. This is why I believe one should not use the same equatio to relate bracing angles to tension as when the spokes cross. this is the reason, i believe, Rinard did not included the tension ratio on his spreadsheet for this particular case.
    This is my theory anyway and I feel comfortable in empirically calculating the stiffness and tension of radially all head-in or all head-out lacings by decreasing or increasing the hub offset by no more than 2 or 3 mm at best to derive the effective offset. Then I use the normal formulas to calculate tension and stiffness. The results are as expected; slightly better Tnds at the expense of a small decrease in stiffness for this particular example. But no miracles; the range of Tnds stays in the mid 50s no matter what.
    Edit: correction
    Going back to the original intent of this post, here is my conclusions after building/ riding said wheel.
    I might have been able to obtain a little stronger wheel laterally with a different pattern and different spokes but, it is plenty strong for my massive 6'0, 163 lb girth. The White Industry hubs build as good as anybody else's in that price range. They are a High end American made hub with a middle of the road price. Probably the best $$$$$ value out there. Alchemy seems to have a little better dimensions but they a bit pricey. I think the fact that I used 28 spokes and solid/wide Pacenti rim, stiffened this build up to a acceptable level. I made sure I got every ounce of tension out of both side of the spokes. I didn't get 'em close, I measured every spoke and took it as far as I could. I see no reason why this wheel should every give any problem.
    Apr 2012
    His equations
    Radial
    =DEGREES(ASIN(width nds/spoke length))-3.5/2)) <-heads out
    3x,2x,1x
    He is subtracting 1.75deg (based on where it is in the equation) to radial lacing. This equals ~8mm.
    I just cant see where he is more or less adding and subtracting 8mm on heads in and 8 mm on heads out. There is no way there's a 16mm change from heads in and out. 16mm difference is huge.
    2012 Felt Z6 (sold)
    grizzly moderator
    Feb 2011
    Apologies; the derailing was not intentional.
    The discussion has never been against the T-11 or any hub in general because there is not one hub out there that is optimum for any circumstance. We all make the compromises we must to get the best hub for our individual use. Personally, I favor the extra stiffness of the T-11 for my use.
    As I suggested yesterday on post#6, if the DS tension fels good, leave the wheel alone and go ride it.
    Feb 2006
    Heads in vs heads out might be 5-6mm. Not 8mm. Of course this will vary depending on the spokes and hub, but 8mm seems excessive.
    Damon Rinard made that spreadsheet many years ago and I'm pretty sure he hasn't revisited it in very long time... he is a top guy at Cervelo now.
    The crossing just serves to split the difference between both sides of the flange... which is why it is assumed that the spokes originate from the center of the flange. It isn't like having a high flange. And the stiffness and tension ratios are what you'd expect based on that.
    The equation you use to calculate the tension ratio is very close to reality.
  1. knocked the spokes - true or replace spokes
    By PoorCyclist in forum Wheels and Tires
    Last Post: 06-17-2011, 02:49 PM
  2. Double butted spokes with Striaght gauge spokes?
    By Gee3 in forum Wheels and Tires
    Last Post: 04-13-2011, 05:48 PM
  3. Strong rim/few spokes vs. weak rim/lots of spokes
    By dualpivot in forum Wheels and Tires
    Last Post: 05-10-2010, 04:01 PM
  4. DT Aerolite spokes vs. DT Revolution spokes
    By uncle in forum Wheels and Tires
    Last Post: 05-25-2008, 04:17 AM
  5. light rims/more spokes or heavier rim less spokes?
    By Kung Fu Felice in forum Wheels and Tires
    Last Post: 05-31-2007, 07:47 AM
